Question about Hasbro Nerf N-Strike Vulcan EBF-25 Blaster
Can't put cocking bolt on nerf centurion - Hasbro Nerf N-Strike Vulcan EBF-25 Blaster
2 Suggested Answers
SOURCE: nerf gun wont shoot
the relese mechanism came loose and i put the pin back in if anyone needs help ill be happy to help fix it
Posted on Sep 17, 2009
Disassemble bolt on bolt action shotgun
Pretty much all bolt action bolts work the same. You need to relieve the spring force. That means pulling back on the cocking knob. The head will come off easily then. You need to have the bolt in the exact condition it's in when cocked, cocking knob back, to disassemble it. Reverse that to reassemble.
Apr 21, 2014 | Mossberg Optics
Have a winchester 1906 pump .22lr, when the bolt is pumped back to cock the hammer, the hammer falls as the bolt is going back to battery. Now if I pull the hammer back to cock and then run the bolt the...
The cocking mechanism is not pushing the bolt back far enough to reach the purchase point of the hammer. I do not know if that model has any way to adjust the range of bolt travel, but it could likely be worn metal just barely falling short of the mark.
Can you find any noticable play in any parts between the cocking mechanism and the bolt?
Have you tried pushing the bolt itself back (inserting something in front of the bolt and push back) to see if you can make the hammer catch in that manner, to narrow the problem down to just the cocking mechanism?
You may need to have a reputable gunsmith look at it, which would also be much safer than trying to repair it yourself, as well as safer than trying to use it while in this unreliable state. If the hammer toches a round just a little too hard before locked in fully chambered position, you could blow out the extractor pin or even worse, as I'm sure you could imagine.
Oct 14, 2013 | Sport & Outdoor - Others
Bolt stuck in closed position after cleaning XL7 30 06
If you had the bolt sleeve or cocking piece out of alignment, it will jam. You should call 1-800-544-8892
to see what they have to say about it
Feb 22, 2013 | Marlin Model XL7 Rifle XLTL3006, 30-06...
How do I unjam a double cocked nerf diatron
1. Make sure that there are two disks loaded in the launcher. They must be pressing against the pressure switch at the top of the chamber. 2. Use a screwdriver to push in the T-shaped switch that would normally be triggered when the priming lever is closed. When both switches are activated, the trigger should be unlocked, allowing you to fire and to release the priming lever.
Feb 15, 2013 | Toys
My son put the cocking bolt together before attaching it to the gun. We can't get it apart! Do you have any ideas or do we have to get replacement parts?
Warning 1: this is a procedure for adults, not children - you may accidentally stab your own fingers.
Warning 2: this procedure might ruin the cocking bolt completely.
You'll need a small phillips head screw driver, two small flat-blade screw drivers, dental floss and four hands.
1) One end of the cocking bolt is fixed - leave this alone.
Remove the two screws from the inside face of the rotating end cap - this allows the outer cap to be removed.
The inner cap (still on the bolt) has four teeth that protrude into a recess around the metal bolt.
Warning 3: be extremely careful during the next step as the teeth may snap off completely and fingers could get hurt.
2) Using one of you four hands, hold the bolt upright on a sturdy table (with the fixed cap down) .
Simultaneously use the two flat-blade screw drivers to carefully lever one pair of opposite teeth out of the recess.
Whilst holding the levered the teeth out, firmly push the inner cap further down the bolt (down toward the fixed
end).
3) Wrap dental floss (or similarly stout, fine cord) around and around the recess to pack it out until it is flush with the outer diameter of the metal bolt - this is to stop the teeth locking back in place.
4) Slide the inner cap up and off.
Reassemble the cap.
Remove the dental floss.
Remind your son about the importance of reading the instructions first (just as you've always done yourself ;-).
Aug 15, 2011 | Hasbro Nerf N-Strike Vulcan EBF-25 Blaster
How many and what type of batteries are required for Nerf Dart Tag Strike Fire Two-Pack?
Wow, this is hands on the dumbest question EVER.
You know, no offense or anything...
Look- this is a manually operated toy.
Unless you or I got the name screwed up, or that picture up above is incorrect...
Oh wait, I just looked at it on Amazon.
Two solutions-
1.) READ THE INSTRUCTIONS, THEY'RE THERE FOR A REASON!!!
2.) Pull the cocking slide on top of the gun back, after inserting a bullet. Pull the trigger to fire.
That's all!!!
Oh yeah, 1+1=2, in case you didn't know that either.
LOL just kidding!!!
Good luck (idk why)...
Feb 27, 2011 | Hasbro Nerf Dart Tag Strike Fire Two Pack
My kid opened the Nerf N-strike Recon CS-6, loaded darts in the clip, shot it a few rounds, and now, somehow, the cocking mechanism is stuck in the middle position, and so is the trigger (like...
Take the rear bolt cover off ( 2 screws) . Reach inside with your finger and try spinning the spring. For some reason the spring will eventually move to a position that when compacted will bind with the bolt pass through hole.
Dec 25, 2010 | Nerf N-Strike Longshot CS-6 Blaster
How do you install Smittybilt Nerf Bars on a 1984 Ford Bronco? Does the rear of the Nerf Bar bolt to the back leaf spring and does the front bolt to the frame?
You're going to want to take that nerf bar, attach it to the spring leaf with the front bolt and frame as you say. Put some inhibitor behind the unit too. After flexing the torque rod for a while, move the rear axle upward by jacking underneath it. From there you should find that the whole thing just slips into place.
Jan 15, 2010 | 1984 Ford Bronco
Nerf gun wont shoot its cocked and when i pull the trigger nothing happens
Sep 06, 2009 | Hasbro Nerf Dart Tag Strike Fire Two Pack
Hasbro Nerf N-Strike Vulcan EBF-25 Blaster Logo
Top Hasbro Toys Experts
thegtw
Antony
William McDowell
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
