Question about Kohler - Toilet - One-piece - Santa Rosa - K3323-52
How to install a 83996 gasket - Kohler - Toilet - One-piece - Santa Rosa - K3323-52
Head gasket replacment procedure
Remove head, remove gasket, clean surface, install gasket, install head.
Apr 29, 2014 | Vehicle Parts & Accessories
Changing thermostat v6
drain coolant until its below the thermostat.then remove two thermostat housing bolts.remove thermostat housing and thermostat.make note position of thermostat before removing it.then carefully clean all old gasket material from thermostat housing and cylinder block you can buy can gasket remover at any auto parts stores.buy new thermostat gasket.if you have the paper type you need to buy RTV SILICONE to help seal gasket if you have rubber type gasket you dont need RTV SILICONE.make sure both surfaces are clean.then install new thermostat and new gasket.if you have paper type gasket apply thin 1/16 coat RTV SILICONE both sides thermostat gasket.then install gasket to thermostat housing then install housing to cylinder block first make sure new thermostat in place before installing thermostat housing. let RTV silicone sit up about hour before adding coolant.IF THERMOSTAT HAS THE O RING SEAL DONT NEED RTV SILICONE AND THE PAPER GASKET.
Jul 01, 2013 | Mercury Sable Cars & Trucks
Leaking red fluid from passenger side
sounds like maybe transmission fluid leaking, power steering.
Sep 10, 2011 | 1999 Pontiac Sunfire
My K3489 toilet leaks down and refills every few minutes. I replaced the flapper with a factory replacement with no affect. The leak seems to be around the 83996 soft rubber gasket at the bottom of the...
Hello, W/D here.
With the water off, drain the tank (lift the flapper). Look inside where the flapper seats. If the (usually black) gasket is rippled, this may be the cause of your trouble. You can remove the rippled portion of the gasket with a razor knife, just be very careful not to damage the flapper seat. Removing the protruding material will allow the flapper to fully seat without damaging the gasket integrity.
Best regards,
--W/D--
Jan 17, 2011 | Kohler Home
I need to change the gasket 83996 on my kohler santa rosa toilet,but cant get the part that says waterline off.how do i get it off?
You have to twist the whole thing. There is no nut or threaded portion under the gasket like you'd find on most (two-piece toilets). The hole under the gasket seal is a triangle-shaped and the bottom of the flush valve (the part that says waterline) has three prongs that lock the unit down against the gasket.
I don't remember which direction worked, but I put the grip/handle of a channel lock pliers down into the flush valve and that gave me the leverage to remove the whole part with gasket.
Nov 01, 2010 | Kohler - Toilet - One-piece - Santa Rosa -...
I need to know how to change he door seal(gasket)
  1. Buy a gasket that fits your door exactly.
  2. Soak the new gasket in hot water in the sink to make it pliable.
  3. Make sure the refrigerator is level.
  4. Find a nut driver that will fit the screws holding the old gasket in place and lay out your tools where you'll be able to reach them.
  5. Start at the top outside corner of the door and fold the old gasket back as you partly loosen the screws along half of the top and side. Don't loosen them all the way.
  6. Pull the old gasket out.
  7. Attach the new gasket by pushing it beneath the metal retainer and tightening the screws as you go.
  8. Replace each section the same way.
  9. Shut the door and check for gaps. The seal should lie straight and smooth all the way around the door.
  10. Notice if there are gaps between the gasket and the frame - this may indicate that the door has warped. (Fix it by loosening the screws and twisting the door a little. You may have to do this a few times before you get the door straight.)
  11. Put a flashlight in the freezer pointed toward the opening and shut the door. Turn off the lights. You shouldn't see any light leaking through.
Regards....
Oct 29, 2010 | Refrigerators
How to replace oil pan gasket on 2002 deville
Oil Pan REMOVAL & INSTALLATION
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Drain the crankcase.
  3. Remove or disconnect the following:
    • Negative battery cable
    • Oil level indicator harness connector, if equipped
    • Exhaust Y-pipe, if needed
    • Transaxle assembly from the vehicle.
    • Oil pan bolts and the oil pan
    To install: NOTE: The oil pan gasket is reusable unless it is damaged. Do not remove the gasket from the oil pan groove unless gasket replacement is required.
  4. Thoroughly clean the inside of the oil pan and the cylinder block contact surface. If the oil pan gasket is being reused, be careful not to damage it. Do not expose the gasket to cleaning solvents.
  5. If a new gasket is being installed, start the gasket into the oil pan groove and work the gasket into the groove in both directions. Once the gasket is exposed to oil, it will expand and no longer stay in the groove without wrinkles. If this condition exists, replace the gasket.
  6. Install or connect the following:
    • Oil pan. Torque the bolts, in sequence, to 89 inch lbs. (10 Nm).
    • Oil level indicator connector, if removed
    • Transaxle assembly, if removed
    • Y-pipe, if removed
    • Flywheel cover, if removed
    • Oil pan drain plug. Torque it to 15 ft. lbs. (20 Nm).
  7. Refill the crankcase.
  8. Run the engine and check for leaks. Fig. 1: Oil pan bolt torque sequence 7922vg08.gif
Oct 29, 2010 | 2002 Cadillac Deville
How to remove valve cover to replace valve cover gasket
1C-LTC and 2CL-TC Engines
(see Figures 1 and 2)
  1. Disconnect the negative battery cable. Remove and label all electrical wiring, connectors and vacuum hoses necessary to gain removal clearance.
Fig. 1: Loosen and remove the cylinder head cover retaining nuts
  1. Disconnect the PCV hose.
  2. Remove the six nuts and seal washers from the cylinder head cover. Loosen them in a crisscross pattern.
  3. Remove the cylinder head cover and the cover gasket from the cylinder head. Discard the gasket and replace with a new one.
To install:
  1. With a wire brush or gasket scraper, remove all the old gasket material from the cylinder head and the cylinder head cover gasket surfaces.
  2. When the cylinder head surfaces are free and clean, apply beads of sealant to the cylinder head in the locations shown in the accompanying illustration.
Fig. 2: Be sure to apply sealant on the cylinder head prior to cover installation
  1. Install the new gasket in the cover. Make sure that the gasket seats evenly.
  2. Place the cover with the gasket onto the cylinder head.
  3. Install the six nuts and seal washers. Tighten the nuts to 65 inch lbs. (8 Nm).
  4. Connect the PCV hose. Connect all removed vacuum hoses, connectors and electrical wiring. Connect the negative battery cable.
  5. Start the engine and inspect for oil leaks. Repair any leaks as necessary.
Hope this help (remember comment and rated this).
Apr 16, 2010 | 1990 Toyota Camry
How do I replace the valve cover gaskets for a 1996 Ford Ranger w/ 3.0L Engine?
The valve covers installed on the 3.0L engine incorporate integral (built in) gaskets which should last the life of the vehicle. Replacement gaskets are available if required.
  1. Disconnect the negative battery cable. Disconnect the ignition wires from the spark plugs, but leave them attached to their wire looms.
  2. Remove the ignition wire separators from the rocker arm cover attaching bolt studs with the wires attached, then lay the wires out of the way.
  3. If the left hand cover is being removed, remove the throttle body assembly, the PCV valve and fuel injector harness stand-offs. If the right hand cover is being removed, remove the engine harness connectors, fuel injector harness stand-offs and air cleaner closure hose from the oil fill adapter.
  4. Using caution, slide a sharp thin blade knife between the cylinder head gasket surface and the valve cover gasket at the four RTV junctions. CUT ONLY THE RTV SEALER AND AVOID CUTTING THE INTEGRAL GASKET.
  5. Remove the integral gasket from the valve cover gasket channel. Note bolt/stud fasteners locations before removing gasket for correct installation. Clean gasket channel and remove any traces of RTV sealant.
To install:
  1. Align fastener holes, lay new gasket onto channel and install by hand. Install gasket to each fastener, seat fastener against cover and at the same time roll gasket around fastener collar. If installed correctly all fasteners will be secured by gasket and not fall out.
  2. Install valve cover to the engine, lightly oil all bolts and stud threads. Apply a bead of RTV sealant at the cylinder head to intake manifold rail step (two places per rail).
  3. Place the valve cover on the cylinder head and install attaching bolts and studs. Tighten the attaching bolts to specifications.
0996b43f802117db.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 3: Rocker arm cover installation on 3.0L engines
  1. Install all remaining components in reverse order of removal procedure. Connect the ignition wires to the spark plugs and reconnect the negative battery cable. Start the engine and run to normal operating temperature, then check for oil and vacuum leaks.
Jan 19, 2010 | 1996 Ford Ranger SuperCab
I NEED HOW TO INSTALL A gasket ON THE DOOR OF A HOTPOINT, GASKET WR24X450.
look at the door gasket, look underneath the gasket and you can see how it is attached. either with a clip or the plastic itself is the one holding the gasket. unscrew all screws holding the gasket, order a new one and install backwards. if there is no screw, there is a grouve in the plastic wall where you can insert the gasket. just slowly pull the gasket and push the new gasket in to the grouve.
Feb 15, 2008 | GE Hotpoint Top-Freezer Refrigerator
Kohler - Toilet - One-piece - Santa Rosa - K3323-52 Logo
159 people viewed this question
Top Kohler Home Experts
john h
Tim Whalen
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
