Question about HP 7470a Graphics Plotter Service Manual
How do I change the motherboard on an hp7470a plotter
    Top Expert:
  • HP Master
  • 14,161 Answers
Posted on Feb 18, 2016
Plotter will not print
Check lan card led blinking pattern., Replace lan card(Jetdirect card 620n) & check, mostly lan card issue might be there..
Jun 12, 2015 | HP DesignJet 5500PS InkJet Printer
I have Canon ipf 650 , it doesnt show any eror, the problem is it is new plotter, printed very few, and stoped printing only empty sheets were coming out, we changed printhead and again the same, empty...
With this type of plotter there really is very few possibilities. Replace the ink cartridge with a manufacturer original cartridge. If that doesn't work, change your paper. If still no print, send it back to Canon on a warranty replacement.
Aug 22, 2013 | Canon imagePROGRAF iPF650 largeformat ...
I hahve hp 1020+ print not proper margine if top margin 1" print 1.2"
SOLUTION: Follow the steps below to change the plotter's current setting.
  1. From the STATUS screen on the plotter's display, press Enter.
  2. Scroll using the up or down arrow key until Page format is shown, and press Enter.
  3. Scroll to Margins and press Enter, the current setting will display either Normal or Expand.
  4. Press Enter, then using the scrolling keys change the selection to the choice needed and press Enter.
  5. Press the Previous key until the STATUS screen appears.
  6. The plotter is now ready to plot using the selected margin setting.
Feb 15, 2011 | HP LaserJet 1020 Printer
Need to change Y-axis belt on 650C Plotter. I
Try www.smpcshop.com they have many service manuals, from $9.95 to $19.95 to download.
Nov 27, 2009 | Office Equipment & Supplies
1. PEN NOT LIFTING. HOW DO I ADJUST PEN LIFT 2.PAPER SKEWS TO LEFT 3. NEED SERVICE MANUAL ON SUMMAGRAPHICS PLOTTER HI7200
Installing Pens
Most types of disposable pens must be activated before using the for the first time. If you are installing a new disposable pen:
  1. Press down on the pen cap to break the internal link seal.
  2. Holding the pen with its tip pointing down, shake the pen to start the ink flow.
  3. Remove the cap and test the pen for ink flow on a scrap of paper or media before installing it in the plotter.
    Some types of pens require adaptor sleeves to fit the pen holders in the pen changer and pen carriage. Insert each pen into its adaptor sleeve, if required, before installing it.
Using the Pen Changer
You may find it easier to temporarily raise the pen changer arm to install pens. Press the widest part of each pen into the jaws of each stall in the pen changer. After installing all the pens that you plan to use, lower the pen changer arm until it latches into place.
Notice that the pen changer stalls are numbered 1 through 8 from right to left (viewed from the front of the plotter).
Note: Make sure that the pen changer arm is in its lowered position and latched into place each time you power on or reset the plotter so that the plotter will correctly change pens.
Operating Without the Pen Changer
For operation without the pen changer, position the pen changer arm in the raised position and install a pen directly into the pen carriage by pressing the widest part of the pen body into the jaws of the pen holder on the pen carriage. You can still produce multi-pen plots, if desired, by enabling the PEN PAUSE parameter--------------Online KeyThe Online key toggles the plotter between on-line and off-line operation. The mode is displayed with each key press.
The plotter is initally in the on-line mode at power-on. In the on-line mode, plotting operations are enabled. When media is loaded in the plotter and the plotter has been selected (see below), an on-line plotter begins executing plotting commands from the input buffer as soon as they are received from the host computer.
In the off-line mode, the plotter can still receive data into its input buffer if it has been selected, but plotting operations do not begin until the plotter is switched on-line. The plotter can be operated manually in the off-line mode using the following control panel keys:
  • Pressing the left or right arrow key moves the pen left or right.
  • Pressing the up or down arrow key moves the media in or out of the plotter.
  • Pressing the PEN SELECT key accesses a menu to select a given pen from the pen changer.
  • Pressing the PEN UP/DN key raises or lowers the pen.
Pressing the Online key during plotting switches the plotter off-line and suspends plotting.
Pressing the Online key again will cause plotting to resume at the point of suspension. ------------------Pen Up/Dn Key
The Pen Up/Dn key raises and lowers the pen when the plotter is off-line. If there is no pen in the carriage, pressing the Pen Up/Dn key causes the plotter to retreive the currently selected pen from the pen changer (if the pen changer is installed and is in the lowered position).
Note: After approximately two seconds of no pen movement, the plotter will automatically raise a lowered pen to prevent ink from bleeding on the media, until the pen is moved again. If the pen is not moved for the period set for the AUTO-CAPPING parameter , the plotter will return the pen to its pen changer stall. To restore the currently selected pen to its previous position on the media, press the Pen Up/Dn key or an arrow key. Pen Select Key
When the plotter is off-line, pressing the Pen Select key allows you to select a pen from the pen changer. After pressingPen Select, press the <-- --> keys until the desired pen number is displayed on the lower line of the LCD, then press the Enter key. The plotter will retreive the selected pen from the pen changer.
The Pen Select key is also used in the Configuration Menu,
Oct 16, 2009 | Computers & Internet
Why want my hp 500 plus plotter turn on, no power to it what so ever
First check the power cable and change the plug. If don't help you have a problem in power supply module in your plotter.
Sep 28, 2009 | HP DESIGNJET 500 InkJet Plotter Printer
HP 750C Moved across country, bought a new iMac. Forgot how to set up plotter settings so the mac can find it. on the network. I remember having to make changes on the plotter, but can't remember what...
Hello, the plotter should be seen in your print and fax preferences (apple menu, system preferences, print and fax): In the print and fax preferences panel, you can click on "+" at the bottom left of the window, you should see your plotter appear in the window, and click on the "add" button Best regards
Jun 10, 2009 | HP DesignJet 750c plus InkJet Printer
450c color problem
The 430 ID is B/W, you need to load the 450C driver to get color, renaming the driver isn't enough.
Oct 13, 2008 | HP DesignJet 450c InkJet Printer
450c Plotter apparently dead
Check the cable connections, and the cable connector inside the plotter. Make sure your cables are good.
Dec 29, 2007 | HP DesignJet 450c InkJet Printer
HP 7470a Graphics Plotter Service Manual Logo
21 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
