Question about LG 42PX5D 42 in. Plasma HDTV
Sparkles Hi, I came across this LG 42PX5D 42 in. HDTV Plasma Television question on FixYa.com and thought you might be interested in reading it. Sparkles. My set is around 16 months old & has recently started doing this (appears to be getting worse). it is linked to a Sky HD box. I have several inputs including P.C using-(RGB), SKY -(HDMI), Home Cinema -(AV4) and DVD -(gold plate scart (AV2). The problem is active on all connections/inputs despite checking the connections. Occasionally (very rarely) it disappears for a programme or 2. At first didn't know if it was my sky signal strength but obviously, cant be that, if its active on all inputs. going to try the idea about panel power supply on fixya to see if it works. Regards, jason1
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 317 Answers
Call tech ..suggest main power pack..
Posted on Nov 26, 2007
I am looking for either LCD or Plasma TV 40-47' that is CableCARD slot equip. I found a couple offering the LG 42PX5D claiming it has CableCARD However when I look at LG specs it seems to say it does not....
It is Digital Cable Ready (CableCARD)
I'd stay away from them personally because of the following reasons:
1. No video on demand (VOD) or electronic program guide (EPG)
2. No PVR function - would require a PVR to record
3. CableCARD units cost more
4. CableCARD may not get the latest channel releases
5. Customer support is lacking as not many people are using CableCard
Oct 14, 2009 | LG 42PX5D 42 in. Plasma HDTV
LG 42PX5D 42 in. HDTV Plasma...
Are you sure theres no sound, or is there a possibility the unit may be in AV?... Most likely cause is the Y-Sustain board blowing.
Apr 22, 2009 | LG 42PX5D 42 in. Plasma HDTV
Connect 2 extra speakers
You probably need the 6,2mm size connectors and you can find them at www.BogueEngineering.com
Hope that helps, Gary
Feb 24, 2009 | LG 42PX5D 42 in. Plasma HDTV
Lg 42' plasma tv shut it self on and off automatically
Sounds simple but check your sleep timer is off.
Dec 31, 2008 | LG 42PX5D 42 in. Plasma HDTV
Loud pop Blank screen 42 inch Viore Plasma
Unfortunately, that board is the inverter board. And for this model the inverter board is only supplied with the the PDP panel. The panel is quite expensive, here's a link if needed:
LG 42PX5D Replacement Part PDP Plasma Display Panel
Dec 26, 2008 | LG 42PX5D 42 in. Plasma HDTV
LG 42PX5D sparkles on black
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 23, 2017 | LG 42PX5D 42 in. Plasma HDTV
Coloured sparkles appear in dark areas of picture
Sometimes just adjusting the VSCAN voltage inthe set will cure it. Other times it will be a faulty panel. Either case requires a technician to do the repairs.
Jun 10, 2008 | LG 42PX5D 42 in. Plasma HDTV
Plasma tv
change the z-sus panel or control panel
Feb 28, 2008 | LG 42PX5D 42 in. Plasma HDTV
LG 42 PLASMA
check all inputs on tv ,also check if menu on tv is working ,make sure lines arent being produce by another source, cable box etcc..If menu and or OSD are affected .Then there is a good chance you have lightning damaged some where in signal section on tv .
Dec 03, 2007 | LG 42PX5D 42 in. Plasma HDTV
Sparkles
Makes you wonder why nobody is taking on the problem, doesn't it?
Well , to the best of my knowledge, it is because nobody really can.
To understand why you have to understand what do they sparkles come from.
They are random electricity discharges coming from capacitors or other components that act like capacitors, but mostly capacitors.
When laymen hear about capacitors they usually associate the word with bulged electrolytic capacitors, which often cause problems in electronics of all kind.
Well this time it isn't about them.
It's about all other capacitors - or other components exposing similar qualities - which are installed on the board. Most of them are small filter capacitors put in parallel to the big ones or to other passive components such as diodes and resistors.
The excessive heat developed by the sustain boards damages those capacitors. It hardens the electrostatic material they are made of and small breaks in it start occurring at voltages that shouldn't otherwise be causing issues.
The trouble is, they can be everywhere. You can't just pinpoint which ones were caught at fault and causing the sparkles.
When it gets REALLY bad eventually the whole capacitor burns and either shorts or, more commonly, just breaks.
Believe it or not I've seen a board that exploded before my very eyes and , after the explosion, started working LIKE A CHARM!
Turned out a small filter capacitor had blown. It as not essential for the board's functionality and after being problematic for so long and causing image deffects it had eventually shorted completely and literally exploded.
Luckily, the short it had created was too short in time and apparently in a circuit that could take the load for a short while without getting damaged.
So after it blew everything worked just great!
it's a real story from my repair experience.
Hope this helps all consumers, DIY enthusiasts and competitors alike :-)
For more you are welcome to visit our site and read our tech repair blog at
http://www.coppelltvrepair.com
and
http://blog.coppelltvrepair.com .
Aug 26, 2007 | LG 42PX5D 42 in. Plasma HDTV
LG 42PX5D 42 in. Plasma HDTV Logo
315 people viewed this question
Computer Repairing
Computer Repairing
