Question about Hitachi Travelstar 5K100 HTS541080G9SA00 80GB 5400rpm 150MBps Serial ATA Serial ATA/150 I... (0A26924FT) Hard Drive
Unusable drive with bad sectors in drives service area
I have a travelstar laptop hd HTS5410 80 gb that has the "physicalbad sectors in the hard disk drive's service area" problem. How do I bypass that area to make the drive usable? It is not currently installed in a laptop but can connect to a machine externally via usb. I may be able to install it in a laptop and use hitachi's drive fitness test software but do not know if it their software will allow me to bypass the bad sectors. What do you reccommend? Thanks.
  • 432 Answers
I would temporarily attach it directly to your laptop and go into recovery console and do a chkdsk /r on that drive
see if that helps, if not then there are things you can do.
post back for more info
Posted on May 17, 2009
Hi I have a advent laptop with a Toshiba MK3263GSX hard drive. Windows has detected a smart disk error press F1 to continue, is the boot up message I get. Then when windows is running I constantly get a...
Well, you can run a check disk on unit - it will identify bad sectors and try to move contents to another good sector. The bad sector is marked as such and will be unusable in future. But if unsuccessful in reading contents, the program that the files belonged to may become unusable unless you reload it. If they were OS files the computer may become unbootable.
If errors are excessive the program will bail out and not complete the exercise. Generally, when you get bad sectors that is the beginning of the end - you just do not know when unit will die. It might last a long time, might die next day. So you gotta be prepared with backups for the eventuality.
Aug 25, 2017 | Toshiba MK3263GSX 320 GB SATA Hard Drive
ATA Hitachi HTS547564A9E384 Drive has 117325064 bad sectors. Ubuntu says to backup all data and replace the disk. Im using an HP Laptop and this started happening only 2 weeks after i bought it. Its an...
I'd take it back right away, sounds like the hard drive is going. There are things you can do to try and fix it, but I'd take it right back and get the seller to fix it. It also could be that the drive has come loose but odds are the hard drive is going. So copy all data that's important to DVD and take it back and have them replace the hard drive.
Aug 16, 2011 | Hitachi Travelstar 5k750 Hts547564a9e384...
I have an 500GB toshiba external hardrive,it still has 50G more space left..however when i tried to open it again..it wont open...it only shows the properties and said that windows cannot correct the bad...
There is no way to fix a bad sector. A bad sector is like a scratch on a cd that can't be fixed. You should run a program like "HD Tune", when you use a program what it does is it will read the disk and when it can't read a certain spot it marks it as a bad sector. After that the hard drive will move the data from the bad sector to a spare area of the hard drive. The spare area will store the data from a bad sector and will be usable like the old one. However if you get too many bad sectors you will run out of spares. When that happens your drive will crash.
You Can Try These Steps: Windows comes with a built-in hard disk utility software that scans your hard disk for errors and attempts to fix them.
  1. On My Computer, select the disk drive that you want to diagnose and repair.
  2. Right click on it and select Properties
  3. Go to Tools tab.
  4. Click on the "Check Now" button under "Error Checking Status".
  5. Depending up on your choice, choose either "Automatically fix file system errors" or "Scan for and Attempt Recovery of Bad Sectors."
  6. Then click on Start.
Jul 10, 2011 | Toshiba 640GB USB 20 Portable External...
Replacing laptop HD
Spend the money and go with a 7200 rpm drive, 160, 320, or 250 gb hard drives are all under 100 bucks these days.
Oct 03, 2009 | Hitachi Travelstar 5K100 HTS541080G9SA00...
HP Pavilion zv6100 laptop CMOS will not recognize the HD
You could have a faulty disk controller. Try inserting a different working hard disk into the HP and see if it can detect it in the BIOS. If not then the disk controller is faulty and this is a motherboard problem. A replacement motherboard may not be worth it, put your money towards a new laptop and put the hard disk into an USB hard drive adapter case and use it as an USB external hard drive.
Jul 15, 2009 | HP Computers & Internet
16 bad sector
Scandisk(or whatever) should mark those sectors as bad, thus preventing them from being used. But no, you cannot erase them, they are physical areas of your disk that cannot properly hold data. Bad sectors are not uncommon, and nothing to be alarmed about, but a loud hard drive is...
Mar 01, 2008 | Seagate (9W2892-337) 80 GB Hard Drive
What is the jumper setting to make this a slave
If it's USB you shouldn't have to mess with the jumper settings but here is a site that appears to have them for TravelStar: http://www.ontrack.com/jumperviewer/ If the drive is not showing up in My Computer make sure there is a drive letter available for it to use. You can right click on the My Computer icon, select Manage and then go to Disk Management and see if the drive shows up there and then assign it to a different letter.
Mar 30, 2007 | Hitachi Travelstar 80GN 60 GB Hard Drive
#1508 Bad directory buffer signature
Hi, if this is a fairly new installed XP you're probably better off: repartitioning, reformat and reinstall WinXP but this will delete all contents of the hard drive. If however there are a good number of critical/important files you would want to save/copy, there are two (2) ways of going about saving/copying those files but both involve access to a working computer. (1) remove your Travelstar 5K100 from the laptop and using a 44 to 40 pin adaptor, connect it to the working pc which should recognize it as another hd and therefore you can copy your files to that pc. There are many sites that explains how to do this. You can try Google search or http://search.techrepublic.com.com/search/laptop+hard+drive.html. (2) another method is to boot and run your OS from your cd. While this does not involve physically removing your laptop's hard disk, it might be a bit challenging preparing the bootable CD with an OS. The procedure is better explained at http://www.nu2.nu/pebuilder/. This will run your laptop although a bit slow however, you can access the hd and save it to a thumbdrive or if you have a lan to another computer. Please let me know if this works ok with you. Good luck and regards.
Mar 29, 2007 | Hitachi Travelstar 5K100 40 GB Hard Drive
Computers & Internet Logo
923 people viewed this question
Top Hitachi Computers & Internet Experts
steve morris
steve morris
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
