Question about Mitsubishi VS-60111 60" Rear Projection Television
60' Mitsubishi went blank showing black screen. Model WD60737
  • 126 Answers
SOURCE: Mitsubishi 60" Model VS-6047
going into shut down why well ther emay be couple reason bad voltage regulator no b+ relay bad or open solder joints call tv reair shop
Posted on Feb 19, 2008
Shuttle83
  • 1139 Answers
SOURCE: mirror on Mitsubishi DLP HDTV 60
Hello zero_x08, 1) remove the cover of the TV and find the light engine. 2) using canned air blow dust from the mirro assembly 3) test the screen by turning the TV on after the system has warmed back to room tempurature. This should clean the mirror Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Posted on Jun 11, 2009
dave1645
  • 834 Answers
SOURCE: I have a Mitsubishi WT-42311. Last week the
where you saw blue it sounds like your blue crt is shorting out could be just the video amp so
i would suggest you have a tech look at it for and estimate
Posted on Nov 25, 2009
toyladi3
  • 597 Answers
SOURCE: my mitsubishi 60" screen went black still have
The problem with your television is that the t-con board is bad. The t-con board is the board that is by the top middle on the main board of the television. Have it replaced and the television will be in good condition once again.
this does not have anything to do with your lamp, if it happens to be your lamp, the audio would not have worked.
You can fix this yourself or ask a friend who is technically able to assist you in doing the job. You will have to get a replacement t-con board, then you unplug the television, leave it for about 6 hours, for the high voltage to dissipate, because these televisions store currents that might shock you if exposed to some components in the television.
Then you, unscrew the television open, lift off the main panel of the television and you will see the t-con board on the top middle of the board. Disconnect it and reconnect the new one on it and the television will work perfectly fine once again.
Reassemble the television back together and plug it to a power source and turn it on.
Take care and good luck.
Posted on Jan 04, 2011
Slinteriors
  • 8617 Answers
SOURCE: picture tube for 60 in' mitsubishi it shows only a black screen but you can still hear it
ts will go into shutdown when a vertical issue is present but the audio will still continue to operate normally.
Posted on Apr 02, 2013
What is the correct part# for a DLP: Mitsubishi WD60737 60", Serial#139599 Made June 2009?
If your set worked well (no lines, maybe only white or black scattered pixels) before you replaced the DLP chip, then your problem could be that the DLP chip did not get seated properly or the cam screws were not tightened enough after replacing the chip. The DLP chip must be seated properly in its socket or else line and column lines will be seen. There is also the possibility that the DLP chip is defective or suffered static damage while being handled during the installation. Hope this helps.
Jul 11, 2016 | Mitsubishi WD Televison & Video
Wd60737 mitsubishi 60"
how long has it been since you replaced the Lamp in the unit
Oct 20, 2014 | Mitsubishi Televison & Video
My mitsubishi wd60737 has black 2 inch stripe
Try pressing along the edge of the frame surrounding the LCD. Look for a disturbance in the "black line". If that shows up, you have lost the bond from the electronics to the LCD. Try using a piece of inner tube between the plastic frame and the chassis where you pressed to hold the connection together.
Sep 18, 2014 | Televison & Video
Picture tube for 60 in' mitsubishi it shows only a black screen but you can still hear it
Apr 02, 2013 | Mitsubishi VS-50609 50" Rear Projection...
Mitsubishi wd60737. It will turn on. Remote does work. Sound does work. But, the video won't show. It just stays black. There is a solid red light when it is off. Tried to reset it and it still did the...
make sure u set ur output to AV u will find this on ur remote control or on front of ur tv set
in regards ur tv will not show a picture since ur last adjustment try to go to menu and follow instruction how to set the tv back to factory setting......this may give u ur picture back......if not call mitsubishi service centre and tell them about ur problem u have......i am sure they will help u
Nov 28, 2009 | Mitsubishi WD-60737 60 in. HDTV
Nov 24, 2009 | Mitsubishi WT-42311 42" Rear Projection...
Mitshubishi VS-6041 No picture, sound ok
It has been my experience with that model mitsubishi that the usual culprit is loss of vertical sweep. If the beams in the picture tubes stops moving up and down this is detected by the micro processor and the video is blanked, but the set is not shut down. The usual cause of loss of vertical sweep is bad solder connections on the deflection yokes or a failed vertical output IC.
May 27, 2009 | Mitsubishi VS-6041 60" Rear Projection...
Mitsubishi VS-60111 60" Rear Projection Television Logo
21 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
