Question about Kyocera Mita Office Equipment & Supplies
Mita dc 2155 error c62
My mita dc 2155 copier is blinking c62. It has done this in the past but then stopped on it's own. Now it's doing it again. Any ideas?
  • dzines May 18, 2009
    OMG... what strange instuctions! I will try it tomorrow. Thank you! Darlene
    President:
  • Kyocera Mita Master
  • 990 Answers
Hello sir;Follow the following steps to reset;
1, press "1087' "1087",
2, enter 45 then press print.
3, use zoom key to achieve a reading of "3", then press "print", "stop/clear"
Posted on May 18, 2009
How to add developer on a mita DC-3060 copier
This needs to be done by a technician as you can easily damage the drum!
Sep 26, 2013 | Kyocera Mita Office Equipment & Supplies
My copier mita dc 3060 showing error code c 210
Hello Manuel sorry for your machine to be in that stake but have you tried to check on that paper conveying motors because that error is for those lift motors try to go on your machine run this code
press status/job cancel
enter 1087*2 twice
enter 906 and then you will see execute
the you press start to see whether it will stablize
Sep 25, 2012 | Kyocera Mita Toner 37085011 for DC-3060 &...
MITA copier DC-2360, error code C610, fuser replaced. How to reset the error ?
IF you have corrected the problem that caused the C610 (broken fixing heater wire), then the error is cleared by turning the machine power switch off then back on.
Jan 07, 2011 | Kyocera Mita Office Equipment & Supplies
Hi, Epson Stylus c62 printer problem. Turn on printer runs through start up cycle power light and ink light (red) flash alternate. Not out of paper or ink. Help Please
The Epson website says that if both lights are blinking, "An unknows printer error has occurred." They say to turn off the printer and contact you dealer (whoever sold you the printer).
Before you contact the seller or EPSON tech support, I recommend going through all the basic troubleshooting procedures (if you haven't done so already):
1. Remove and reseat ink cartridges.
2. Turn off the printer
3. Turn it back on again and see if lights quit blinking.
4. If still not working, remove paper. Check thoroughly for jams (and remove, if necessary).
5. Turn power off and then back on again and if still not working...
6. Turn off again.
7. Unplug and replug all cables to ensure a good connection
8. Turn back on and if it's still not working, it's time to contact the vendor or manufacturer.
Hope this helps...
Steve G.
Nov 02, 2010 | Epson Stylus C62 InkJet Printer
MITA DC 1460 copier stops
try switching to "manual" exposure setting instead of "auto" call service to check sensor and process control
Jan 06, 2010 | Office Equipment & Supplies
Error code 260 for a MITA DC 6090
its a problem in your cooling and drive system... consult kyocera for an explanation of this code...
Mar 15, 2009 | Kyocera Mita Kyocera-Mita SCANNER RACK...
Mita error code
I think that stands for OPEN. Check to make sure that all the doors are closed. Right side, left side door, and also front door.
Hope this helps.
If you still have the OP message, then let me know and I will dig out my books and look it up.
Good luck.
Mac
Mar 12, 2008 | Office Equipment & Supplies
Error C63
That is the same as a Kyocera Mita DC 1470.
Error C63 is a fuser related error:
Broken fixing unit thermistor wire
• The fixing unit thermistor output voltage does not exceed 0.039 V DC within 7 s after fixing control has started with the fixing temperature remaining below 100°C/212°F (fixing unit thermistor output voltage: 1.71 V DC).
I can provide for you a full service and parts manual from Mita in PDF form for a nominal fee. Contact me for more info here.
Jan 07, 2008 | Copystar CS-2114 Copier
176 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Adorjani Laszlo
AAAA262430
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
