Question about The Singing Machine Audio Players & Recorders
CD DOOR STUCK ON SINGING MACHINE - The Singing Machine Audio Players & Recorders
Singing machine CD player won't play and blinks door?
can you here if the disc is spinning?
and what do you meen by blinks door?
Dec 11, 2016 | Audio Players & Recorders
Won't play the CD and the open cover door won't go off when you close the door
Normally in all CD players there is a little "pip" in the door that presses a S/W when you close it. this may may brokend
May 14, 2015 | Singing Machine The iSM1028Xa Pedestal CDG...
Cd door will only half open
Just bought a singing machine ism 1028 Karaoke Vision from Costco. It was a floor model and when We turned it on it only shows to flashing bars in the CD area. Won't play demo CD. Nothing else seems to come on either. I have tried to look for manual on line and am unable to find one. Not sure if i have hooked it up right or if I have all the parts. Help please.
Nov 13, 2009 | The Singing Machine DVD/CDG Karaoke System...
Same Problem: CD flashes 'door', but will NOT play CD
What do you mean by not ANY CD? Does it mean that you can play some CDs while others can't? If it can't play any CD at all, it might be that the sensor for the CD tray is not working. It is not recommended to change the sensor yourself. Since you have contacted the service department of the player, give them 2-3 working days to get back to you.
Aug 03, 2009 | The Singing Machine DVD/CDG Karaoke System...
Singing machine ism 1010
My machine has the same problem and I got the same response from the company. I discovered a quick fix. With needle nose plyers I removed the wire from the corner of the lid that holds the lid open. Without the wire, the lid remains closed and the CD will play. The downside is that its tricky to open the lid. I've been using the piece of wire I removed to gently pry the lid open. I think I will glue a knob or ribbon to the top of the lid to make it easier to open. This isn't a perfect fix, but it was quick & free and now I can use my machine!
Apr 21, 2009 | The Singing Machine Singing Machine SME399...
The Singing Machine - STVG-1008
sounds like the rom drive needs to be cleaned had a similar problem with a kareokee machine when i was 16 used electrical contact cleaner and some cotton swabs with a cleaning disc and it worked fine
Feb 18, 2009 | The Singing Machine DVD/CDG Karaoke System...
Singing machine SMG 301 problem
has a bad drive motor, not sure where you can get parts for these
Oct 19, 2008 | The Singing Machine DVD/CDG Karaoke System...
Display keeps saying door
When your site kicked me out and charged me twice, I through the singing machine away! that solved the problem.
Jul 04, 2008 | The Singing Machine SINGING MACHINE...
37 people viewed this question
Top The Singing Machine Audio Players & Recorders Experts
 Grubhead
Grubhead
paul
Are you a The Singing Machine Audio Player and Recorder Expert? Answer questions, earn points and help others
