Question about JBL Northridge E 250P Subwoofer
Won't power up
How to remove the amp
Power antenna
I was able to remove the antenna on a 1986 cadillac
deville many years or decades ago & don't remember
even having to loosen any fender bolts
The solution is to install a new one IF Avail
I remember the only issue was the wiring
I cut the & spliced the new antenna to the old
harness as I had access issue in the body,not
the problem you have removing it
I think you get it out from the bottom,the most
you would do is loosen the bottom of the fender
not remove it
Jul 16, 2013 | Oldsmobile Cars & Trucks
2001 ford taurus power draining new battery & new alternater won't work when cables are removed from battery
That suggests that the problem is in the harness, something in the connector or wiring is causing an open circuit. You will need to have the circuit tested to find the fault. Ford alternators have known connector issues & new aftermarket connectors are readily available at most auto parts stores.
Oct 25, 2017 | 2001 Ford Taurus
The yellow light comes on inside but the computer won't come on neither does it beep?
First remove any power cables and batteries(if laptop) from your system and hold down the power button for 15 seconds.
Plug the power cable back in & attempt to boot.
If this does not solve your problem then you will need to remove all non-essentials from your system.
If laptop, this simply consist of battery, ram, optical drive & any other removable bays or devices. Unplug all cables except the power cable & attempt to boot.
If desktop, you will need to remove any cables plugged into your computer except keyboard, mouse, power, video, sound, & network cable. Open the case & remove any PCI cards, except video cards, unless you have on-board video, unplug the data & power cables going to the optical & hard drives. Now attempt to boot. If you have no luck you can remove your RAM sticks & try again. If you get an error beep warning you about no ram then you might have a bad ram stick. If none of the above works then you may have a bad power supply or motherboard. Power supplies are pretty easy to test with tester or use a spare.
Jul 16, 2012 | Dell Computers & Internet
If my 1999 cadillac deville goes up to 232 degrees is it overheating?
Outside of radiator is most likely full of dirt,leaves,
bird feathers,etc.
Remove as many things as necessary, & use an air hose
followed by garden hose to clean radiator.
Could try a new thermostat & make sure spark plugs
& basic preventative maintenance is done
Change Power Steering,Trans & Motor Oils
Old fluids won't remove heat well
Jun 11, 2012 | 1999 Cadillac DeVille
Hp pavilion laptop won't come out of standby
See if this works for you.
Unplug the power, remove the battery. Wait 2-3 minutes. Plug the power in without the batter. Turn on the system.
I do this for fun & feedback not $$$
Jim
Oct 03, 2011 | HP Pavilion dv1000 Notebook
Power window will not roll up on passenger side of 2000 lincoln ls
Remove & test all door window switches that
operate that window
If they are good, then remove the inner door panel
& check for a broken regulator cable & if necessary
unplug & put 12V directly to the motor to test it
If you replace or lube anything, you will need to do a
Door Window Motor Initialization
You push window button to second detent & hold until
glass stalls into top run,then hold 2 more seconds
If you do not ,you won't have the one touch feature
Jun 24, 2011 | 2000 Lincoln LS
Rider loses power after mowing for 30 - 45 minutes. Gets to a point, it won't climb a small incline. Engine sounds good & the deck runs fine. Just won't go.
Hi, the hydrostatic drive is most likely over heating. Remove the battery and battery carrier, from here you can clean all grass and debris from the hydro cooling fins and fan. Hope this helps, regards Phil.
Jun 01, 2011 | John Deere Garden
1999 lincoln continental drivers power seat won't work
Could be any number of items related to the seat
power motor circuit
Start by removing & testing the switches
If modules are involved,then it will be beyond
your ability to diagnose ,without a trouble chart
Check any fuses that apply
If a fuse is blown,replacing it won't
likely fix the issue,only blow again
May 23, 2011 | 1999 Lincoln Continental
My woofer is 18' 600w rms power. so what is the
Basically you cannot break you woofer with too powerful amp, but you can break it using too weak amp. This is because if you don't have enough watts going to you woofer the cones movement isn't controlled properly. I'm usually using +20% to the woofers RMS and peak power. This will also make the amp last longer because you won't use it at it's peak performance all the time. If possible use manufacturer whose prising policy matches your woofers manufacturers, that way you won't end up with "2000w peak power" cheap amp with real output of 30w. and in the other end cheap woofer won't handle expensive amp with real 600w rms so well, you need to find a midlle way here. Hard to say without knowing the make and model of the woofer.
This is a taste question for some people, and I haven't build a system to match so powerful woofer ever in my life. But I'm pretty sure you won't go wrong with this one.
May 20, 2011 | Audio Players & Recorders
Hp nc4200 won`t start
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
If this did not work, try also disassembling the laptop & make sure that all main components are seated properly. Also make sure that all ribbon cables interconnecting the various components of the laptop are tightly connected.
Dec 28, 2009 | HP Compaq nc4200 Notebook
JBL Northridge E 250P Subwoofer Logo
44 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
