Beko wma765s washer error code 1L and flashing 1200 spin light washer completed wash but when went to load up again refused to start and 1200 spi n light flashing as well as flashing 1L in time remaining display
Main board fault.engineer says not worth fixing.sourced board and replaced myself cost me £50 but have seen it priced at £63 and £86 .got mine by phoning Beko spares. took 10 days tho.as not in stock
Posted on May 30, 2009
MY BEKO 765s washing machine, has stopped working mid load, on the display it is flashing iL but its smaller, it has also gone onto pause, and wont go on to start, also on flashing on 1200. This was a...
Hi if your beko 765s washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Dec 31, 2010 | Televison & Video
How do you reset a beko washing machine??
It's actually pretty easy. Try this: press and hold the start button in for 5 seconds.drain pump will start up.let it complete its routine (takes 2 mins or so).now the machine has reset.select program as normal and retry
Hope this helps
Dec 26, 2010 | Washing Machines
Beko WMA765S fills, stops, then drains and stops
i would think about replaceing the timer
Sep 09, 2009 | Washing Machines
Does not drain error code f2
There is a block in your pump, you have to locate it, dismantle it & remove the block. Plug off the wall first.
Mar 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
E30 error code
Error E30 is a motor drive problem. Would check motor brushes as most likely fault.
Thanks for using Fixya.
Dec 16, 2008 | Hotpoint Ultima WD72 Front Load...
Kenmore Elite washing machine won't complete a full cycle
its a error code for not enough water fast enoght or no water. check fill bibs are on and screens inside fill valve are clean if ok . make sure you do not have steel branded flow retrickers fill hoses it if so replace hoses. washer has to get a amount of water fast or it will code out
Nov 11, 2008 | Kenmore Elite 45986 Front Load Washer
Fridgidaire front load not starting
hi fourintow
sound to me that its the water inlet valves at the rear of the machine,they're the bits where your blue and red water hoses joint on to they are quite cheap and easy to install
Oct 28, 2008 | Frigidaire ATF6000ES Front Load Washer
Whirlpool Duet HT Front Load Washer- won't start
remove the plug of the machine from the power outlet and plug it after 10minutes and then check .
if the frontpannel screen shows any error codes or any lights flashing check out this link
http://www.applianceaid.com/frigidaire_frontload_washer5.html
also check out this link for more help
http://www.applianceaid.com/frigidaire_frontload_washer.html
thanks.
Oct 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Indesit washer dryer stops halfway through a wash....
depends on what lights are flashing this is your fault code
Mar 28, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
691 people viewed this question
Top Washing Machines Experts
