Question about Kenmore 47772/47774/47779 Electric Double Oven
Kenmore oven shows code f32 - Kenmore 47772/47774/47779 Electric Double Oven
I have a frigidair double oven and I get a f32 error code. What does that mean?
f3 is a bad sensor and 2 is for lower oven so f32 is a bad lower oven sensor
Nov 08, 2017 | Ovens
M# 911 4288816 s# OV609596Q showing a F-4 code...what does this mean?
F4 is an error code that flashes on Kenmore electric ovens when the oven's temperature sensor has shorted. You should check the wiring harness and replace the sensor if necessary.
Hope helps.
Rea
Jun 08, 2011 | Kenmore 41389 Electric Double Oven
After self cleaning my oven i have a fault code F32 what does that mean?
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Apr 17, 2010 | Miele H398BP2 / H398B2 Electric Double...
Error code shows E1 -F3- on a
F3 E1 IS THE OVEN SENSOR IT IS ON THE BACK WALL HELD IN BY TWO SCREWS IT LOOKS LIKE A ROD,MOST OF THE TIME YOU CAN PULL ITHE WIRES THROUGH OR YOU MAY HAVE TO DISCONECT FROM BEHIND
Jan 12, 2010 | Kenmore Ovens
Kenmore wall oven keeps showing error codes f5 and f3. Unit will not say on.
oven went into E2 F3 oven code while cooking a chicken and broil burner came on turned off oven but broil burner stayed lit, then had to unplug
Nov 13, 2009 | Kenmore 47702 / 47704 / 47709 Electric...
Kenmore oven showing an F3 and later F5
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Nov 11, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Oven showing F1
kenmore digital stove is clicking when cooking in oven
Apr 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore Ultra bake self cleaning oven is showing code E0 - F2
My oven will not stay on, when started to preheat it will come on for a few seconds and they it will make a beeping noise and the codes E0 F2 will appear. The codes stay on even if the oven is off.
Jan 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 47772/47774/47779 Electric Double Oven Logo
47 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
