Fagor washing machine error code f06
Hello, I fagor 2LF-013SX machine, error F6 what I do, thank you
  • 87 Answers
SOURCE: Whirlpool AWM 8023 -error F06
This erroe code means drive motor tackometer error Probably a bad motor or motor drive pc board or cable problems
Posted on Jun 08, 2007
SOURCE: LG washing machine error codes
I have today the same error code on model WD-11155FB. This code means that the speed of the electrical motor can no longer be controlled. The velocity sensor placed just behind the motor is probably damaged but it can be also the electronic board where is connected this sensor, or the wiring between these two items.
Posted on Aug 16, 2008
SOURCE: error code 43 on F& P washing machine
The micro switch or the lever that activates it seems to have been the cause of the Error Code 43. Have re-seated the switch in its holder and ensured the activating (out of balance) lever is moving freely. The switch appears to be OK and now it is all re-assembled, the Error Code 43 is gone. Machine is operating normally again.
Out of Balance Switch was located below the right hand side of the computer board (module).
Rgdz John T
Posted on Sep 20, 2008
aborcass
  • 2651 Answers
SOURCE: F6 Code
f6 communication error in ht emotor controll board, located in the lower left front of machine
Posted on Nov 07, 2008
richardsimpl
  • 230 Answers
SOURCE: Getting faulf code F06 on Whirlpool 6th Sense AWM 8143
Hi There
I have found what you looking for and i hope this help's yo. let me know.
F/06 Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Thank you for writing to fix ya.
Best regards Richard
Posted on Dec 12, 2009
Washer error F06 E01
The error codes F6 E1 for Maytag Maxima 6000 front load washer means that the MCU AND CCU are not communicating. You need to check the wiring and plugs to make sure they have a good connection.
Feb 10, 2015 | Maytag Washing Machines
What does and F6 error code mean on a whirlpool duette front loading washing machine mean and how do I fix it?
Error code F06 means Drive motor tachometer error.
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
1/ Check wire harness connections between the Drive Motor/Tachometer and the Motor ControlUnit (MCU), and between the MCU and the Central Control Unit (CCU)
2/ Check the Drive Motor
3/ Check the MCU
4/ Check the Wire Harness
Replace failed component or contact an authorized repair agent.
Oct 15, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Ho do I reset the whirlpool error codes f6
F06 Drive motor tachometer error The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
• Check wire harness connections between the Drive Motor/Tachometer and the Motor ControlUnit (MCU), and between the MCU and the Central Control Unit (CCU)
• Check the MCU
Replace failed component.
Whirlpool Duet error f6 Google Search
Sep 06, 2014 | Whirlpool Duet WFW9151YW 27" Front-Load...
Fagor oven has error code F06
I cleaned the smoke filter, took of the top cover, in front of electronics is the brown smoke sensor. I took of one wire off the sensor, started the oven (beware of not shortcutting anything) the f06 error message had disappeared. I put back the wire, mounted the top cover and the oven functions like new.
Nov 28, 2012 | Fagor 5HA-196 X Single Oven
Hi, my new FAGOR 2LF-013S has no problem fortunately, but i have questions. is it possible i connect the water hose to hot water mains ;if ok; does it lead to power consumption reduction, or any other...
some fagors have a built in water heater (not all) your manual should say so , even so I allways connect my machines to hot supply as yes it's less expensive to use domestic heater for water , the heater inside (if equipped) machine just boosts the temp for cleaner dishes
Sep 11, 2011 | Fagor LFA-013 Stainless Steel Built-in...
F6????
The F06 error code on the HE3 elite is a tachometer error. Per the tech sheet, it says to check all connections and continuity between the MCU, CCU and Drive Motor. The tech sheet says normal reading is at 6 ohms.
Apr 18, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
I have to buy a dishwashing machine,
go with bosch they are about the best made
Jan 28, 2009 | Fagor Dishwashers
Kenmore Elite he3t model 11045972404
POSSIBLE COMMUNICATION PROBLEM BETWEEN MAIN AND MOTOR CONTROLLER
Nov 22, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Not good washing
You are either not using enough of the wash chemical or you need a product like Jet Dri...what you are seeing is mineral deposits.  Make sure your water temperature is hot enough.  If not sure, use the cycle which heats the water.
Nov 15, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
