Question about Team International Hawk Talon V3 RC Indoor Helicopter
Saturn x bottom rotor not spinning - Team International Hawk Talon V3 RC Indoor Helicopter
Stantonst.150 turntable platter spins unevenly
Well, you have the rotor, which has above the conus where you put your platter on. But the rotor needs to be kept in space, so it can spin,
which offcourse in the is done by (too soft) bearings, but the bottom of the the rotor(which looks the same as the 'pin' where you put you vinyl on, just leans on a piece of metal, instead of a technics where it falls in a shaft too keep it is place.
You undestnd that the strength on the bearings of a st150 is much higher, especially when scratching. Besides that, the high torque works 0,2 sec and then an optocoupler samples the speed of the rotor. And it's easy:on the underside of the rotor ,there's a plastic round disc puled over the rotor and kept on his place by a plate and 3 screws, with on the outside just
Mar 29, 2014 | Stanton ST-150 Turntable
Top rotor will not spin
I have the same problem. I have two of these helicopters and just recently brought them out of the closet. On one of them, the bottom rotor spins but the top does not. On the other, it Ian the other way around. It seems like the shaft is not catching the rotors properly, anyone have ideas?
Dec 25, 2013 | Brookstone uControl Cloud Force RC...
Ir helicopter only upper wing spinning
Have a SATURN-X 2CH IR and the tail and the tail rotor will not spin? What can I do?
Dec 30, 2012 | Worldtech Devices World Tech 85618 2CH...
LG WM2455HW washer won't spin when loaded
The tub was slipping on the motor and when loaded would not spin. I noted when accessing through the back panel that the rotor bolt was loose, probably from the factory as the unit has been used less than two years. When I inspected the rotor, the plastic insert that is screwed into the rotor housing and provides the splined hole that fits over the splined shaft from the motor/stator, the plastic ridges had been destroyed. There are three screws mounting the plastic piece onto the rotor so it appears that the designers anticipated selling replacement for the plastic piece alone. So far this evening, I've only been able to find complete rotor assemblies costing $100+.
So, bottom line, your rotor may just be loose.
Sep 22, 2012 | LG WM2455 Front Load Washer
Stealth flyer ii bottom propellor wont rotate. any help on how to fix
Ya, I've got that problem too. I note that the bottom rotor spins without turning the gear inside the copter (I can hear the gear when I turn the top rotor. So I'm thinking that maybe the rotors plastic sleeve was glued to the shaft and that came loose. But I'm a little hesitant to put glue in there until I'm sure!
Dec 29, 2010 | Toys
Bottom spray arm will not spin. Water pressure is fine and no clogs. Any suggestions?
Nrmally the bottom arm is not controlled by a solonoid selection.so try and spin the rotor by hand. Does it turn freely? Does it strike any part of the tray? If no problem there,remove the bottom rotor and inspect the holes on both sides.it only takes one hole on one side to be blocked then the equalibrium is broken.(To clear, get to a tap and fill centre with water then quickly tap librally and remove the small parts of calcium that normally collect in the rotor.) When eventually all is clean, replace and test.
Sep 08, 2010 | Dishwashers
Please help....I replaced the front brake pads on my 07 Saturn Aura because there was a squeaking sound. I took the old pads off and there was plenty of meat left and the rotors look very good. I didnt...
check the dust shield that is behind the rotor. It should be attached to the steering knuckle. if it is bent and touching the rotor it will squeak. I would jack the passenger side of the car up and remove the wheel. Once you have done that try to spin the rotor. Try to get it to squeak. It may also be dirt on your brake pads. If it came back after a week it is most likely dirt. Try a couple cans of Braklean while you have it apart.
Mar 27, 2010 | 2007 Saturn Aura XR Sedan
Dishwasher is not draining during washing cycle. Water is always sitting at bottom of dishwasher pan. Also, when the draining cycle is going on the dishwasher (?) pump made a strange sound (not smooth...
Locked rotor on the bottom of the machine. If you remove the bottom plate of the dishwasher where the water valve and electrical hook up is the motor is right there. If the rotor on the motor is locked up the dishwasher will not drain.. If you take a screwdriver and spin the rotor on the back of the motor it may release the rotor. If it does not spin freely then you will need to replace it. Make sure to unplug the dishwasher before doing any repairs to it.
Hope this helped you some
Dave
Jan 12, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
Saturn Vue 2004 model
more than likely you have warped brake rotors. or lack of parallelism in the rotors. you can get them machined if there is enough meat left on the rotor or just buy a new set which isn't all that bad for that vehicle since it's a floating rotor. good luck
Aug 19, 2008 | 2005 Saturn VUE
Team International Hawk Talon V3 RC Indoor Helicopter Logo
16 people viewed this question
Top Team International Toys Experts
ray gallant
Are you a Team International Toy Expert? Answer questions, earn points and help others
