Detrola record player
Turntable is running to slow. How do I fix?
  • 104 Answers
SOURCE: Need free owner's manual for a Detrola record player Model KM837
unable to follow what is wrong.
are you talking about the tonearm or a lever at the power switch?
Posted on Feb 11, 2009
You have probably done this, but I had same problem on one I was given with no manual. I couldn't get the turn table to turn and by accident I move the arm to the right, away from record and it began turning. Hope that helps.
Posted on Apr 22, 2009
  • 547 Answers
SOURCE: vintage turntable turns slow for few minutes then speeds up,,,why
The tubes are only in the audio amp portion of the stereo, and have nothing to do with the motor that turns the turntable.
Most likely it's that the grease on the motor is old and gummy, but becomes less viscous when it warms up.
Posted on Jan 24, 2010
  • 15 Answers
SOURCE: HMV Radiogram Turntable run slow at the start,
you should check under the table.
if it's a roller drive there, you can use water to clean the roller rubber and the inside edge of the platter.
If it's a belt drive, take it out and measure the length and get a replacement belt of same length
Posted on Jul 27, 2010
kevin_getz
  • 1031 Answers
SOURCE: turntable starts out slow then seems to work fine
Just sounds like it's so old to the point that it's working on it's last legs...enjoy your time with it while it lasts.
Posted on Apr 30, 2012
Record player turntable runs too slow. How to troubleshoot?
If this is a belt drive turntable the belt might be in the wrong position or is slack due to wear.
Jun 12, 2017 | Audio Players & Recorders
Can i use a crosley stylus in my detrola km837 record player
Stylus will only fit into certain cartridges. You have two options here. You can look up the cartridge number and make on your Detrola. It should be on the cartridge somewhere. Then search for the stylus. Or you can remove the Detrola cartridge and fit a new cartridge and stylus. As long as the cartridge will fit into the arm of your deck, plus it's the right type - ie: magnetic if the old cartridge was magnetic! Or ceramic - again if the old cartridge was...
Then you can use any make or model cartridge you want. As the quality of the sound can be improved - albeit paying more money for it - by having a good quality cartridge and stylus, it might be best in the long run to change the cartridge.
Jul 15, 2015 | Crosley Audio Players & Recorders
How to fix flutter & wow on a Gemini 500 XLii direct drive turntable
Direct drive turntables have electronically controlled speed. If the records you are playing are warped (not flat) that will cause wow & flutter. If that's not the problem then you might try connecting the turntable to a different power outlet using a long extension cord. Failing that, the turntable needs repair.
Jul 30, 2014 | Philips gemini XL-500 II Turntable
Crosley CR40 playing 33 1/2 too fast? What can I do to slow it just a little bit?
I would get a vintage turntable and not a new one inexpensive one. The new record players do not last.
Apr 20, 2014 | Crosley Stack-O-Matic CR40 Turntable
My museum thomas series record player runs slightly too slow. How can I fix this??
Try changing the needle which runs on the record this is to do with clarity , makes a big difference and you get many types of needles
Dec 29, 2013 | Seth Thomas Pacconi Turntable
Lots of Turntable belts are very much universal. If they are the same size there's no reason to think it won't work on another make.
Dec 24, 2013 | Audio Players & Recorders
Detrola record player wont spin, even after moving arm to far right.
I suggest you lift up the turntable matt and see if you can see a belt, which has either broke or come off. You might need a new belt!
Mar 22, 2013 | Audio Players & Recorders
Can't get the record player to work on a detrola
Thank you for the solution of moving the arm to the right and wait for the click, now my turntable works and Keely Smith is playing and sounding great!
Apr 22, 2012 | Crosley Audio Players & Recorders
Feb 22, 2009 | Audio Players & Recorders
Jan 25, 2009 | Crosley CR248 Turntable
121 people viewed this question
 Grubhead
Grubhead
