Question about Goulds Pumps Plumbing
Should a goulds pump hook up to 240 volts be backed up with a double 20 amp breaker or 30 amp
Accurate Joe
  • 61 Answers
SOURCE: i have a 240 volt
No, as long as the heater on the label says 240 volts. You would hook up your 240 v to black and white wire
Posted on Nov 30, 2008
  • 83 Answers
SOURCE: convert a Flotec Flotec FP4012 pump from 110 volts to 240 volts
Here is a link to your manual.
http://www.flotecpump.com/pdf/FP745.pdf
Posted on Mar 30, 2009
shastalaker7
  • 1515 Answers
SOURCE: I do not know how to wire the plug box from my
Hi, I am not completely Sure what you mean, but will explain the connections. First, from your breaker box if you are trying to wire a 3-pole cord and plug to the breaker, you will be dealing with 3 wires, more then likely, Red -Hot, black-Hot, and white Neutral. If you have a 30amp 2-pole breaker, make sure it is off and red goes to one leg of the breaker, black to the other, and white to the ground or neutral buss bar. Each leg is 120 volts,=240. I am trying to cover all of the bases here for you. The plug it self has 2 brass colored connections for the 2 hot and 1- silver for the white. Maybe a ground, but doubtful. I hope this has given you some direction to go by. If you need more help or not sure, please leave a message for me so we can get this right for you. Let me know one way or another. Good Luck,
Shastalaker7
Posted on Nov 08, 2009
SOURCE: Astra Mega II
disconect the heatind element or elements on the live side and see if it still trips the 20 amp breaker. try that first.
Posted on Jan 03, 2010
  • 111 Answers
SOURCE: i have a cadet heater
heater shuld have lable telling what max draw is.the breaker protects the wire.short answer is yes, 12/2 will carry 20 amps
Posted on Jan 12, 2011
Try to hook up my welding to breaker panel how many breaker do I need and what size
Typically a welder is 240v requiring a Double pole breaker, the size would depend on the equipment amps or watts?
30 amps X 240 volts = 7200 Watts
Mar 16, 2015 | Electrical Supplies
I have 110 volts n each leg but not 220 across both why??
In a traditional North American residential electrical panel (120/240 volt, single phase), installing a single width or single pole circuit breaker, you would expect to read 120 volts from the breaker terminal screw to either ground or neutral. A double width or double pole breaker would provide 120 volts from either of the breaker terminal screws to ground or neutral AND it will provide 240 volts BETWEEN the TWO breaker terminals.
A single-width circuit breaker case that contains two handles is NOT a two pole circuit breaker (these are called "tandem" or "1/2 size" breakers). This is because a single width breaker engages only one "line" in the panel. A double width breaker will engage 2 "lines" as a triple width breaker would engage 3 "lines" of a 3 phase panel. A single wide breaker can not physically engage more than 1 "line" so it will never be able to pass 240 volts.
You must install a double width / double pole breaker to safely supply a 240 volt circuit / device.
Mar 15, 2014 | GE 20 Amp 1 In Double Pole Circuit Breaker...
I purchased a 7000W Westinghouse Portable Generator to back feed my circuit breaker box. The cable is rated to 30amps. Do I use a 30 amp or a 40 amp circuit breaker? Thanks, Mike
1) Match wire and breaker:
http://waterheatertimer.org/Color-codewire.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
2) 7000 watts divided by 240 volts = 29.1 amps.
30 amp breaker x 80% safe maximum = 24 amps.
This means you should use 8 gauge wire and 40 amp double pole breaker for 240volt
3) 7000 watts divided by 120 volt = 58.3 amps.
60 amp breaker x 80% safe maximum = 48 amps.
So use 70 amp breaker and #4 wire.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jan 30, 2013 | Electrical Supplies
Can I use the existing 40 amp double pole breaker?
Rule of live by: Each unit must have its own breaker. Cooktop needs 30 amps and a double oven needs 40 amps. Never combine the unit as the amps flow if too high can cause the wires to melt. I hope this helps. Be safe!
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Sep 13, 2012 | Thermador Ovens
Can a 240 volt outlet be ran off this breaker and can a 240 volt electric baseboard heater be wired to it or should i use double pole breaker?
You need 240 breaker:
Notice that your 240V breaker is twice as wide as regular 120V breaker.
Notice that both switches are tied together on 240V breaker, making this a double-pole breaker.
For more information about breakers and 120-240V circuits:
http://waterheatertimer.org/B220C.html
Jan 24, 2011 | Siemens 20 Amp Single Pole Breaker 120/240...
Purchased "Reliance Lowboy electric water heater"
The water heater has two 4500 watt elements.
However both elements are not turned-ON at same time
So the water heater is 4500 Watts
Volts x Amps = watts
Amps =watts divided by volts
Amps = 4500 Watts divided by 240 Volts
Amps= 18.75
So that says a 20 amp breaker ... except for the 80% rule
80% rules says for safety, your Amp rating should be multiplied by 80%
20 amp breaker X 80% = 16 amps
20 amp breaker is actually safe for just 16 amps, and your water heater draws 18.75 amps.
The calculation shows you need a 30 Amp breaker.
30 Amp breaker requires 10 gauge wire.
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html
Nov 02, 2010 | RELIANCE ELECTRIC WATER HEATER
GE 36 inch profile is on but is not heating up. I
Sounds as tho you are only getting 120 volts versus the 240 you should have. Your breaker needs to be at least 30 amp double pole rating. 240 volt
Jan 30, 2010 | Cooktops
A diagram of how to wire a 220 volt outlet from two 110 volt outlets.
You can't really do that. The two 110 outlets probably come for the same 'leg' of the 240. If you check them with a meter, there will be '0' volts between the two hot wires. So, they have the same 'potential'. You need a regular 240 volt circuit from a double pole breaker that is rated for the wire size that it's feeding. 20 amp-#12 ; 30 amp- #10 etc.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 01, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Plumbing Logo
55 people viewed this question
Top Goulds Pumps Plumbing Experts
Steve
Andrew Taylor
Andrew Taylor
Gil Shultz
Are you a Goulds Pumps Plumbing Expert? Answer questions, earn points and help others
