Question about IntelliTouch Communications Grace Digital Victoria Tunewriter Turntable ITC TWCDRW
Arm wont move
The needle arm won't move
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Same modle and turntable wont turn. any fixes?
Posted on Jan 19, 2016
Wiring for the arm head where the needle goes. Wires were unplugged by accident now not sure how to plug them back in. Rockola sybaris 474.thanks
Thee is a standard wiring connection for stylus cartridges. Looking at the rear of the cartridge, there are four connections. With the stylus point down, starting at the top left and moving clockwise:-
White wire - Left channel out (10 o'clock)
Red wire - Right channel out (2 o'clock)
Green wire - Right channel ground (4 o'clock)
Blue wire- Left channel ground (8 o'clock)
Alternately the connection arrangement could be in a vertical line with alternate pins staggered. In this arrangement looking from top to bottom it will be :-
White wire - Left channel out ( Top left)
Red wire - Right channel out (Second right)
Blue wire- Left channel ground (Third left)
Green wire - Right channel ground (Fourth right)
I hope this helps
Nov 24, 2017 | Music
No sound
Check to see if tone arm is in the correct position and did not get jostled out of place during the move.
Be sure needle did not get damaged.
Check to see if cartridge wires came loose during move.
Did turntable slip out of position?
Any cables come unplugged?
Any amplifier fuses blown or mechanism power supply fuses blown?
Aug 26, 2014 | Wurlitzer Rock-ola Jukebox
When we try to play LP records, the arm stops half way through the record and wont move any further so we cant listen to the whole LP. We always make sure we have it switched to the correct rpm.
If it's on ONE particular record, it may have a deep groove that the needle cannot move past. It could also be that you don't have enough pressure on the needle which you can adjust on the arm with a turn of the counter-weight (should be a knob on the other end from the needle)
Nov 01, 2013 | Akai Music
Tuner Won't Acknowledge Sound
Before turning the unit on, press the calib/batt button to check the battery condition.
The Fender AG6 only responds when the strings pitch is within a certain frequency range. If the guitars tuning is not within that range or if your installing new strings, first connect the guitar to the AG6 with a cord that you know to be in good working condition and turn the AG6 on. Then starting with the low E string (the thickest one), loosen the tuning peg to a point well below the standard tuning for that string. Then slowly tighten the peg as you strike the string repeatedly. When the strings frequency, comes within range you will see the 6E light glow and the needle will begin to deflect. When the needle reaches zero it is in tune. Do the remainder of the strings the same way then go back and recheck each a second time. If you have a tuning fork, you can use it to tune by ear then re-tune and maintain it with the AG6
Remember to always stretch then re-tune new strings several times.
If the AG6 does not respond even after checking the condition of the battery and the cord that connects the guitar to the tuner, the problem could be inside the AG6 with a bad connection on the board. Try moving the cord as you strike a string that you know is close to being in tune. Again a tuning fork would be helpful.
~DrewWatk
Jun 10, 2013 | Fender AG6 Automatic Guitar Tuner
Intimidator light wont come on
I have 6 of these in my lighting rig, and the most common problem has been a bad bulb socket. If your bulbs end up with corroded or blackened terminals, you should replace the socket. The black/corroded stuff can cause the connection to become intermittent, sometimes so badly it entirely doesn't work.
The other common problem I've seen involves a resistor on the circuit board that powers the light bulb. I believe it's R2 - regardless it's the only big one. It's value is .5 ohms at 3 watts. Be sure to use a flameproof resistor when replacing it, and most likely your fixture will light up again.
Dec 20, 2011 | Chauvet Intimidator 1.0 Dmx-600 512...
No sound coming out of speakers but lights moving on board
The Efx 12 has two outputs monitor out as well as mix out ( XLR sockets ). If the level bars are moving its an indication that the mixer is working. Have you tried headphones out as well as monitor out.
What is your amplifier and speaker setup- you have not mentioned it at all.
Even if any PFL switch is on you won't get sound out of the speakers.
PFL stands for Post Fade Listen and when any of the 12 channel PFL switch is on only the headphone out put will work.
May 18, 2011 | Soundcraft Efx12 - 12 Channel Sound Board...
Low sound an hum from turntable with cobra tone arm 1955 wurlitzer but when another source is plugged in to aux in works fine. What could be causing this? Changed all the caps in this unit.
Hi, I believe I know what's causing this-It sounds to me like you have an open ground somewhere between your cartridge and amp. A headphone cord should make an acceptable substitute for the original wire if exact replacement is unavailable. I have heard many a hum in my day. I think this helps, Good luck and thanks for asking FixYa, Prodzilla
Apr 19, 2011 | Wurlitzer Green Zenith Cobra Cartridge...
I have an Epifhone SG special, red When I play on the top of the neck the pitch can change up to half a tone. Only by picking a tone on the top it is is very sensibel. I noticed the arm moves a lot more...
You mention an "arm" but the websites do not show any "arm" on the SG specials... If you mean a bender arm, your guitar has probably been modified and maybe done so incorrectely. The problem sounds like one of "intonation" which has to do with the lengthwise positions of the saddles at the bottom although a hallf tone is a lot to be in error from this. Watch videos on YouTube about guotar setup or take iit to a guitar shop to have it setup correctly. You can DIY this.
Apr 01, 2011 | Epiphone SG Special Guitar Electric
I have no clue how to play a cd there... I mean, the radio is no problem, i can turn it off and on, can search for a prog, no big deal. but how do i start the turntable? maybe someone even has a manual for...
to start a turntable press Start button and put an arm with a needle across record, if there is no start button, just put arm across record - it should auto-start; to play cd put it in and press play (play button shoud be near the cd slot, together with stop, skip and others)
Oct 14, 2009 | Crosley CR711-BK AutoRama Retro Turntable...
Yamaha psr230 keyboard wont turn on
I was bird so I got on my yamaha won"t I c it and it don"t turn on
Oct 19, 2008 | Yamaha Full-Size Keyboard
IntelliTouch Communications Grace Digital Victoria Tunewriter Turntable ITC TWCDRW Logo
Top IntelliTouch Communications Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you an IntelliTouch Communications Music Expert? Answer questions, earn points and help others
