Question about Honeywell Programmable Thermostat Heater
Proper wiring for honeywell 6400 thermostat
I connected all wiring according ot the diagram. My question. I installed the red wire into the slot for R and left the jumper between R and Rc installed. Is this correct or not. My system will come on but switch from heat to cool in a few minutes even if I am in cool mode.
Need answer bad, hot a shell here in florida.
Ernie
  • bethmoore99 May 18, 2009
    I have a similar issue. My old manual system had a Y, G, W2, and R wire and I matched them to the new programmable Honeywell 5-2 thermostat connections as Y, G, W and RC per the installation instructions (leaving the last Rh connection blank). The fan worked great, but when I used the "Cool" setting it blew out heat! Do I have a wire crossed?? My system is electric.
    Help!
  • 148 Answers
Depending on how they had it wired originally but there could be a switch on the back of the thermostat for electric
Posted on May 17, 2009
Wiring diagram thermostats
Look at the base plate just below the w position. This is the correct placement for heat pumps.
Jul 25, 2014 | Honeywell TH6220D1028 FocusPRO 6000 5-1-1...
Hooking up a new thermostat honeywell rth7600 from a honeywell t8411r. we hooked up the wires as shown in the installation manual- we have fan but no cold air blowing out or it feels like the heat is...
apparently who ever did the wiring installation did not use the Proper color coding when they did the install. Now you must trace the wiring to the appliance and wire accordingly.
Oct 10, 2013 | Honeywell Programmable Thermostat Heater
I have a red and a white wire only. I am installing a honeywell thermastat rth111. The heater is an electric air forced one. Where do I connect the wires?
These are not enough for you to install this thermostat properly. You could try hooking red to R and white to W2/E, but an electric furnace requires 4 wires for modern thermostats to run properly. If there are more wires in the line then it's a fairly easy task for a technician to add proper connections in, if not a new thermostat wire will need to be put in place.
Sep 25, 2011 | Honeywell Programmable Thermostat Heater
I need to replace an old Thermostat that just has 3 wires coloured Red, Blue and Yellow. The Honeywell THR830TUK Thermostat I have bought shows 5 wires on the diagram. I'm not sure which wire goes into...
The honeywell THR830TUK thermostat does not require a neutral as shown in the instructions.Connect the LIVE to terminal "1" and your YELLOW SIGNAL wire to terminal "3".
Connect your EARTH (if you have one) to the EARTH connection on the top left hand corner of the thermostat and blank off your NEUTRAL wire with a block connector.These instructions were supplied to me by Honeywell Customer Support.Hope this helps.
Jan 08, 2011 | Heating & Cooling
I need a y plan wiring diagram
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Apr 22, 2010 | Honeywell Programmable Thermostat Heater
I am trying to install a Honeywell RTH2510 thermostat for my heat pump. The wires coming from the wall are red, white, green and blue. Where does the blue one go? My second question is what to do with the...
HONEYWELL WEBSITE:
Go to honeywell.com
Jan 08, 2010 | Heating & Cooling
Just installed the honeywell thermostat. the ac turns on, but not the heat. what do we do?
Some of the thermostats from Honeywell require a jumper wire on the thermostat between the RC and the RH connection for the heating to operate. It is possible that your installation needs this jumper wire installed for the heating to work.Verify that this jumper wire is installed if your thermostat requires it. If it requires the jumper wire and you do not have one you can cut a small piece of existing wire on the connections to make a jumper wire. There are also some thermostats with a jumper switch for electric heat and gas heat...make sure that it is on the proper setting.
Dec 02, 2009 | Honeywell Electronic Programmable...
Installing thermostat - extra wire?
you have to go down to your furnace and follow the thermostat wire ...it connects to a terminal strip or fan centre...the color doesn;t really matter...installers mix and match all the time....look at the furnace wiring and mark it down...Red on "R"...Green on "Y" whatever it is...and connect it accordingly upstairs...if you only have 4 thermostat wires downstairs you will need a jumper wire between RH and RC...if you have 5 wires you will see 2 wires on "R" at the furnace.,...and connect either to RH and RC at the thermostat
Nov 01, 2009 | Honeywell Electronic Programmable...
Wiring
red goes to RC and RH, White goes to W, Green goes to G and Blue goes to Y. iam assuming on the old tstat that Red whent to R White went to W Green went to G and Blue went to Y
Sep 20, 2009 | Honeywell Programmable Thermostat Heater
I had an old thermostat that i had to change need wiring diagram
HONEYWELL WEBSITE:
Go to honeywell.com
Dec 20, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
644 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
