Question about Birds
I put frozen pie in fridge instead of freezer 1day ago and it's thawed. Can I still bake it?
IFIXALL
  • 868 Answers
SOURCE: We have a Whirlpool gb22dk
1st.Check the freezer door gasket for any place it maybe torn or not making a 100% seal when you close the door.That would make temperature drop. 2nd.take off bottom kick plate so you can look under the refrigerator.Using a flashlight make sure there is not alot of lint / dust stuck on the coils .If there is remove it carefully and you will see temperature lower. PLEAS RATE THIS!
Posted on Jun 09, 2008
  • 142 Answers
SOURCE: FREEZER IS COLD BUT NOT FREEZING WELL,FRIDGE IS NOT AS COLD AS IT SHOULD BE
Your freezer fan has stopped working or jammed. It's also possible that your defrost timer has stopped working and that the airways in the freezer are clogged with ice and the air can't circulate to the fridge. One of the two. Good Luck!!
barneyluc
Posted on Oct 03, 2008
aasc
  • 1606 Answers
SOURCE: Ge Profile fridge
Pull the refrig out from the wall , and remove the rear panel . Touch the compressor and feel if its hot or running . If the compressor is cool , then the main control board is bad ( since the compressor isn't running ) . If you can solder , you can repair the board (another paragraph ) . If the compressor is warm , then you could have a thermistor or 2 bad . This would have to be checked by a technician , unless you know how to get into the diagnostics procedure . Also , see if the compressor cooling fan is working and the black squirl cage is clean of dust .
Posted on Sep 06, 2009
Testimonial: "Quick, professional response."
Sea Breeze
  • 4654 Answers
SOURCE: freezer is frozen fridge is warm
Your model is most likely the Profile Artica style. Most times the defrost heater is burned out behind the rear of the freezer wall. Manually defrost and look at the defrost heater to see if burned out. That model possibly has the glass covered defrost heater and will be easy to spot if burned out because the element is inside a glass tube, If you replace the defrost heater also replace the defrost thermostat, Please send me your model number located near floor of the fresh food compartment door seal and kick plate, Thanks Sea Breeze
Posted on Oct 02, 2009
Testimonial: "thank you , i will try it."
  • 942 Answers
SOURCE: fridge & freezer not cooling. Meat thawing
If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions: Is the refrigerator completely dead? If so, see “It's stopped completely.” Is the thermostat knob turned to the proper setting? If not, reset it.
Next, see if the compressor motor is running The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help. If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
The compressor The Thermostat The overload, relay, or capacitor The defrost timer The condenser fan motor
Posted on Mar 31, 2010
Can I freeze homemade cheesecake
No. the cheese base will "break" and have a weird texture. Cheesecakes keep for about a week in the fridge. If you need a smaller size, use 1 8 oz brick of cream cheese, 1 large egg and 1/4 cuo of sugar over a graham cracker crust to make 6 cheesecake cupcakes.
Apr 05, 2016 | Homemade Gourmet Pumpkin Pie Cheesecake...
Tip
Making more room in your freezer
Although plastic containers are certainly convenient for storing frozen foods, freezer bags can actually save room. Place your cooled soups, stews, or fresh fruits and vegetables in a zip freezer bag. Close the zip top almost all the way. Then gently press out the remainder of the air and finish zipping the top shut. Place your freezer bag on a flat surface such as a small baking sheet and place the sheet in the freezer. After a few hours, check the contents of the bag. If they are frozen, remove the baking sheet and stack your thin bags, saving space and saving time when you're ready to thaw the contents. Thinner items thaw in less time.
on Dec 02, 2010 | Freezers
2 hours ago I baked a double crusted vegetable pie in a glass pie pan... BUT I can't eat it & need to freeze it.
Wrap it in two layers of clingfilm and then two layers of foil making sure to fold down all the edges making it airtight. Freeze it as fast as you can in the coldest part of the freezer. We remove the ice trays which is where the blower is. Date it and label it and eat within 6 months. Defrost in the fridge for 24 hours and reheat in the oven to an internal temperature of 165'F.
I am a career chef :-)
Oct 12, 2015 | Kitchen Appliances - Others
2 hours ago I baked a double crusted vegetable pie (in a glass pie pan)... BUT I can't eat it & need to freeze it.
Oct 12, 2015 | Marie Callender's cherry pie, famous flaky...
I made an apple pie and froze it. How do I bake it now?
Bake it, frozen, at 350F. Keep an eye on it, let it cook until the juice comes out the holes in the top crust, cover the edges with foil if they're getting too brown.
It'll take close to an hour, stick with it and it'll be nice.
Don't thaw it before putting it in the oven, it'll make the crust gummy.
lp
Jan 09, 2011 | Ovens
Water line (inside freezer) is frozen shut
turn off the frige completly then let it unfreze for 1day or 2 and turn water off then turn back on and water should work,if my info was of any help please leave a comment,vote,note.thankyou
Sep 10, 2009 | Whirlpool GS6NBEXR Side by Side...
Fridge odor
There are a couple of methods to help remove odors from a fridge. The first is a cookie sheet with baking soda spread across it left in the fridge for several days. The other is something called Activated Carbon. Most stores sell it as a carbon odor filter and it is pretty cheap. It actually works better then the baking soda so I recommend you pick some up and just leave it inside the fridge. You can also put this behind your fridge or wherever you have foul odors. Hope this helps.
Nov 01, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Soda can busted in frost free freezer....need tips on how to clean frozen soda up
defrost freezer by turning off fridge. open freezer door, use a hair dryer on freezer compartment to thaw it out,(first remove all good frozen food to a cooler), then simply wipe up the mess. turn fridge back on and reinstall frozen food from cooler.(
Apr 02, 2008 | Refrigerators
Birds Logo
64 people viewed this question
Top Birds Experts
Tom Chichester
Are you a Bird Expert? Answer questions, earn points and help others
