Question about LG Goldstar GWHD5000 wall/window Air Conditioner
Does not cool
Runs but does not cool!
  • 148 Answers
Is the compressor coming on or just the fan if comp comes on might need a shot of gas
Posted on May 17, 2009
Norcold 6120 gas heats and electric warmer heats still doesn't cool has no ammonia smell
Only offering I have for a consumer is to run a "highpot" test on the cooling unit. This will bypass all the controls from the board and test the function of the cooling unit. Remove the leads from the board for the heating element and connect leads directly to 110 volts. Run for 3 hours to see if cooling is stating in the freezer. If cooling detected let run for 6 hours. So on and so forth. DO NOT RUN FOR MORE THAN 12 HOURS LIKE THIS!!!!!!! If no cooling detected in the first 3 hours the unit is "stopped up" and will have to be replaced.
Oct 04, 2015 | Refrigerators
Cooling fan inop 1995 mustang gt 5.o
you can check the cooling fan by disconnecting the plug at the motor and run jumper wires from the battery directly to the fan motor it should run if its working if it doesn`t run then the cooling fan motor needs replacing. if it does run then check the plug for a bad connection. other things can cause this like the cooling fan relay, the coolant sensor that sends a signal for the computer to turn on the cooling fan by sending a signal to the relay.
Sep 08, 2014 | Cars & Trucks
Why Refrigerator does not cool?
condenser fan must run if it is to cool. does compressor run but not fan. fan need to be replaced ... will not cool until it is fixed.
Aug 26, 2014 | KitchenAid Refrigerators
I meant the AC does not cool
Make sure the mode is set to freeze and temperature is set to below the room temperature.
If it is a split system, check the outdoor unit whether it is running. If it is running, see if you can reach and feel the temperature of the pipes connecting between the indoor and the outdoor unit. It should be cool.
If it is not cool, you may need to get somebody to check the refrigerant.
May 22, 2014 | Dometic 57915531 Air Conditioner
I just bought a 1995 jetta and it's running at 260 degrees. Is this too high, and if it is then what would be causing this?
CHECK TO SEE IF BOTH COOLING FANS RUNNING ARE RUNNING WHEN ENGINE RUNNING START OVERHEATING IF COOLING FANS NOT WORKING CHECK COOLING FANS LARGE FUSES IN THE ENGINE COMPARTMENT OR YOU COULD FAULTY COOLING FANS THERMO SWITCH BOTTOM LEFT SIDE OR RADIATOR.IF COOLING FANS IS WORKING WHILE ENGINE RUNNING.RADIATOR CORES AND HEATER CORE COULD BE CLOGGED.COOLANT SYSTEM NEED FLUSHING. THE THERMOSTAT PARTIALLY CLOSED CAUSE ENGINE OVER HEAT.CHECK WATERPUMP WEEP HOLE IF LEAKING WATER PUMP NEED REPLACING.
Jul 21, 2011 | Volkswagen Jetta Cars & Trucks
Cooling fan not running as temp. heats up.
most time coolant temperature sensor faulty.but check cooling fan fuse and relay.then hot wire the cooling fan if fan runs.problem in the fan wiring or pcm.if every thing else okay.if cooling fan dont run when hot wired the cooling fan need replacing fan motor has internal open winding circuit.
Apr 15, 2011 | 1995 Buick Skylark
Kenmore Electric dryer runs on cool down forever.
Call the mfr and ask them about it. This problem may be pretty complicated. There may be a problem with your board that tells it to go to cool down. Can you set the timer for 45-60 minutes and it stay on heat for that long?
Feb 11, 2009 | Kenmore Dryers
Kenmore refrigerator not cooling or freezing
my refrigerator suddenly stop cooling all the fans run normal. It makes a click Noyce.
Jan 11, 2008 | Refrigerators
LG Goldstar GWHD5000 wall/window Air Conditioner Logo
128 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
