Question about Sole Fitness Sole E20 Elliptical
Console no power - Sole Fitness Sole E20 Elliptical
Wii wont power on
Wii Console Won't Turn On, and Has No Power Light
Situation:
The Wii console won't power on, and the Power LED is unlit
The console powers on, but shuts off after a few seconds/minutes
Attaching an accessory to the console turns the power off
Information:
This issue can be caused by an accessory or power surge tripping the circuit breaker on the AC Adapter.
What To Do:
Check any accessories attached directly to the console to make sure that it is licensed and undamaged. Unlicensed or damaged accessories shouldn't be used with the console.
Try using a different wall outlet, or plug a different device into the outlet to make sure the outlet is providing power.
Oct 29, 2012 | Nintendo Wii Console
Wii won't turn on
Wii Console Won't Turn On, and Has No Power Light Situation:
  • The Wii console won't power on, and the Power LED is unlit
  • The console powers on, but shuts off after a few seconds/minutes
  • Attaching an accessory to the console turns the power off
Information:
What To Do:
  • Check any accessories attached directly to the console to make sure that it is licensed and undamaged. Unlicensed or damaged accessories shouldn't be used with the console.
  • Try using a different wall outlet, or plug a different device into the outlet to make sure the outlet is providing power.
  • Perform an AC Adapter Reset. (How To)
Situation Not Resolved:
If the system still won't power on, the system and AC adapter will need to be repaired. To start the repair process, click here.
Wii Console Turns On, But Has No Power Light Situation:
  • The power LED on the system does not come on, but the system still powers on and plays
Information:
If the Wii Console is still working normally, it is likely that the power LED is broken.
This issue will remain limited to the Power LED, and will not get any worse.
Unless the system is having other problems, continue using the console regularly for a few weeks to determine whether this interferes with the enjoyment of game play.
If, after using the system for awhile, the Power LED not coming on is too distracting, the Wii Console does carry a one-year warranty.
We are happy to inspect and, if necessary, fix the system at no charge within the warranty period. To start the repair process, click here.
function rvl_ts_sys_power_no_light_showsurvey(){ omnitureHelp("helpful_survey:rvl_ts_sys_power_no_light",JSchannel,JSprop6,"",""); } var req; var timeout; function rvl_ts_sys_power_no_light_psurv(a,sid,pid){ if (window.XMLHttpRequest)req = new XMLHttpRequest(); else if (window.ActiveXObject)req = new ActiveXObject("Microsoft.XMLHTTP"); if(a=="yes"){ document.getElementById("rvl_ts_sys_power_no_light_s_yes_button").innerHTML=""; document.getElementById("rvl_ts_sys_power_no_light_s_no_button").innerHTML=""; } else{ document.getElementById("rvl_ts_sys_power_no_light_s_yes_button").innerHTML=""; document.getElementById("rvl_ts_sys_power_no_light_s_no_button").innerHTML=""; } var url="/consumer/surveys/surveySubmit.jsp?a="+a+"&sid="+sid+"&pid="+pid; req.open("GET", url, true); timeout = setTimeout("techDif()", 5000); req.onreadystatechange = rvl_ts_sys_power_no_light_psurvr; req.send(null) } function rvl_ts_sys_power_no_light_psurvr(){ if (req.readyState == 4) { if (req.status == 200) { clearTimeout(timeout); var outString=req.responseText.substr(req.responseText.indexOf("##")+2); outString=outString.substring(0,outString.indexOf("##")); document.cookie='rvl_ts_sys_power_no_light=answered; expires=Wed, 28 Dec 2011 02:16:21 GMT+00:00; path=/'; document.getElementById("rvl_ts_sys_power_no_light_s_folowup_div").innerHTML=outString; } } } function rvl_ts_sys_power_no_light_techDif(){ //it broke document.getElementById("rvl_ts_sys_power_no_light_s_folowup_div").innerHTML="Thank you for your interest in helping us improve our content. It appears our survey system may be temporarily down. Please try again later. If you need further assistance, Click Here to contact us."; } function rvl_ts_sys_power_no_light_clearboxsurv(whatto,box){ if(box.value==whatto)box.value=""; } function rvl_ts_sys_power_no_light_fsurv(form){ var url="/consumer/surveys/surveySubmit.jsp?p=7" var reasonSet = false; for(var i=0;i-1)reasonSet=true; }else if(form.elements[i].name.indexOf("question2_answer")>-1){ url+="&"+form.elements[i].name+"="+escape(form.elements[i].value); }else url+="&"+form.elements[i].name+"="+form.elements[i].value; } if(!reasonSet){alert("To help us improve our content, please indicate why this page wasn't helpful");return false;} if (window.XMLHttpRequest)req = new XMLHttpRequest(); else if (window.ActiveXObject)req = new ActiveXObject("Microsoft.XMLHTTP"); req.open("GET", url, true); timeout = setTimeout("techDif()", 5000); req.onreadystatechange = rvl_ts_sys_power_no_light_psurvr; req.send(null) }
Dec 25, 2011 | Nintendo Wii Console
My wii won't turn on
Information:
What To Do:
Dec 23, 2011 | Nintendo Wii Console
I have 3 red lights on my x-box 360 RROD .Can this be fixed
  • Turn off your console.
  • Disconnect the power cord from the back of your console. Unplug the power cord from the electrical outlet and the power supply unit.
  • Reconnect the power cord to the console. Then plug the power cord back into the electrical outlet and the power supply unit.
  • Turn your console back on.
  • Jun 26, 2011 | Video Game Consoles & Games
    Power supply light stays orange and wont turn on the XBOX PRO. HELP!
    I hope this helps The power supply light is orange for one of the following reasons:
    • The console is turned off.
    • The power supply is not plugged into the console or the connection is not tight.
    • The power supply is not functioning properly.
    Note An orange light usually indicates that the power supply is connected to electricity and ready to power the console. When you turn on the console, the power supply light should change from orange to green. If your console does not turn on, please see the following Knowledge Base articles: 907588 (http://support.microsoft.com/kb/907588/ ) Your original xbox 360 console will not turn on
    2122656 (http://support.microsoft.com/kb/2122656/ ) Your xbox 360 S console will not turn onIf the console will not power on and you have tried the troubleshooting steps in the above article, your power supply will need to be replaced.
    Contact xbox Support to obtain a replacement power supply. For information about how to contact xbox Support, visit the following website: www.xbox.com/support/contact (http://www.xbox.com/support/contact)
    Jan 04, 2011 | Microsoft Xbox 360 Pro System Console
    I was playing MW2 online and the game cut-off and the console won't power back on. What can i do?
    Unplug the console video and power cables from the back of the console and the power unit from the wall and let everything sit for 5 minutes. I know, it seems like forever. Plug the power supply into the wall and give it a few seconds to get steady. Reconnect the power and Video/Audio cables to the console and to your TV. Cross your fingers if ya want and hit the power button. Hopefully, your console will come roaring back to life or at least power back up to a point where you can get error lights and you can diagnose further if necessary. If you have absolutely no power at all, try borrowing a friend's power adapter from their console and try it to see if that is the problem. Message me if you need more help :) and best of luck!
    Jun 19, 2010 | Sony Playstation 3 (PS3) Console
    Orange light flashing in powercell pack.console not turning on. tried different powercell pack still not working .used power surge adapter
    Hi,To troubleshoot this problem, try the following steps:
    Examine the power indicator light that is located in the center of the Ring Of Light on your Xbox 360 console. If there is no power to your console, the indicator light is off and the fans are off.
    * Press the power button. The power button and the power indicator light are located in the center of the Ring of Light on the front of your Xbox 360 console. If your Xbox is functioning correctly, the power will turn on.
    * Press the eject button on your console disc drive. If your console turns on when you do this but does not start when you use the power button, there may be a problem with the power button or the console faceplate may not be attached correctly. Contact Xbox Customer Support for more help.
    If the above step does not resolve the problem, examine the power cord where it connects to your console and to the power outlet. Disconnect and then reconnect the power cord at each end to make sure that you firmly connect the cord.
    If this does not resolve the problem, see whether the power cord is plugged in to any device other than a typical power outlet. For example, the power cord may be attached to an extension cord. If this is the case, remove this device and then plug the power supply directly into a power outlet.
    If the problem is not a connection problem, examine the light on the Xbox 360 Power Supply.
    * A green light indicates that the power supply is functioning correctly. If the light is not green, contact Xbox Customer Support for more help.If these steps do not resolve the problem, your console needs service.
    Thank you!
    May 11, 2010 | Microsoft Xbox 360 Console
    Ac adaptor blinking orange. Xbox360 won't power up.
    An orange light is illuminated on the power supply for one of the following reasons:
    • The power supply is disconnected from the console.
    • The power supply cord is not fully inserted into the power socket of the console.
    • The power supply is faulty.
    • The console is faulty. (The console might be faulty if it does not turn on when the power supply light is orange.)
    Step 1: Try to connect and then disconnect the power supply
    loadTOCNode(2, 'whattotry'); Follow these steps to connect and then disconnect the power supply:
    1. Turn off the Xbox 360 console.
    2. Disconnect the cord that connects the power supply to the console.
    3. Reconnect all the cords, and then try to turn on the console.
    if after this also your console does not power up then you need to check if you are seeing any flashing red lights on the power button of Xbox 360, if you see the red flashing lights then you would have to get your power adaptor replaced by calling up MS Customer Support.
    If you do not see flashing red lights on the console power button in that case the console itself would have to be send for repairs
    Please do rate my solution, Wish you Happy Holidays and Happy Gaming
    Regards
    KreativeGeek
    Dec 29, 2009 | Microsoft Xbox 360 Console
    Xbox 360 not powering up at all. power supply light blinks orange
    * The console is turned off.
    * The power supply is disconnected from the console.
    * The power supply cord is not fully inserted into the power socket of the console.
    * The power supply is faulty.
    * The console is faulty. (The console might be faulty if it does not turn on when the power supply light is orange.)
    The power supply has several built-in safeguards to help prevent damage to either your Xbox 360 console or the power supply itself. The power supply will automatically turn off if either the current flow, the voltage, or the temperature is too high. When the power supply turns off for any of these reasons, the light on the power supply will turn from green (normal) to orange or to red, or the light will turn off. When the power supply light is green, the power supply is working correctly. What you are experiencing is an over heating issue, that may have damaged the supply.
    With that being said, i would try to reset the supply by disconnecting the unit from the console, and unplugging the power supply unit from the wall socket for 5 minutes. Once the 5 minutes have passed, reconnect the unit to the console, and plug the power supply into the wall socket. If the console dose not power up, and the supply unit is still showing an orange illuminated operating light, this will confirm that the power supply unit will need to be replaced. Contact Microsoft for the correct replacement parts needed(power supply unit)
    TIPS FOR PREVENTING OVERHEATING ISSUES
    * Do not block any ventilation openings in the power supply.
    * Do not put the power supply on a bed, on a sofa, or on any other soft surface that might block ventilation openings.
    * Do not put the power supply in a confined space, such as a bookcase, a rack, or a stereo cabinet, unless the space is well ventilated.
    * Do not put the power supply on a stereo speaker, an amplifier, or a heat source such as a radiator or a heat register.
    * Do not use an unlicensed accessory, such as a replacement power supply that was not manufactured by Microsoft, or any accessory that plugs in between the Xbox 360 console and the power supply.
    * Plug the power supply directly into a working wall outlet. You may have problems with the power supply if you use an extension cord or a power strip if the extension cord or the power strip is faulty or cannot supply the required power to the console.
    * If you are not sure about the reliability of an AC power outlet, power circuit, or power cabling, do not use it. Contact an electrician.
    Oct 26, 2009 | Microsoft Xbox 360 Console
    No power
    Plug the console into a different power outlet. Or by a replacement power cord. If it still doesnt work, then chances are it is the console itself.
    Mar 28, 2009 | Nintendo 64 Console
    Sole Fitness Sole E20 Elliptical Logo
    46 people viewed this question
    Top Sole Fitness Exercise & Fitness Experts
    Art Wilson
    Art Wilson
    Level 1 Expert
    Electro Med Services...
    Ross Metcalfe
    Ross Metcalfe
    Are you a Sole Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
