Question about Nespresso Aeroccino Automatic Milk Frother
Nespresso UMilk not piercing pod and leaking water into tray - brand new machine one day old !!!
Water in tray pod not pierced
Richie_asg1
  • 1036 Answers
SOURCE: Nespresso Essenza D100 leaking water while brewing
Sounds like a gasket or seal gone or a split pipe.
If it's still under warranty - take it back for free service or replacement.
If you do have to attempt DIY, then a clear silicone sealant may save you the price of expensive gaskets.
Be very careful when taking apart - take notes or photos as it will help put it back together !
I usually put related sub-assemblies together with their screws in separate pots.
Posted on Aug 11, 2009
SOURCE: Nespresso Essenza C100 leaks all the water out
I have a nespresso type D90 which does exactly the same thing so it is probably not just yours
Posted on Feb 09, 2010
  • 1833 Answers
SOURCE: Nespresso C190 is not piercing the top of the
According to your problem first open the coffee container and clean it properly. After cleaning fill the container with proper quantity of coffee beans. May be the spout holes are blocked. So clean the spout by pin. Also make clean the infuser by open the front cover of the infuser. The ground coffee may be blocked in the funnel. Remove the ground coffee inside the funnel using a knife. Then clean the infuser and the inside of the appliance. Descale the machine. It will help you.
Posted on Jun 13, 2011
SOURCE: The pods are not being
The capsules are not pierced when they are inserted. They are pierced on the back but not in the foil. The foil is pierced when the hot water is injected through the posterior holes and the pressure causes the foil to bulge, thus getting pierced by the grid in the front of the machine. If the capsules are not getting pierced it means that the water is not being injected with enough pressure. This could be due to hard water deposits. Try first to pump the machine by turning it on and then lifting the lever and keeping it raised for a few seconds. If that doesn't work, de-scaling the machine should correct the problem.
Posted on Sep 16, 2011
  • 6 Answers
SOURCE: My Nespresso Magimix Citiz does
-the short term solution-
1. take your affected capsule. set it on its un-punctured/un-perforated bottom (the thin foil surface) on a flat surface. the three puncture holes should be facing upward on the top of the capsule. by the way, if you shake the capsule you should hear the grounds sound dry as if the capsule was new.
2. find a thin small rubber band. size-wise, ideally, the rubber band will fit loosely around your thumb; with a very small gap between the rubber and your thumb.
3. put the rubber band around the collar of the capsule. the band should be put over the top of the capsule and pushed down until it stops flush against the flange (rim). if the band is correctly placed, the band will be just 1mm flat inside the rolled bare aluminum edge (rim).
4. insert the capsule in your citiz machine as usual. optional: you can orient one of the puncture holes at 12 o'clock position (top dead center) during the insertion process. this time, it will work. you will find the capsule will eject cleanly with the rubber band intact.
5. save the rubber band.
-which machines does this apply to?-
this is a common problem with nespresso machines introduced after 2010, specifically the citiz. i have not seen this problem on the pixie, yet. i would expect this issue on the lattissima plus.
i am assuming that the machine is otherwise functioning properly: meaning that the machine does not have an issue with the water pump, excessive scaling deposits restricting water flow, or some other major mechanical part.
-why is this happening?-
look at the capsule, the post-2010 machines bite new slightly rectangular indentations on the capsule around the top edge of the wall. this is new. nepresso changed the insertion mechanism in response to competitors bringing non-nespresso branded capsules to market: Douwe Egberts/Sara Lee "L'or expressO", Caffe Vergnana "ESPRESSO", etc.
this new insertion mechanism was supposed to thwart knockoff capsules, instead it is unintentionally thwarting your "real" nespresso capsule. the injector needles are not piercing correctly all the way. the injectors poorly lodge: deep enough to make puncture holes but not deep enough to allow water to flow freely into the espresso grounds compartment.
two things can happen:
1. the pressure release valve, inside the brewing chamber which prevents an explosion occurring if the coffee exhaust path becomes blocked, is activated and hot water overflows into your used capsule basket.
2. the hot water flows outside and around the capsule and into your cup as clear hot water.
-what do i do long term?-
contact nepresso. get your machine repaired or replaced. this is a factory manufacturing defect that has nothing to do with you, wear, use, or hard water. refuse to pay the $125 repair fee. demand that they fix the machine free of charge. they will send you a loaner in a plastic shipping crate to use while your is being fixed. you should not have to suffer without espresso or waste legitimately purchased capsules just because nespresso is in a legal fight capsule copycats. this is not your fault.
Posted on Dec 26, 2011
The water does not flow through the spout. Can this be fixed or is it cactus?
YOU MAY FIND CACTUS IN THE GARDEN BUT YOU COFFEE MAKER NEEDS TO BE CLEANED OUT TRY CLEANING THE SPOUT FROM OUT SIDE WITH A LONG NIDDLE LIKE TO CLEAN THE CHANNEL PLUS RUN SOME WORM WATER TO MELT IT DOWN
Nov 14, 2015 | Nespresso U D50 Espresso Machine with...
The part that holds the water is cracked can I get a new one as its leaking
If it is Nespresso branded then contact them, check on Google. If it is another brand but using the Nespresso pods then contact the distributors of that other brand.
Jun 15, 2015 | Nespresso Coffee Makers & Espresso...
Coffee pod stuck in machine
These machines are designed to use only Nespresso capsules. The UMilk, particularly, is susceptible to jamming if so-called "compatible" capsules are used, as the capsule is pierced electroncally, not manually as in most of the Nespresso range of machines.
Hope this helps, Rob.
Apr 11, 2015 | Nespresso U D50 Espresso Machine Color:...
Why my nespresso c110 cofee machine will not pierce the top of the pod and thereFore no coffee.
Are you using genuine Nespresso capsules? Any other kind will cause the machine to malfunction.
Feb 13, 2015 | Nespresso Coffee Makers & Espresso...
My machine isnt working
I've had this issue a couple of times. The water just goes straight through to the drip tray and the pod doesn't get pierced. The first time it was fixed under warranty but the 2nd time Nesspresso wanted $150. I took the back off the machine myself (very easy, just unplug it from the wall, remove the 4 screws and unclip the back cover) and saw that the $3 flowmeter had been replaced at the first repair (it had a date on it which was after we purchased the machine). It's the white thing at the bottom right and very easy to remove, (Take a photo of it so you know which way it goes, then just pull off the electric plug, unclip it and take off the 2 water tubes). I couldn't see anything wrong but blew through it a few times and put it back...........its since been working perfectly for over a month now, (I think microscopic solids from the water supply can block it). The whole process shouldn't take more than 10mins.
Jul 21, 2014 | De'Longhi EN720M Lattissima Premium...
The pods are not being pierced and the coffee is coming out too weak. Help!
Aug 10, 2011 | Nespresso Essenza D100 Espresso Machine
My Nespresso Magimix Citiz does not pierce the capsules every time. I use only Nespresso capsules. I have tried to pass them through a second or third time when this happens but I have thrown too many...
Mar 02, 2011 | Nespresso C100/T-US-AERO Espresso Machine
Nespresso machine does not punch hole on the capsules after close
This problem is most likely being caused by air being trapped in the system. To fix this, please follow the following steps: -
- Turn on the Machine, ensuring there is water in the tank
- Wait until the light stops flashing and the machine is ready for use
- Lift the silver lever on top of the machine into the upright position
- Press the coffee button on your machine
- Push the silver lever back, away from you, and hold it in this position for 3 seconds
- Press the coffee button again to stop the water flow
This procedure releases the air blockage in the system and your machine should function normally again.
(from
Nespresso Club)
Sep 18, 2009 | Nespresso C100B Essenza Single-Serve...
Nespresso essenza problem
It's not supposed to make holes in the capsule until the water comes through. So, basically, when you put the capsule in, it pierces the capsule in three spots, on the top. The aluminum part will not pierce until you press the button and water comes through. If water is not coming through, then you can clear the air bubble by opening the lever on top of the machine, pressing the coffee button, and then closing the lever once the water begins to come through.
Jul 30, 2009 | Nespresso Essenza C100 Espresso...
Nespresso Aeroccino Automatic Milk Frother Logo
213 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
