Question about Universal MX-900 Remote Control
Controls only power and volume - Universal MX-900 Remote Control
How do you turn up the volume on hisense ledn32d33 without a remote
See if the set has volume controls on it. Some sets have a power switch and volume/channel controls on them.
May 29, 2016 | Hisense Televison & Video
Where is the volume knob?
Is there a power cord? If not the speakers just adjust volume from your computers volume control.
Nov 13, 2013 | Recoton Advent Advent Q2035A 20" TV
Where are the external controls such as volume and power on or off on this tv
According to Samsung touch controls for power, volume, channel, menu and input should be locate on front panel. Usually it is located on the bottom right side and look around outer edge of panel with a flashlight ( they hide them well).
Oct 15, 2013 | Samsung 40 UN40D6000 LCD TV
I have a MTS surround sound system and when i put the volume up the woofer turns off. whats wrong with it? and how can i fix that
Seems you are over driving the unit and causing it to overheat and the protective circuits are kicking in. U need a more powerful system to play at the volumes you want.
Aug 26, 2017 | Audio Players & Recorders
No low volume
known bug electrolytic capacitor+eeprom store, remove power+batteries and store min 1 week without power!!
Dec 03, 2011 | Sangean ATS 909 AM/FM/SW Radio
My comcast remote won't turn on or off my yamaha rxv365 audio receiver only controls the volume the code i put in was 30176
It controls the volume just fine. It's the power that doesn't work. I'm having the same problem with my Yamaha receiver. Different model. Multiple Comcast remotes too.
Apr 14, 2011 | Yamaha RX-V363 Receiver
Ilgk@gmail.comHad purchased Dell Desk top 580S C13 W7HB from Vijay Sales on 6th June 2010. Got it installed by a friend as I am a senior citizen needing advice on operations also. Generally OK but sound...
The speakers inside desktop computers (if it has one) are very small and do not produce a reasonable volume.
I suggest you purchase a powered stereo speakers and connect it to the audio out connector on the desktop computer. Powered speakers have better sound quality and adjustable volume controls as well as bass and treble controls.
Dec 15, 2010 | Computers & Internet
Orion TVD2710. Lost remote, can't change signal input
I would suggest you try to find a universal remote that has an "input" or "source" button and program that one to your tv. By pressing the "source" or "input" button, it will change the input to the tv. I hope this helps! -Der Strom
Apr 06, 2010 | Orion STV2763 27" TV
Can't find the hands free speaker button
In an increasingly hands-free world, the external speaker feature of cell phones has increased the usability of cell phonesmag-glass_10x10.gif in the car, public transportation and at work. The volume controls on the external speaker controls can be somewhat difficult to find and manipulate.
  1. Step 1 Make sure the speaker setting is actually on. If the speaker is turned to off, the volume you hear will be coming from the earpiece and will be very low indeed. Sometimes there is a button on a cellphone which you can simply press and hold to activate the speaker function. You will notice a difference immediately.
  2. Step 2 Check to see if you have external volume controls. On some models, there is a button or two buttons that adjust the volume of both the handset and the speaker volume. If you have these buttons, use them to adjust these controls while on calls. Remember that adjusting the speaker volume will subsequently adjust the handset volume once you've turned off the speaker mode.
  3. Step 3 Access the sound controls in your phone. If your phone does not have external speaker control, it can be accessed by adjusting the controls saved on your phone. Also, the main settings can be controlled even if you do have external controls. Phones are different, but in your menu of options, choose sound and sound controls. This should give you options for ring volume, alarm volume and handset volume.
  4. Step 4 FInd volume controls for all settings. If you wish yo have multiple settings for each function---alarm, calls and speaker---you should be able to adjust these accordingly. Search through the control options until you've found speaker controls. Choose the setting you desire and save the settings.
  5. Step 5 Using the main volume as a foundation, use the external controls (if applicable) to adjust the levels.
Nov 15, 2009 | Cell Phones
Gemsound power speaker pxa105
First,
Disconnect any input cables from the amp. Turn down the volume controls and disconnect the speakers. Power back on. If you still blow fuses with nothing hooked up, have the amp fixed.
If the fuse holds, shut down and connect the speakers, leaving the volume controls down. Power up and see if your fuse holds. If you have hum, an output transistor is most likely shorted. If you have no noise, SLOWLY turn up the volume controls and listen for the hum. If all is quiet, turn down the volume controls and connect your input cables and turn the volume back up. Noise? check your cables!
Mister Phil
Apr 07, 2008 | NAD C350 2-Channel Amplifier
Universal MX-900 Remote Control Logo
Top Universal Televison & Video Experts
JOHN TOPLISS
Are you an Universal Televison and Video Expert? Answer questions, earn points and help others
