Question about DKNY Watches
How do I start a new dkny 1444 watch - DKNY Watches
VOTIT
  • 2071 Answers
SOURCE: Replacement battery for DKNY NY1050
I found a "battery" website that had some suggestions that should be typical of any snap back case watch.
http://www.online-batteries.co.uk/whichb...
specifically they said that when you try to press the back on it must be flat (not one edge down as I had been trying) Put the watch face down on a non scratch surface and press with both thumbs evenly. If that doesn't work a press will be needed. If you have a vice a couple of blocks of wood to distribute the load on the front and back may work, otherwise take it to a jeweler with the proper equipment.
The thumb routine didn't work for me. I have a vice but figured many wouldn't so I tried something else first. I put the watch face down on a piece of wood. I found a small 2" long scrap of wood (3/4" x 1.5" approx) that spanned the back. I centered the back (aligned properly) placed the block of wood squarely and centered across the back and tapped the end of the block with a hammer. First try didn't work, second one did. I used a rubber mallet as the hammer but a regular hammer or other heavy object would work. The trick, I think, is to get everything lined up and square so the blow is centered and even.
Also, I'd suggest cleaning the back and the groove in the case and be sure the rubber gasket is properly positioned. This will give you the best chance of retaining the waterproofing. And remember to check that the watch is running before you do this. Some need to be reset (usually with a very small screwdriver or pin) after replacing the battery. There should be a small hole with some printing next to it. You may need a magnifying glass to see/read it.
Hope this may help you;
DON'T FORGET TO RATE:
Posted on Sep 06, 2008
escapement
  • 2334 Answers
SOURCE: replace the back of a dkny watch after replacing the battery,
For closing your caseback you need the man with very strong hands first, but it might not work as some casebacks can be closed using special tools only.
Before you visit the watchmaker, try this: first of all open your bracelet by taking out spring lug. This will make more space at the back. Then take watch caseback and check for groove in it. Align that groove with stem (pin going into watch movement) and deepen grooved caseback side as it should be. Then without turning caseback apply great pressure with both hands to the watch(from caseback and dial sides). If hands are strong enough, caseback should snap on into place.
In case if it doesn't work, find a piece of thick leather (wide mens belt will do) and place it on completely flat surface (table top). Place the watch face down on that leather, adjust caseback groove with stem again and try to press caseback down with both hands, only this time using your weight.
If all mentioned above doesn't work- you have to go to see watchmaker.
Good luck.
Arthur
Posted on Dec 17, 2008
disap1
  • 98 Answers
SOURCE: resize DKNY 1035 Wrist Watch band
Could be a number of different ways. Some newer watches have multiple clasps that make it easier for you to adjust it yourself. Check the bottom of the band for extra clasps.
Without seeing the watch I have no idea what type of links you have. I suggest taking it to a reputable watch repair shop and have them adjust it for you! It will save you the frustration of having to search for a small screw or pin if it should fall on the floor!
Posted on Jan 10, 2010
  • 2501 Answers
SOURCE: How can I get the DKNY Urban Face Watch NY1135
  • There is a store in London but their web site says that "all items may not be sold in all stores". You could try your local watch shop, who may be able to get the watch you want.
  • DKNY
  • 27 OLD BOND STREET
  • LONDON,
  • +44 207 647 9166
  • Posted on Aug 01, 2010
    SOURCE: I have a DKNY watch which has a slim rubber starp
    I found my DKNY watch ******** http://www.bablas.co.uk/watch-straps/dkny-watch-straps.html
    Posted on Jun 06, 2012
    I have a DKNY NY-1251 but i need the instruction to work it because it not working with new batteries. it was working but keeps on stopping
    If it is an analog watch and the second hand moves a few time then stops and sort of twitches then the watch battery (even though new) may be bad. If not the the watch is dead and needs repair.
    Jul 04, 2016 | DKNY Watches
    Hi. Can You replace a Crystal for DKNY ladys watch model NY-4609 Thank You.
    It is probably replaceable. Try to locate a watch repair shop or and jeweler who repairs watches. If they don't have one, then contact DKNY directly.
    Jan 13, 2011 | DKNY 1035 Wrist Watch
    Cam i get spare links for dkny clear links watch
    yes Dkny will give you free links for your watch if you need them . DKNY watches are made by fossil watch company, you can contact them at this telephone number# 1-800-449-3056 to have watch links sent to you.
    Oct 14, 2010 | Watches
    Steel mesh on strap is ravelling and cannot wear it
    Thank you for contacting FIxYa.<br /> You will have to contact DKNY on this or take back to store you got. I dont know how long you have had it. Most watches warranties do NOT cover bands. <br /> Contact at:<br /> http://www.dkny.com/contact/<br />Best regards.
    Aug 25, 2010 | Dkny Mesh Bracelets #NY3992 Watch for...
    One of the larger crystals on the strap has fallen off, where would I be able to find a new one? thanks
    If you are looking for just a crystal, I would check around with local jewelers/watchmakers. If you are looking for a strap, I would contact DKNY at this site:
    Good luck
    Aug 14, 2010 | DKNY Slim Crystal Bangle Watch for Women
    I-have-a-ny3715-watch-with-a-stone-missing.it-was-bought-in-new-york-last-november-i-have-the-reciept.i-have-tried-local-jewelers-but-they-cannot-fix-it.how-do-i-get-it-repaired-
    Your best bet is to contact DKNY to see if they can replace it for you. Other then that, I would try a local jeweler. Here is a link for the DKNY service center: http://www.dkny.com/contact/ Good luck!!
    Aug 12, 2010 | DKNY 1009 Wrist Watch
    Hi - I bought a DKNY NY1304 watch three years ago, and unfortunately my digital screen just broke. I was wondering if it is possible to replace it with a new device? The only information given for the...
    You have to speak to your nearest DKNY distributor - they might help you and carry out necessary repairs. Alternatively visit your nearest watch repair shop and ask if they can help.
    Jul 31, 2010 | DKNY NY1304 Watch for Men
    Dkny 1350 how to change day
    Hello. Contact DKNY customer service and request an instruction manual http://www.dkny.com/contact/index.php
    May 25, 2010 | DKNY 1009 Wrist Watch
    Watches Logo
    12 people viewed this question
    Top DKNY Watches Experts
    richie46
    bigdawg7299
    Are you a DKNY Watch Expert? Answer questions, earn points and help others
