Question about Fossil Ch2803 Flight Stainless Steel Watch In Black
Setting date on a fossil ch2863 watch - Fossil Ch2803 Flight Stainless Steel Watch In Black
  • 4 Answers
SOURCE: Setting time & date on Philippe Starck Fossile watch ph1080
hold the left, bottom button (marked ....) for a few seconds....then press the top right button (marked with 1 dot) to change between the hour, minute, date etc. use the bottom right button to advance the flashing number, and when finished setting time and date, use the bottom left button to stop the numbers flashing and return the watch to normal. hope this helps, this is also how to change the date for the other question asker (works on 2 other starck/fossil watches i have and i assume the controls are the same).
Posted on Dec 02, 2008
escapement
  • 2334 Answers
SOURCE: Setting the day on my watch
Try this: pull out the winding crown to the first click and change the date. Memorize which way the crown turns to do that. Now turn the crown in opposite direction and the day should adjust.
This solution wrks for most of the makes.
If this doesb't work - submit the make, model and all the writings on watch caseback.
Posted on Mar 15, 2009
SOURCE: Set time on Fossil DQ1138 Watch
Press and hold the SET button (it will read CHIME with a flashing on or off). Then push the MODE button - the top will be flashing 12-HR or 24-HR. Push the ST/SP button to toggle between the 12-HR to 24-HR reading. Push the MODE button to get to the hour/minute/second/year/mo-day/month/day value you want to change. Push the ST/SP button to increase the value, the RESET button to reduce the value.
Posted on Apr 04, 2009
digritz
  • 530 Answers
SOURCE: changing the date
Which Fossil do you own?
Analog Date Watch:
Date Setting
  1. Pull the crown out to position 2.
  2. Turn the crown either clockwise or counter-clockwise and set the date for the previous day. The direction that moves the date varies on different watch models.
Analog Automatic:
Time and Date Setting
  1. Pull crown out to position 2 and rotate clockwise to set time.
  2. Pull crown out to position 3; date will advance automatically. To set to required date, continue to rotate crown between positions 2 and 3.
  3. Push crown back to position 1.
Analog Digital:
Time and Calendar Setting
  1. Press and hold pusher A for 2 seconds to enter setting mode. Year will begin flashing.
  2. Press pusher A to select year, month, date, hour, minute, second, and then exit setting mode.
  3. Press pusher B to adjust digit.
  4. Press and hold pusher B to adjust digit automatically.
  5. If no pushers are operated for 30 seconds, setting will be returned to Normal Time Display.
These are the three most common Fossils. If yours isn't here please let me know which model you have and I'll get you the instructions.
Hope this helps.
Posted on Dec 12, 2009
  • 2501 Answers
SOURCE: how do I set the date on my Fossil AM 3108 watch
Try their web site. Go to http://www.fossil.com/en_US/shop/customer_care/static/fossil-customercare.html . You will find a set of instructions; choose the ones for your watch and download.
Posted on May 12, 2010
Testimonial: "Thanks for such a great & quick answer "davidtolond". You've been extremely helpful."
How to set or restart the fossil automatic ME 1030? Because the problem now is when the time turn at 12 at midnight, the date din turn..
sometimes during time set, the hands are set to change date at day time.
check it your date turns during 12 noon, if yes move the hands clockwise until you set your time and date on sync.
say you want to set your watch date:10th and time:10:15am
adjust your date at 9th
then move your hands clockwise until the date turns to 10th at the 12 thats the 12 midnight.
then continue moving your hands clockwise until you reach 10:15am
Dec 14, 2010 | Fossil MultiFunction Automatic ME1030...
Philippe starck with fossil ph-2006
Fossil Contact Information Main support number 1-800-842-8621
Email support webguy@fossil.com
hope this helps
Mar 25, 2008 | Fossil Philippe Starck PH1026 Wrist Watch
I cant adjust the date for my Fossil AM4205..help!
mcdevito75 here, If your Fossil watch has a winding stem it may have 2 positions, gently place a fingernail under the crown and lift as gently as possilble, this should allow you to adjust the date without having to cycle thru the 24 hours to get to the date you want. It may take practise but that first position should be there, Set the date to 1 day before the date you need, then set the watch normally the full 24 hour cycle to get the date you want, this way the watch date will set as suppose to at about mid-night for the next days date.
Aug 28, 2010 | Watches
My chronograph men's watch came without a manual. Where do I find a manual that discusses setting time, cleaning the watch, setting teh date, etc?
Philleo Stark are made by Fossil.<br /> <br /> Go to <a href="http://www.fossil.com/en_US/shop/customer_care/static/fossil-customercare.html">http://www.fossil.com/en_US/shop/customer_care/static/fossil-customercare.html</a> and you will see "watch instructions", ckick on this for download of the instructions. They are generic instructions, so you need to scroll down to find the one that looks like yours and download the file.
Aug 26, 2010 | Fossil Philippe Starck PH1035 Wrist Watch
Fossil bq 9011349908 cannot set date and day
mcdevito75 here, There are many versions of Foosil watch, If yours has a stem (winder) it"s 2 position, to set Day pull stem out and rotate the hands till the day appears, push stem in all the way, Now slip your fingernail just under the crown and lift stem to it"s first position this will allow the date to change. You can also visit Fossil Watch online at Fossil Watches.com or visit a small watch repair shop in your area for adjustment help.
Jun 27, 2010 | Bulova Watch
My me1020 came without instructions and i do not know how to set the date, min nor theday please help
Actually there is no instruction manual for ME1020 available on Fossil website except for how to replace the battery. When you try to match ME1020 model with the available diagrams, there is no match (4 eyes). To set the time, pull the crown out to the second position. Now set the min/hour hands. Date hand is linked to it so keep rotating the crown till the date is set is set correctly. Now remaining is the day setting. Notice that the day changes every 24 hour mark on the 24 Hour sub-dial, so cross this mark to change the day. Go reverse & again cross the 24 hour mark to get the next day. Repeat this till you get the correct day setting. Now your day is also set along with date & time!
Feb 14, 2010 | Fossil ME1020 watch
Changing the date on a fossil watch- how do you do it?
Analog Date Watch:
Date Setting
Analog Automatic:
Analog Digital:
Hope this helps.
Dec 12, 2009 | Fossil Watches
SETTING (DIGITAL) DAY/DATE ON THE FOSSIL JR9387
Follow this link and download proper instructions:
http://www.fossil.com/webapp/wcs/stores/servlet/StaticView?langId=-1&storeId=12052&catalogId=10052&page=Instructions&nav=custCareNav
Rate me, please.
Mar 24, 2009 | Fossil JR9388 Watch
Aug 08, 2008 | Fossil Philippe Starck PH1035 Wrist Watch
Fossil Ch2803 Flight Stainless Steel Watch In Black Logo
56 people viewed this question
Top Fossil Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you a Fossil Watch Expert? Answer questions, earn points and help others
