Question about Fossil Anadigi JR9121 Watch
I need to replace the batteries.
What type of batteries do I get. The watch is second hand and I don't have a Manuel or the original batteries
2 Suggested Answers
SOURCE: second hand and battery replacement on fossil
Fossil watches have an 11 year warranty. Any jeweler can replace the battery. If that doesn't solve the problem and you registered the watch or still have the receipt call 1-800-TICTOC1 for repair.
Posted on Sep 29, 2011
Rolex st6 23zuan original or fake??
This is the hint regardless of Rolex. Look at the second hand and watch the motion! Does it sweep or tick? If it ticks it is battery operated watch knockoff.
Rolex is a self winding watch thus the second hand sweeps does not click each second.
Aug 28, 2016 | Rolex Watches
How to change battery watche
Remove the back cover of the watch. You probably do not need a special tool to do this. The battery is likely right on top, held by a metal clip. Note the "polarity" and orientation of the battery, i.e., which end is up (take a picture, if necessary). Carefully remove the battery by gently prying up the clip that holds it in place. The battery type is engraved on it, and you will need to get a replacement of the same type or an exact equivalent. You could purchase one on-line or from Radio Shack.
With the replacement battery in hand, insert it back into its cutout within the watch mechanism, again gently prying up the clip. Make sure it's oriented the same as the original battery. Replace the watch back -- you may need to press down to make it click into place.
Sep 10, 2014 | Casio Watches
My gold Mickey mouse Lorus watch was opened a part damaged by the person replacing the battery. This is not a digital watch, but has nthe mouse with hands and a second wheel at bottom.
You are probably going to have to look for an identical watch for parts.You might try this site:
http://www.esslinger.com/watchparts.aspx?gclid=COCr3t2F9KUCFcIKKgodgiARnA which is parts for watches. I'd have a look on ebay as well for a watch that is not working. Of course it does depend on the part you are looking for. I am also wondering if the inner parts for another Lorus mickey moue watch might fit, but maybe you don;t wish to change it out from the original.
Dec 17, 2010 | Disney Lorus Out of Production Collectible...
Swatch Irony Battery replacement will not work
mcdevito75 here, I am thinking your watch ran fine before the battery change. It sounds like the new battery is not makeing good enough contact, you can try, removeing the battery and cleaning the contacts in the watch carefully with a Q tip, dip the Q tip in anything containing alcohol cologne, rubbing alcohol, perfume wet the Q tip good, then sqeeze most out of the Q tip as not too saturate the battery contacts, also clean the battery itself, the oil on your fingers could give it a poor contact on the watch. The stop watch section doesn"t take as much battery power as the second hand. You may also be able to jump start your watch also, You"ll need a needle and a magnifier glass, With the back off your watch, right in the middle of the movement, just below where the stem (winder) goes, you"ll just see part of a little gear, this is the hour hand gear, see if you can gently move that gear just a fraction, place the needle between the teeth of the gear and try to move it as gentle as possible then se if the gear will move on it"s own., be very carefull with the movement. Swatch watches are collectables. If you don"t feel comfortable doing the above, look for a small watch repair shop in your area for help.
Jul 17, 2010 | Swatch Irony watch
Sweep second hand sticking on colibri pocket watch. How can I correct. I just had battery replaced.
mcdevito75 here, This is a very common problem easily fixed, when the battery was change the repair prerson could have interfered with the seconds hand bending it ever so slightly so it hits the other hands or it became loose, return to the person who changed the battery, they"ll take the back off and fix that seconds hand. Remember this may be no ones fault so I don"t know about any extra charges for service on your watch. This is just my info to you.
Jul 02, 2010 | Colibri Swiss CSQ Pocket Watch
End-of-life indicator for Victorinox Night Vision II watch - I seemed to remember that the watch battery can be monitored through the red LED that blinks every 10 secs. when it is OK, if the battery needs...
Not a malfunction - just a dead battery. See the manual:
http://www.victorinox.com/medias/sys_master/timepieces_manuals/8800396705822/NightVision_II_ENGLISH.pdf
May 12, 2010 | Watches
The second hand of my Tissot watch T870/970 starts and stops.
Hello!
Absolutely astonished by this "solution" from escapement.
This watch is working perfectly - it is simply giving its "end of battery life warning".
Dec 20, 2008 | Watches
Tag Heuer 200meter Professional series
This is to let you know that the battery needs to be replaced.make sure that you use a watchmaker that can test and replace any worn case parts so that your watch will retain it's original design water resistance.
Donald McPherson
Certified Watchmaker AWCI
www.finewatchmaking.com
Oct 21, 2007 | Tag Heuer Link Automatic Chronometer...
Second hand skips
It's part of the design. this let's you know it's time to change the battery.
Don
Oct 11, 2007 | Seiko SLL003 Wrist Watch
Problem with second hand
I need to know what type of oakley is this .. i mean what model .. because they have different specifications..
Dec 26, 2006 | Oakley GMT OAK0531 Wrist Watch
Fossil Anadigi JR9121 Watch Logo
52 people viewed this question
Top Fossil Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you a Fossil Watch Expert? Answer questions, earn points and help others
