Question about CDV Software Blitzkrieg for Windows
Cant run blitzkrieg 2
3.7.16.4;3008
Please help
Change the compatibility settings of the .exe file that executes the game to an earlier o.s. That should work. If it is REALLY old, try DOSBOX
Apr 16, 2014 | CDV Software Blitzkrieg: Rolling Thunder...
Blitzkrieg will not work on windows 8.1
Blitzkrieg is a B***h of a game to get working on anything after XP
I own a copy myself and on windows 7 it runs really fast and the graphics are all over the place.
Unfortunately I dont think you can get it working unless you mess with the compatibility settings.
Nov 23, 2013 | CDV Software Blitzkrieg Anthology for...
Need Blitzkrieg II game disc key
Please purchase the product and support its developers in order to receive the activation key.
Jan 14, 2013 | CDV Software Blitzkrieg 2 for Windows
I'm interested in buying Blitzkrieg 2 but seeing alot of issues with vista is it safe to buy this
you need to run them in compatability mode for xp
HOWEVER not to worry. Right click on the game icon and select properties. Click on the compatibility tab and tick the box in the compatibility mode section. Select xp and click apply.Stat the game and hopefully it works.
Sep 30, 2012 | CDV Software Blitzkrieg 2 for Windows
When i try to play blitzkrieg 2, i cant play game as i get message saying error code 577 also that i need administrator privileges
error 577 is a registry error. The fix is easy, download and install PC Health Advisor. This free microsoft tool will fix registry errors. Do this first.
For the Administrator problem, you can right click on the shortcut and choose "run as administrator" and you should be able to play the game.
Feb 08, 2011 | Computers & Internet
I have tried everything, how can i run this program? I have windows 7 64-bit and i need help!! Any solutions?
This is an older game so it may not be possible, but there are a couple things I would try. I have linked to sites with a full description of what is needed for each suggestion.
Compatibility Mode and Set CPU Affinity:
http://techpaul.wordpress.com/2009/06/28/compatibility-tricks-for-old-programs-new-machines/
http://www.sevenforums.com/tutorials/316-compatibility-mode.html
patch your game:
http://www.fileplanet.com/124619/120000/fileinfo/Blitzkrieg-v1.2-Patch
A quick search found other users who got Blitzkrieg to work, but I found none that were using Win 7 64 bit. 64 bit versions of windows seem to have more compatibility issues with older software than the 32 bit.
Assuming you have tried all of this, you might consider a dual-boot option for Win XP, or get an older PC for this and any other Win XP games (that don't like Win 7). I have found several of these.
Jan 29, 2011 | CDV Software Blitzkrieg for Windows
Why cant i install blitzkreig game on my windows 7 pc is it compatible
try installing your game in compatibility mode.
Running from a disc:
right click on disc>open>(find the installer for the game usually installer.exe)>right click on the installer>properties>compatibility tab>(click the box to run in compatibility mode and try running your software with XP SP3).
If you are installing from a file then just follow the same steps, find the installer in the downloaded folder...............
Dec 23, 2010 | CDV Software Blitzkrieg for Windows
Blitzkrieg wont load on xp
If the game has been istalled successfully,on desktop right click on the game icon, select properties, switch to compatibility, then select run this program...... then select another OS.
Jan 06, 2010 | CDV Software Blitzkrieg for Windows
CDV Software Blitzkrieg for Windows Logo
49 people viewed this question
Top CDV Software Video Game Consoles & Games Experts
James Wishart
comandomcl8
Level 1 Expert
Bill Boyd
Are you a CDV Software Video Game Console and Game Expert? Answer questions, earn points and help others
