Question about GE Microwave Ovens
Have a GE Turntable Microwave oven JES1246BH002 which does not heat or cook.Have a GE Turntable Microwave oven JES1246BH002 which does not heat or cook.
Have a GE Turntable Microwave oven JES1246BH002 which does not heat or cook. The light comes on and the fans work,its not loud or no unusual sounds. We do not have instruction manual for it and do not know if this problem has to do with programming the microwave(?). Please assist as to solving the cooking problem and where we may find instruction manual for it. We looked on web and cannot find a copy. Thank you.
jsrock516
  • 5911 Answers
SOURCE: Maytag Rangehood Microwave Loud Humming
Sounds like you just fried your magnetron. Normally when they go bad, they make a very loud noise like what you described. The smell concerns me because you may have ruined the waveguide as well. If the magnetron burns through the protective painted surface of the waveguide, the waveguide is ruined. In most microwave ovens this means replacing the entire unit because the waveguide is not replaceable. Putting a new magnetron in a damaged waveguide will result in the same arcing and eventual failure. In addition to the magnetron, the following components are part of the same high voltage network: HV Transformer HV Diode HV Capacitor Magnetron Thermal Cut-Out Any one of these components could have also been damaged. I DO NOT recommend taking any voltage measurements inside the HV network. Potentials of over 4000 volts can be reached and make it very dangerous for the do-it-yourselfer. Taking resistance readings with the unit unplugged is strongly encouraged. If you decide to pursue a repair, inspect the magnetron tip and inside of the waveguide first. If the magnetron is melted and/or there are burn marks inside the waveguide, a new microwave may be a in order. This actually may be a better option than an expensive repair. I hope you find this advice helpful.
Posted on Jul 31, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: sANYO EM-D9550. Turntable turns when off but not when cooking.
That's sounds pretty strange!
Since I don't have any service data on Sanyos, I'd have to speculate.
I would guess that one scenario that could cause it would be if the turntable were turned off via the control panel, but there was a switch or switch mount problem.
I would refer you to their support people:
http://sanyoservice.com/
Posted on Dec 08, 2007
SOURCE: GE Spacemaker Microwave JVM165OWB005--No more heat!
If you look at consumer affairs.com, there are many problems like this with GE microwaves. Not a good track record, experiencing problems with mine as well.
Posted on Apr 15, 2008
  • 140 Answers
SOURCE: Ge microwave model JVM1190WY buttons work but does not cook
The problem you are having with your microwave is a common one. Not heating is a problem that can be caused by three things. I'll list the most common solution first, the magnetron that actually does the heating is what is making that noise and has gone bad. It is possible for you to also have a bad high voltage diode that has opened up, solution two, or solution three is the high voltage capacitor is not working properly as well. From my experience with microwaves I am positive that it is your magnetron that is bad. If you are not do it yourselfer you'll need to take it to a repair shop to replace. However, if you know how to use a screwdriver and can unplug a couple of wires with spade terminals on them, then you can take it off yourself, find another one and replace it the same way you took it off. The magnetron sits behind the control panel of your microwave but on top. It has cooling fins on it and has 2 terminals maybe three depending and make and model that plug into it. It has 4 screws that are easy to get to that actually holds it in place. If you do not have a good local source like an electronic parts supply place then you can find the right magnetron at www.mwoparts.com. Be sure you always unplug the microwave before touching or trying to take the he cover off and then when you take the magnetron off also.Good luck and God bless.
Posted on Feb 11, 2009
  • 92 Answers
SOURCE: GE Microwave oven vent fan not working
You are correct the fan motor is either stuck or needs replaced.
There is no way to do this without removing the entire microwave. In case your not familiar with how microwaves work, there is a capacitor that is very large inside and can hold a charge even after it is unplugged for up to 24 hours, please take action to prevent getting shocked.
Posted on Sep 11, 2009
GE microwave not heating, sensor error.
first suspect is the inverter board (power) and magnatron a distant second----in either case the part involved unless an expensive unit is pricey.
Aug 26, 2012 | GE SpaceMaker Microwave Ovens
GE Spacemaker XL1800 Microwave
see for the turn table obstacle of any screw or something else.
Aug 04, 2008 | Samsung MW1030WA Microwave Oven
I have a GE Spacesmaker model #JVM1440BH04 that came on by itself and can't be shut off unless the door is opened. It does not seem to be cooking since nothing heats up unless the cook start buttons are...
The problem is in one of the door switches, "it is defective" this is a highly dangerous situation and should be checked immediately, the microwave oven should unplugged until a appliance repairman looks at it.
Jan 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave will run, however will not heat / or cook anything. Also the turntable does not turn.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
uofiotup
May 22, 2010 | GE JES1456 Microwave Oven
My JVM1653 stopped cooking, The turntable turns
your magnetron might be out. its what heats
Feb 13, 2010 | GE JVM1653 Microwave Oven
Went pop 20 seconds into cooking clock still works turntable stills moves won't heat
Remove the cover and look for a blown fuse. If found, replace the high voltage diode and the 'stirrer' (a fan like device that is inside the sheet metal wave guide near the area where the microwave energy enters the cooking cavity).
Oct 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave won't heat or cook - one year old
More than likely the magnetron has failed. This could be for a number of reason. Do you use your microwave to heat wheat packs or warm plates? If so, you may have dried the magnetron out (they use the moisture in whatever you're cooking to heat it, and plates/wheat bags have no moisture).
I'd say a trip to your local Microwave repairer could be in order. It could also be the High Voltage Fuse which has failed. Either way a repairer will be able to tell you!
Mar 25, 2009 | GE Profile Spacemaker Over-the-Range...
Microwave oven does not heat anything. Clock, turntable, lights work. I turned the turntable off while the oven was cooking--heard a noise, now it doesn't heat anything.
Spacemaker XL 1400 worked for 7 years.Yesterday, no more heat. Also plastic door damaged.
will try Panasonic or something commercial
Jul 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Apr 15, 2008 | GE JVM1650 1000 Watts Microwave Oven
Microwave Ovens Logo
144 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
