Question about Norelco Advantage 6735 X Electric Shaver
Need replace paets for Advantage 6735 x
Need replace parts for Advantage 6735 x
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
Find battery for
battery for model 6735X can be found at shaveroutlet.com using the link below
http://shaveroutlet.com/shaver-battery-pack-for-most-norelco-more-p-278.html
Jun 25, 2014 | Norelco Advantage 6735 X Electric Shaver
How to install new shaver heads on the norelco 7325 xl
You will find a general instructional video at shaveroutlet.com. See link below
http://www.shaveroutlet.com/philips_norelco_heads_replacement
If you need the replaement heads, you will also find them at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-hq8-spectra-sensotec-replacement-heads-p-251.html
Dec 04, 2010 | Norelco Advantage 6735 X Electric Shaver
Hi My name is Tony Di Cicco I purchased a Livietta T2 Espresso Machine on May 20th/09 and as I was cleaning the Filter Screen I discovered thhat the Adaptor Disc is all cracked, need I to order this...
Hi, Is the machine still under warranty? If so you may consider bringing it back. Otherwise they sell paets on the Pasquini site -- not sure the one you are looking for is there but you can also contact them. http://www.pasquini.com/ Hope that helps.
Sep 14, 2010 | Pasquini Livietta Espresso Machine
Norelco 6735X shaver:batteries replacing. I removed the 5 screws but the back case remained not removable. How to get to the mounted batteries? Thanks, Guido
If you have removed the 5 screws the back cover will come off. There are seals that make it fit pretty snug. You will need to gently pry the back cover off.
You will find batteries for this model at shaveroutlet.com. See link below
Apr 12, 2010 | Norelco Advantage 6735 X Electric Shaver
I need to know how to remove the battery from a norelco mod #
To get to the batteries, you will need to flip up the lotion packet cover on the back and remove the lotion packet if there is one. You will see four screws on the back. Remove these to take off the back of the shaver case. Once this back case is removed, you will be able to see the battery pack. The circuit board can be lifted up slightly for better access to the batteries.
To replace the batteries, you will need to do a little soldering. For easy replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather that removing them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can them solder the tabs from the new batteries to the old existing tabs.
Batteries for this shaver can be found at shaveroutlet.com. See link below.
Feb 22, 2010 | Norelco Advantage 6735 X Electric Shaver
I have excell 3700 pressure washer...the pump cover vibrated loose lost oil and cam melted.how do i get parts and change pum cam?
When you get down to it, purchacing oil end parts for a pressure washer is not cost effective.
The crank(cam) shaft runs about 280.00 dollars. The oil seals, new bearings, possibly new pistons and almost definatly new seals would be at least a hundred more. You can get a new pump for about 400 dollars and won't have to do all the work.
Dec 18, 2009 | Psi PowerBoss 20262 Pressure Washer
Have a lanier 6735 with an ''A1''Code
Hello sir; A-1 code means discharge corona cleaner problem, check it up may be the cleaner not function right.
Oct 16, 2009 | Lanier Office Equipment & Supplies
Norelco Advantage 6735 X Electric Shaver Logo
121 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
