Question about DeLonghi De'Longhi Energy Star174; Approved 40 Pint Dehumidifier - DE400P Dehumidifier
Delonghi dh400p dehumidifier error e1 with ice
Our dehumidifier had an error code e1, felt warm, and wasn't taking the humidity out of our basement air. I removed the cover to the filter area (5 screws) and found a wall of ice. I used a hairdryer to melt part of it away. It wraps around the tubing toward the back. How do I fix this? I really need the dehumidifier to get the musty dampness out of the basement.
Thanks!
  • jfowler10 May 17, 2009
    I cleaned the filter and the area on the coils around the sensor. It still has E1 error.
  • jfowler10 May 18, 2009
    Unplugging it for 15 minutes didn't help. It still has E1.
    Scholar:
  • 104 Answers
The condensation drain is being blocked from draining....kinked hose or lint...the symptom is cold air being blown across. If you left it unplugged...defrosted and works...check the drain on maintenance schdule
Posted on Mar 26, 2011
  • 148 Answers
Was the filter dirty that will do it let it defrost and put it back on
Posted on May 17, 2009
  • Jason vangel May 17, 2009
    it may be just a reset even unplugging the unit for a few minutes and plug it back in
I've misplaced the owner's manual on a DEN 500 P. What is a good basement setting for Summer in Central Ohio? Is a manual available on line?
I bought a cheap digital humidistat at Walmart to keep an eye on the humidity in my basement. I hung it on the wall not too near my dehumidifier. I have found that the settings on the dehumidifier are misleading, but I found a setting that keeps my humidity between 40% and 55% (at around 70 degrees), as measured by the humidistat.
Jun 04, 2012 | DeLonghi DE500P Dehumidifier
Unit is about 5 years old - 40 pint unit (DN40G). It runs but does not dehumidify (no water in the tank) and humidity in basement is 80%. I wonder if the unit is just too old to work? Do you have any...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Aug 06, 2011 | DeLonghi Dehumidifiers
Delonghi DH400p dehumidifier running but not collecting any water ? Humidity is 68 set to 50???
Hey, I had the same thing with mine.
First, try cleaning out your filter if you haven't already. It gets angry if it can't get any air.
If not, I don't know how brave you are, but I ripped mine apart to fix the problem. I took off the panel with the filter (5 screws) and you can see a collection tray with another little collection gutter under that. Both of mine were filled with junk, mostly dust that had gotten wet to make this awesome disgusting sludge. If you can get at it from there, try to clean the sludge out of the collection tray and the little gutter. I ended up taking my whole unit apart so I can get the collection tray out (dumb design, you have to take apart the whole dang casing to get at two screws that hold the collection tray in).
May 14, 2010 | DeLonghi Dehumidifiers
Whirlpool dehumidifier in basement has stopped taking water into
how warm is the basement,if the temp of the basement is lower than say 70 degrees,the unit will not function,true dirty coils can have this effect also and a refrigerant leak on these will cause the same result,if the temp is low,use a fan to move the air and this will help with your humidity problem too
Apr 02, 2010 | Whirlpool AD35USS Dehumidifier
The fan runs but it does not dehumidify. What could it be?
If the room tempature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defost over night.
Only specially made dehumidifers work below a room temo of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensot from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Jan 02, 2010 | DeLonghi DN25G Dehumidifier
E1 CODE ERROR
E1 code for the primary humidity sensor behind right side grill. Unit MUST be unplugged from outlet. Take right side grill out, unplug sensor from wire socket and plug back. If no help, you need new sensor.
Dec 30, 2009 | Danby DDR451 Dehumidifier
My challenge dehumidifier runs ok but does not collect any water , whats the problem?
low outside temp means low inside humidity
If the room temperature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
Turn off and it will defrost over night.
Only specially made dehumidifiers work below a room temp of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensor from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Dec 20, 2009 | DeLonghi Dehumidifiers
Works well but
Yup, they eat energy.
An electric dehumidifier includes a refrigeration cycle that is very similar to a window AC units and refrigerators. They cool the air in the basement to condense and collect water and remove humidity, heat the air as a required consequence of the refrigeration cycle and dump it back to your basement.
Two sources of humidity in basements include warm outside air that naturally cools due to below grade earth contact and water passing from the ground though the floors and walls and evaporating into the basement. Dehumidifiers do most of the work in the summer when higher temperatures outside enable air to hold more water content.
In the winter, cooler outside air contains less moisture by weight eventhough it may be raining and the relative humidity in basement will be less because the air is warmed relative to the outside. The lower moisture content in the winter also absorbs the water passing through the walls and floor.
From an energy perspective, you may want the humidity set NOT below 50%. This will keep humidity below the level mold desires, but prevents the dehumidifier from doing more work and eating more energy than needed. A cheap battery powered temp/humidy meter left in your basement will help. Sources that include the "mold triangle" (temperature, water & food) often separate fact from expensive hype.
If the dehumidifier doesn't keep up, consider adding a moisture barrier to the basement walls and floors such as Dry-lock and floor paints to ****** moisture entry. Moisture barriers act very similar with water as insulation does with heat. They don't eliminate the need for a dehumidifier, but they reduce the work they do and energy they eat.
Oct 02, 2008 | DeLonghi DH40P Dehumidifier
Delonghi Dehumidifier E! error
I Had an E error (not an E1 error) when I was fiddling with my humidity/temp sensor on the face of the radiator fins (behind air filter).  The sensor was WET.  I dabbed it dry, let it sit all day, and re-assembled.  It works fine now.
Aug 30, 2007 | DeLonghi DE500 Dehumidifier
Dehumidier Delonghi DH400P not removing any water from the air
Only thing I can tell you to do is to make sure that the evaporator in the back is ice and cold. If the evaporator is not cold the unit will never remove moisture from the air. And if that is the case you have a sealed system problem. The unit may have a leak so there is no gas in it. The compressor may not be working or the humidstat my not be working properly. So check those thigs out or if its under warrenty call for service.
Jul 11, 2007 | DeLonghi DE400P Dehumidifier
Dehumidifiers Logo
852 people viewed this question
Top DeLonghi Dehumidifiers Experts
dennis lewis
Level 1 Expert
Are you a DeLonghi Dehumidifier Expert? Answer questions, earn points and help others
