Question about Toro Lawn Mower With Toro Power Tools
Toro 6.5 hp 9 year old mower. Starts Ok; surges
Toro 6.5 hp 9 year old mower. Starts easily but engine surges up and down in speed. Help!
  • 376 Answers
Sounds like your carburetor needs to be cleaned out. The surging is usually a sign of running to lean (not getting enough gas) because of possible water, rust, gum, varnish or trash in your carb. Hope that helps.....
Posted on May 17, 2009
Toro Personal Pace sounds like it is running at half power
got oil in it, or do you add oil. Left outside alot, fuel line clogged. Is the gas old. Check the blades and the exit portion of the clippings. Does it have a drive train for ease of moving. those can bog down a mower. good luck
Apr 30, 2013 | Toro Lawn Mower. 22 in. Personal Pace with...
Toro timecutter mower motor upgrade
90% of vertical shaft engines use the same pattern only seen a couple that one hole is off place
Sep 13, 2012 | Toro 52" 27hp Z Master Zero Turn Lawn...
Toro z master 252, starts ,runs 8 to 10 min. shuts...
One suggestion wouild be to check the spark right after failure. You can buy in-line spark indicators that give you a visual light if you are getting spark. This way you could see if you are losing spark when the engine warms up. If your spark is good, you would want to check the compression after the engine is warmed up and quits. You should have at least 100# minimum.
May 21, 2010 | Toro 54'' Zero Turn Lawn Mower 25hp...
Electric Starting Difficulty on Toro mower with Tecumseh engine
it sounds like to me that the starter pully is getting caught up on the worm gear ,this could be because of dirt or grass getting in the way make sure that no grass or dirt is around the worm gear
Mar 03, 2010 | Garden
Silver series 6.5 hp surging
  1. Carburetor is dirty.
  2. Air leak in carburetor or intake manifold (e.g., bad O-ring, gasket, primer).
  3. Carburetor is improperly adjusted
These are some of the more typical reasons that can cause a small engine to surge.
Jul 09, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Toro mower-shut off, won't re-start
check the coil by pulling the plug and lay it against the head put the plug wire on pull the handle if it sparks then its not the coil another thing you can try is spay carb clean or starting fluid in carb see if it starts if that starts it then the float in the carb is stuck if i can help further e-mail me @wadembly@aol.com
Jun 08, 2009 | Toro Lawn Mower With Toro Power Tools
Engine surging
sounds like it is "hunting". it is a fuel mixture issue.
May 22, 2009 | Toro Lawn Mower With Toro Power Tools
Toro mower does not strat
Did you possibly hit something? Sounds like the flywheel key may have sheared.
May 18, 2009 | Toro Lawn Mower With Toro Power Tools
Toro self propelled wont rev up
sounds like the govern spring came off
May 12, 2009 | Garden
Engine revs faster than it should. no controle of speed.
on the bottom of the carb is a metal bowl, remove and clean internal parts. make sure the float moves freely and isnt sticking
Nov 13, 2008 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Toro Lawn Mower With Toro Power Tools Logo
741 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
