Question about Actiontec Computers & Internet
Very slow speeds
Slow connections on wireless or ethernet. Just started 2 days ago.
3 Suggested Answers
SOURCE: Wireless light does not come on
are u able to detect your wireless network in view wireless networks
if not login the modem setting and check whether the modem wireless is enabled.
if still having problem contact 9444482052..........jammy
Posted on May 19, 2009
  • 158 Answers
SOURCE: Weird problem. I have
You will need to contact Comcast. They will reset your service for the new equipment. Things are rarely "plug & play" with Comcast.
Posted on Apr 13, 2011
Download Speed Failed
Hi Aljaz,
If you are having issues with your download speed I would suggest purchasing an ethernet cable and plugging in directly. This will ensure you are getting the best possible internet connection.
Ethernet cables cost around $10 depending on the length and quality.
If you are unable or unwilling to purchase an ethernet cable, your next step of consideration may be your router. Routers usually last only 2-3 years before they start to experience issues. If yours is any older than that, replacing it will help solve the issue.
Having said all of that, I highly recommend the ethernet cable route. It is the cheapest and most reliable option.
May 02, 2012 | Sony Playstation 3 (PS3) Console
Is it possible that my Dell Inspiron wireless card ( with Blurtooth ) is slowing my wireless broadband by approx 50% from an ethernet connection
With regard to your inspiron 6000 wireless, I believe that the wireless card included is a b/g type. This means that the maximum speed that you could get to a wireless connection is actually 56Mbps which is really around 50% of the normal ethernet connection which is 100Mbps. If you would like to increase the speed of your wireless what you need is to upgrade that to a b/g/n type which goes up to 100Mbps also with increase in distance. Also you have to make sure that the wireless access point or router also has a N-type wireless connectivity. Even if you have a N-type wireless card on your laptop, if the router is only up to G then it will still connect just up to 56Mbps.
Now, with regard to your bluetooth connection interfering with your wireless, You do not have to worry, both these devices connect at a different frequency. So they would not interfere with each other.
Apr 29, 2010 | Dell Inspiron 6000 Notebook
Incredibly slow wireless connection when DSL connection is fine.
anytime you transmit wireless and connect wireless you loose speed. a lot of routers have a buffer in them to regain the transmision speeds. the antennae needs to be at a 45 degree angle as well for best transmission and tight. there maybe static in the lines called ingress. a bad connector or a radio shack splitter will kill off hsi. make sure your splitter is over 1000 mhz. the 900mhz are garbage. your netgear may also be the problem, and may be subject to warranty replacement.. it is very common. i install netgear wireless daily and i have seen brand new out of the box fail. also like my wife, she forgets to remove the torrent files from the vuze downloader and ends up seeding 20 albums which slows us down bigtime.
Jan 18, 2010 | NetGear WGR614 Wireless Router
The wireless network is very slow compared to when I connect to one of the RJ45 ports in the back of the router. Every wireless connection I try crawls in speed. I have Wireless -G USB adapter in one...
Makesure your computer is not too far away from your wireless router andyou have a good signal. By placing your mouse pointer over the wirelessconnection icon, located in the bottom right corner of your taskbar, you cancheck to see if your signal strength is good. Anything less than a good signalcan cause intermittent connections.
SOLUTION:You will need to relocate your wireless router closer to your computer.
Dec 16, 2009 | Linksys WRT160N Wireless Router
Ethernet works wirelss is very slow
Most of the wireless adapters connect at a speed of 54mbps max, while wired lan connection adaptors (LAN adapter/cable) works at max of 100/1000mbps. hence use a cable to connect the PC to make it faster than using wireless.
Aug 17, 2009 | 2wire 1800HG Router (RG1800HG00)
Dell latitude cannot connect to wireless but can through ethernet
ever thought that the wireless card might be disabled or you set it to off?
Apr 18, 2009 | Dell Latitude C840 Notebook
Connection to iMac not working
the easiest way is hard wire a windows laptop and use the CD that came with the router.
Oct 13, 2008 | Microsoft Broadband Networking MN-500...
Network Cable Unplugged
mairelina, if all was well 2 days ago then resetting the router should fix your problem. usually a small button on the back of the router.
chelliepooh, you need to check that the router's wireless function is on. connect using the ethernet and go to the config page (usually 192.168.1.1) make sure wireless is on and security is set to wpa-psk.
May 19, 2008 | NetGear WGR614 Wireless Router
Desktop has very poor/slow connection through wireless router
This sounds like a spyware/virus problem. Try running the computer in safe mode(With networking) and see if it's any faster. You should also run your Anti-spyware,AV apps to check for problems.
Sep 13, 2007 | D-Link DI 514 Wireless Router (DI-514)
Computers & Internet Logo
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
