Question about Whirlpool AWZ412 Front Load Washer
Detergent where do you put the detergent in
I have a maytag bravos xl top loader with the water saver i cannot find a detergent that doesnt get rid of the soap it covers my black clothes
powder detergents are generally the reason for that as they use a clay base to carry the active detergent and it is that base that is the problem
Try using a liquid detergent
next try using a wash bag that you put clothes in to put in the wash as that also stops marks and fluff from getting onto black or dark colored cloths
Feb 27, 2017 | Maytag Washing Machines
Ariston Dishwasher Detergent dispenser
you have 2 options.replace the timer on the unit or when you start a load wait 10 minutes and put a half cup or a little more of detergent into the water in the dishwasher.
Jan 05, 2008 | Ariston Technologies LL64WNA Built-in...
Do you put detergent in the frigidaire affinity front loader clean washer cycle?
Good Afternoon Jodi,
I understand that you are wondering if you put detergent in your Frigidaire Affinity washer for the clean cycle. You do not put detergent in. You will want to take the detergent cup out and put a cup of bleach in there when you run the clean cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 10, 2014 | Washing Machines
Should I put powder detergent in the tray or in the drum in my Asko front load washer?
But the powder in the tray. I have a asko washer myself
You should to able to go on line and download your manual
Go to Asko.com Good Luck
Feb 12, 2013 | Asko W6461 Front Load Washer
Do I put powder detergent in the same place I put Liquid detergent?
Detergent compartment
Add liquid or powdered detergent to this compartment for your
wash cycle. The detergent separator must always be in place,
either in the front or back position.
 Do not fill beyond the “MAX” level.
 Liquid or powdered color-safe bleach may be added to the
Main Wash compartment along with the same type of
detergent, liquid or powdered.
 Liquid detergent: Put the SEPARATOR in the front position,
between the guides, as shown as shown by Position 1 below.
There will be no gap between the bottom of the wash cycle detergent
compartment and the bottom of the separator.
Powdered detergent:
Put the SEPARATOR in the back
position, behind the guides as shown by Position 1 below. There will be
a gap between the bottom of the wash cycle detergent
NOTE: The separator will be in the POWDER (back) position
when shipped from the factory.
Nov 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
There are streaks (lint?) left on clothes after
It is not on the machine, it is on the detergent that you are using and the amount of water for per grams of detergent, maybe you are putting to much detergent, try to lessen the detergent and more water instead.
Nov 06, 2009 | Kenmore Washing Machines
REGULAR DETERGENT ON HE PLUS
Regular detergent causes the washer to make too much suds. Use HE detergent unless you want to fry your washer. You can use regular detergent as long as you use a small amount.
Jul 14, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Where do i out the laundry detergent, when there are two sections
Look closer at drawer that comes out. The labels for pre-wash and wash are under the lip on my LG. Stand to the side and look towards your hand that opened the detergent drawer.
May 12, 2009 | LG WM2487H Front Load Washer
WATER IS COMING OUT OF THE DETERGENT DOOR. I'VE HAD THIS PROBLEM BEFORE FROM PUTTING POWDER DETERGENT IN THE LIQUID DETERGENT AREA. I BELIEVE IT'S CLOGED. WHAT CAN I DO TO SOLVE THIS. IT WAS UNDER WARRANTY...
STOP USING SOOOOOOOOOOO MUCH DETERGENT, AN USE HE DETERGENT. POOR HOT WATER IN DESPENER LET SOAK. IT WILL BREAK THE SOAP LOSE .
HE DETERGENT REQIURES A TEASPOON ONLY
May 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
LG 2277 Liquid Detergent Box & Insert
please put detergent into the main(left) side of the dispenser
Feb 15, 2009 | LG WM-2277HW Front Load Washer
Whirlpool AWZ412 Front Load Washer Logo
14 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
