Question about Icom Radio Communications
Ic706mk2g front panel blank display, no backlight, set working ok via ham radio deluxe, but cannot access menu.
    Sergeant:
  • 435 Answers
In order to access the menu you have to push & hold "display" for 2 seconds
& to get to the real menu hold this down while powering on the radio
not sure what one you need
Posted on Feb 11, 2015
I have a IC-756pro and the cat system won't work? Is it something easy to fix or only the factery
Icom radios are particularly problematic for HRD. I would urge you to read the instructions here. http://www.ham-radio-deluxe.com/hrdrigcontrol.pdf There are special instructions for Icom radios.
Dec 09, 2014 | Icom Ic-756pro Hf Transceiver Service...
We have a Phillips plasma tv and the picture pixelates randomly and freezes for about a second and sound breaks also. We have had everything checked and have been unable to find a solution. The latest...
In my openion, Its problem of hardware in your TV and signal processing circuits are involved. It might be problem of Firmware (programe to control the performence over all) Philips can advise you better in this regard.
Aug 01, 2008 | Televison & Video
Black screen for HDTV channels -- but TV menu and DVDs display normally
Try hard reset, Please unplug the tv cables and power cables for 30 min and redo the cable and check its working ....
Good luck...
Aug 01, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Why is my bc898t display blank
Could be a cold solder joint bad connection of wiring harness hard to say I will look to see if i have a spare front panel with display. what electronics level are you?
Sep 07, 2014 | Radio Communications
My 857 receives fine, but when I key the mic it turns off. The 857 works fine on HF both receiving and transmitting.
I would have a look at the FT-857's extended service menu by holding in A, B, C buttons and pressing power button for a couple seconds. The default setttings are on the mods.dk website. Should also ensure regular menu settings are correct/appropriate. I can tell you that it is possible to change extended menu settings by getting RFI into radio. Also, although unlikely, it sounds like you could inadvertently have done a write to the radio's EEPROM, which can be determined by using a program such as Ham Radio Deluxe, a CAT cable, and procedures also posted on mods.dk website under how to open radio up for 60m, ext tx/rx, without any hardware mods. As to whether you can do all this while still mounted mobile,,,,,maybe with a laptop? Good luck, Link, WV4I....
Oct 22, 2013 | Yaesu FT-857D transceiver
Brother mfc-6490cw lcd screen shows no display (just the backlight is on)
Procedure1: Changing the LCD Contrast setting
  1. Press Menu.
  2. Press the Up or Down Arrow key to choose General Setup.
  3. Press OK. (For touchscreen models, skip this step.)
  4. Press the Up or Down Arrow key to choose LCD Settings.
  5. Press OK. (For touchscreen models, skip this step.)
  6. Choose LCD Contrast and then choose Light, Med, or Dark.
  7. Press OK. (For touchscreen models, skip this step.)
  8. Press Stop/Exit.
Procedure 2: Changing the Backlight Brightness setting
(This option may not appear depending on the model of your Brother machine.)
  1. Press Menu.
  6. Choose Backlight.
  7. Do one of the following (The menu varies on your model.):
    • Choose Light, Med, or Dark.
    • Press the Left Arrow key to make the backlight darker or press the Right Arrow key to make the backlight lighter.
  8. Press OK. (For touch screen models, skip this step.)
  9. Press Stop/Exit.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
May 28, 2011 | Brother MFC 6490CW InkJet Printer
THE FRONT PANEL DISPLAY IS BLANK. HAVE I DONE
Perhaps, the manual mentions a Dimmer setting under the Display Set Menu but doesn't specify how dark it can get. Give it a try.
Dec 26, 2009 | Yamaha RX-V1000 Receiver
Lc32gd8e backlight goes out in middle of a program
This is not a complete solution, but I have found that once the backlight has gone out, I can normally get it back by selecting the "Audio Only" option in the setup menu without turning the set off. This option is really intended for use with radio broadcasts when the picture carries no useful content.
When I press the 'menu' button on the remote and select the right hand most tab, the top option under this tab is 'Audio only'. I select the tab, and then exit from the menu until I need it. When the backlight goes out, I press the following key sequence:
menu, down, ok, right, ok, menu
and the picture reappears. Pressing the menu button opens the menu page at the correct (righthand most) tab. the down highlights the 'audio only' option, and the OK selects this. The right turns the option on (with the backlight working, the picture is removed, but the menu is still displayed). The second OK activates the option. The backlight is turned out. Finally, the second menu key press turns the backlight back on again. This technique has the advantage that the sound continues throughout the sequence, and the recovery of the picture is faster than waiting for the set to boot from a power off condition.
I suspect the problem is caused by an intermittent contact on one of the tubes, possibly as the result of some movement as the tube warms up and expands. (There are 8 tubes in the 32" set.) This causes a safety ciruit to shut down the inverter supplying power to the tubes. Switching off the backlight resets the safety circuit. If I manage to confirm this suspicion, I will write again.
Jun 12, 2009 | Sharp Televison & Video
The screen on my compaq armada is blank. i can
The display panel itself is probably fine, but its backlight isn't working. Without the backlight you can't see the display. There's a small circuit board called the inverter inside the display that provides power for the backlight.
It's pretty easy to replace the inverter. You need to take out whatever screws are holding the front half of the display to the back and remove the front. The inverter is at the bottom of the display, held in by a couple of screws. A couple of cables plug into it.
Here is a place that claims they have the inverter in stock for $7.39. That is one fantastic price! Get one of those and a set of miniature Phillips screwdrivers and you'll be able to fix this yourself.
Apr 18, 2009 | Compaq Armada 7800 PC Notebook
80gb Classic backlight on, no menu displayed
you LCD is Broken...Look for an iPod Repair in your area and have the LCD replaced.
it's a classic symptom of a damaged LCD..I see it all the time.
Apr 12, 2009 | Apple iPod classic MP3 Player
Radio Communications Logo
82 people viewed this question
Top Icom Radio Communications Experts
peter0911
Steve
Are you an Icom Radio Communication Expert? Answer questions, earn points and help others
