Panasonic tbm2ax01801 where is the hdmi port
Does panasonic th-l32c8d 32 in has hdmi and USB port
The connections are on the left of the TV, they are an SD card slot along with an HDMI port, a USB port, a 3.5mm audio jack and composite ports.
Nov 02, 2016 | Panasonic Televison & Video
HDMI 1 and HDMI 2 no longer work on my TV. What can I do to repair this?
Sounds like you have a bad input board and it is only time before you lose three. If it is under warranty get it in otherwise start tracking down the part. Most of these are a plug and play device once the tv is apart.
Oct 07, 2012 | Panasonic Tc-p50g20 Viera G20 Series 50"...
Panasonic PT47XD64J Rear Projected TV
I know this sounds crazy but unplug everything in the HDMI ports. This series of Panasonic TVs have had many problems with bad HDMI ports. If there is a device plugged into one of the blown ports the power light will blink and the TV will refuse to power on.
If it comes on plug in devices one by one. You'll be able to isolate the bad port. Just refrain from using that one from now on. There's not much else you can do. There are HDMI splitters available if you need all your ports. It's an extra step but it's certainly cheaper than buying a new TV.
Jul 23, 2012 | Panasonic Televison & Video
Panasonic Viera TC-L37X1 hdmi not working
What do you have hooked up to the HDMI ports? Just a cable box?
Apr 02, 2012 | Panasonic Viera TC-L37X1 37 in. LCD HDTV
The hdmi port on my Panasonic CT-30WC14 only works when I push the cable into the port and hold it. It has a bad connection. I was going to take the back panel off and see if I could connect to the port...
Not the HDMI port,it the HDMI cable is dead.If u have dead HDMI port holding the HDMI cable wouldn't work,make no difference.Change the HDMI cable will solved ur problems.
Sep 06, 2010 | Televison & Video
Panasonic PT-AE2000U All three HDMI Ports stoped working. I have tried different HDMI cable and a three different HDMI Feeds. I can get a picture using the red green blue component cable. Any ideas?
WOW. I just experienced the same thing. None of my HDMI ports are working, though component is fine. I've had my unit since November 2007 and had no problems until this. I think the HDMI board has gone bad and will require replacing.
May 20, 2010 | Panasonic PT-AE2000U Projector
Only one HDMI port on new receiver/dvd player
Chances are good that your panasonic would not support HDMI 1.3b firmware and you would loose audio or video anyway. If your Panasonic has digital inputs, ie. coaxial digital or optical, run audio to your receiver and HDMI direct from Cable box/ DVD/other source to TV. On the TV settings menu, turn the speakers "off". If you need further help, post a comment and I can help you more
Oct 14, 2009 | Audio Players & Recorders
Panasonic TH-42PX60U HDMI stopped working
Please unplug TV from AC outlet and replug it after 5 minutes then check HDMI port.
Nov 28, 2008 | Panasonic TH-42PX60U Television
Televison & Video Logo
101 people viewed this question
Top Televison & Video Experts
Electro Med Services...
