Question about Acer TravelMate 517TE Notebook
New Hard drive not recognised
I am putting a new 40GB hard drive into a 517TE that had a 20 GB
but it will not recognise the new drive. Are there any dip switches
etc?
  • troubleme Oct 17, 2007
    No it is a laptop so only has room for one drive. ut thanks for trying
  • 4 Answers
You have to use a drive overlay due to the bios limitations of the computers motherboard.
go the manafactures website "harddrive sight"
or use google to find 1 that works for you . lol at eagle338 "n00b"!
Posted on Feb 24, 2008
  • 4,889 Answers
This is probably becuase you are trying to use two masters in the same cable...Set the HDD to CS(cable select mode)..and it will detect automatically
Posted on Oct 17, 2007
SOURCE:
I want to upgrade the hard drive on my Advent 6001 laptop to a 250gb one. How do I then copy Windows onto the new hard drive as the laptop doesn`t recognise the CDROM as a boot device, not even in the
Running under the assumption that the CD is actually working, have you checked the BIOS settings to indicate that you want the CD to be the first boot device?
Alternatively, some if not most systems will accept an F12 during boot up to query the user where to boot from.
Jan 06, 2018 | Hitachi Travelstar 5K100 HTS541040G9SA00...
My pc recognices the Hard disk but it dosent recognise its capacity :/
click start click on my computer you will see your hard drive usually C: right click on it select properties you will see all used GB on your hard drive and all free space
hope this helps you
Jul 30, 2011 | HP/Maxtor 40GB 3.5 IDE/ATA Hard Drive...
How do you use it?
connect the device using as usb cable to your pc, it will start working and the pc should recognise it as a new hard drive. you can save data to it and from it like a regular harddrive.
if you have any prolbem first time you may need to format the drive.
only remove it when data has stoppped being transfered to or from it.
once removed the data put on it is still there and can be move from it to any other device that accepts the drive and the data formats.
I hope this was helpful
Jan 22, 2011 | Seagate 500GB USB 20 5400RPM Portable 500...
Iomega 320 external hard drive computer wont recognise
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked (with the computer and hard drive plugged in). I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
Jun 15, 2010 | Iomega Portable Hi-Speed USB 2.0 40GB,...
Lacie 250 GB (Neil Poulton) external hard drive not recognised on PS3 (20 GB) . My friend has a Maxtor 250 GB drive, he can play just about anything from his drive on the PS3, but i cannot. The drive does...
go in to add new hardware in control panel and run external drive ere from there use disc if u have one or go to vendor's support page and download driver's from there
Jul 18, 2009 | LaCie (300770) 250 GB Hard Drive
Dell optiplex gx110 733mhz won't recognise another hard drive
this time external hard disk drive to you Dell... this Dell optimized for only that 10GB drive..
Jun 17, 2009 | Computers & Internet
Wd element 250gb usb hard drive
you'll find that the external chassis is buggered, get a new one and put the hdd in and see if your info is still there.
Apr 23, 2009 | Western Digital 250GB ELEMENTS EXTERNAL...
Windows 2000 advanced Server does not support Seagate 250 GB Hard Drive.
I am inclined to think that this would be a problem with the jumper settings limiting the size of the drive.
I can't offer anything more than that, sorry. Hope it will help a bit.
Aug 08, 2008 | Seagate (ST3250824AS) 250 GB Hard Drive
Quantum fireball 40 not recognised as master
goto the quantum site and verify the jumper setting on the drive first
if correct then.. check your sata cable is good...
check the bios to boot options so the quantum is set to boot...
under boot options .. hard drives.. sort the drive to be the first to boot
Jan 04, 2008 | Quantum Fireball Lct20 (QML20000LD-A) 20...
Acer TravelMate 517TE Notebook Logo
83 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
