Question about Motorola Mobility H390 Bluetooth Headset
When charging light blinks red when off charger it does nothing wont come on
Invacare what does it mean when light on charger continually blinks red when charging, It wont move
The red light is the power light and if the red light is blinking the charger is bad or the wiring is bad on the chair or the batteries are bad. Usually it's the charger.
Aug 12, 2014 | Invacare Supply Group Pronto M61 Standard...
Charger will not charge radio, has red blinking light
If the radio will charge on one charger and not the other, the one with the blinking light is bad or has a dirty or defective battery contact. Check your charger for debris and clean your battery contacts with a pencil eraser and try charging again. If this fails, replace your charger.
Best regards.
Jan 31, 2014 | Kenwood KSC-37 Replacement Charger for...
Duracell charger wont charge..
The blinking indicator is telling you that the batteries have been inserted incorrectly. Otherwise, the charger probably no longer works
Jan 20, 2013 | Duracell AAA NiMH Battery Charger with 4...
Red light is blinking
Your battery is shot you need to replace battery.When the red light blinks it means the Battery wont take a charge this normally happens if the battery is left on the charger longer then needed to charge. They sort of burn up on the inside.
Apr 14, 2012 | Drills
RYOBI CHARGER RED AND GREEN FLASHING LIGHT
My charger blinks red and green but I've literally only used my chainsaw 4 times. It's less than a year old. It won't charge the battery. What could be the issue? Or can I take it back to home Depot and use the warranty? Any help will be welcome.
Jan 04, 2012 | Ryobi Multi-Volt Battery Charger
Blackberry wont light up after connecting to
the battery is very low that's why. The battery cell is weak such that it cannot be power up with charger. Except you use a desktop charger to wake the battery cell, then you can continue the charging with your charger.
Also you can leave the charger in the mouth of the black berry for some hour as it might still power up the battery.
There is nothing to worry about. Its a battery issue.
Take care.
Mar 17, 2010 | RIM BlackBerry 8700c Cellular Phone
Dewalt battery charger won't charge
As you know, solid red on your charger means that the battery is fully charged and the BLINKING red light means the battery is charging. Unless the light is blinking irradically everything is working the way it is supposed to. If the light is blinking irradically, the battery may just be too hot or too cold to charge ( like when you are driving many lags and your battery dies) and in this case simply wait 15 minutes to charge. If you get a fast blinking light still, the problem probably is with the battery.
Oct 07, 2009 | Dewalt DW056 18 Volt Cordless Impact...
WON"T WORK
sounds like a dead battery. Plug the origional charger into it and the front led (below the flash) should flash red. If the red led in the back of the camera flashes or stays lit, then you have the wrong charger plugged in. (the camera won't power up if the back red/green led is on when plugged in)
May 08, 2008 | Jazz DV-179 Digital Camera
Motorola Mobility H390 Bluetooth Headset Logo
47 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
