Question about Rancilio Epoca ST-1 Espresso Machine
Brand new Rancilio Epoca S1 Tank will not fill up the boiler? I have filled the tank, water is flowing through the softener andd airlock. The motor starts but no water is flowing through the hoose. An
When turning on the main switch, the motor starts, but no water flows from the tank.
2 Suggested Answers
mikey270
  • 26 Answers
SOURCE: new rancilio epoca s tank I
It should take about a 1/2 hour to warm up, are any lights flashing? Is the light on the second switch green? If not you might want to take off the left panel and find the thermal reset. Its mounted to the top side and has a little red button facing you. Press that to reset the unit.
Mikey@espressomachineexperts.com
Posted on Feb 24, 2011
Rancilio Epoca S1 tank
Try editing brand and model number into your question.
Aug 03, 2015 | Coffee Makers & Espresso Machines
How does pressure tanks work
Pressure tanks do just that in a water system. They create pressure for water to flow when the water pump is on the off cycle. A manifold is plumbed into the tank from the main line coming from the well. The main water line continues to the house plumbing from the manifold. So it's line from pump to manifold - to tank, and from manifold to main into house. The manifold also has tappings for the pressure gauge and the pressure switch. The pressure tank creates water pressure. The water does not flow through the tank. Pressure tanks also have to be 'tuned' or adjusted to the low end pressure set by the pressure switch. Actually the tank pressure needs to be set 2psi below the low end pressure. Most residential water systems are set to operate between 20 -40, or 30-50 psi, which is set by the pressure switch, which in turn , turns the water pump on and off. So if a system operates between 20 and 40 psi, the pre-charged pressure of the tank should be 18 psi. Pre-charged means the tank is drained of water with the water pump OFF. The tank pressure is then checked adjusted by way of the air valve on top of the tank ( A tire gauge works). Pressure tank mainfolds are a common plumbing part.
Mar 19, 2014 | Utilitech 20-Gallon Vertical Pressure Tank...
Temp water from portafilter
you want between 94 and 96C for water temp and you want 13.8 kg tamp pressure you want extraction to commence at most 9sec into button press an to pour like room tmp honey would. Drip drip start is okay at times but should start to flow by about 10 additional secs in you want it to extract with about 9.5bar pressure and you want to stop full shot extraction by the third colour change no longer than 4 sec of blonding or tigerstriping what eva u wanna call it.
sounds like your element needs to be changed out/is shagged or you have a leak in a weld any leeks water or steam take off housing an inspect
Nov 07, 2013 | Rancilio Epoca ST
Wont turn on
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Feb 27, 2013 | Kenmore Washing Machines
Zanussi jetsystem ZJD-12191 TURBODRY washer dryer drum will not turn
Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Jan 22, 2013 | Washing Machines
The unit was working filled up with water and then quit working. The LED's flicker but it doesnt turn on
It ispossible that the machine does not start off the cycle because there are errors possible failure of the controller unit. For the program to start up the main programcontroller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting fromthe flow of water into the drum as also the drain valve to open to exit thewater at the point of the program cycle. If this does not happen then thevoltage at the valve/motor/pump must be checked or the fault relates to novoltage from the controller. This meansthe controller is a suspect.If thewater flows though the inlet then the flow pressure should be good, if not theinlet valve is bad or there is dirt in the filter. Also check the flow at theinlet of the water line. Once the water comes into the system the WATER LEVELSENSOR - normally a pressure switch- must activate at the preset/chosen levelto give the signal to the program controller to switch on the motor. What ismost important for the motor to start functioning is that the door switch mustbe ON when the door is shut or this will be an error for starting the motor forrinse and wash.
Aug 03, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing machine will not turn on
It ispossible that the machine does not start off the cycle because there are errorsdue to feedback from the inputs. For the program to start up the main programcontroller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting fromthe flow of water into the drum as also the drain valve to open to exit thewater at the point of the program cycle. If this does not happen then thevoltage at the valve/motor/pump must be checked or the fault relates to novoltage from the controller. This meansthe controller is a suspect.If thewater flows though the inlet then the flow pressure should be good, if not theinlet valve is bad or there is dirt in the filter. Also check the flow at theinlet of the water line. Once the water comes into the system the WATER LEVELSENSOR - normally a pressure switch- must activate at the preset/chosen levelto give the signal to the program controller to switch on the motor. What ismost important for the motor to start functioning is that the door switch mustbe ON when the door is shut or this will be an error for starting the motor forrinse and wash.Check thislink to replace the inlet valve:http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Jul 26, 2012 | Fisher and Paykel Washing Machines
Spin is all that is working, wont fill with water
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Jun 27, 2012 | Admiral AAV7000A
Maytag neptune washer not turning on
Jun 25, 2012 | Maytag Neptune MAH5500B Front Load Washer
My Rancilio Epoca ST1 would not turn on yesterday so I unplugged the machine and plugged it back in and it started right up. Today I turned the machine on and it warmed and pressured up as usual and then...
That's a tough one, the only thing I can think of is checking the reset switch and the element with an ohms meter to see if they are functioning correctly, before moving on. The only reason the machine would turn itself off, would be lack of water in the main boiler and if it does not know there is water in the reservoir, or it cannot take water from the reservoir to fill the boiler, or the element is overheating so *** trips the reset.
Jul 12, 2011 | Rancilio Epoca ST-1 Espresso Machine
Rancilio Epoca ST-1 Espresso Machine Logo
83 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
vilhj
Level 1 Expert
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
