Question about Sharp Televison & Video
How to connect woofer of sharp godfather tv to computer
Password for godfather game
If you downloaded a pirated versios of that game and it had no password to uncompress it on pirate site, bad news is that wery probably the intention of ploader was NOT provide you the password.. Check site anyway if some other dowloader already asked for the password and it was provided.
DON'T FOLLOW ANY LINK TO FILL "SURWAYS". . That's just scam and all you'll get is some virus or in best case, spam in your email inbox.
May 03, 2015 | The Godfather Video Game Consoles & Games
I have a Sharp Aquos LC-60LE640X TV and I am trying to connect a Samsung HW-H751 Soundbar to it. I have hooked up the optical cable, adaptor and sub woofer, I have tested the Bluetooth function throug
If you are connecting the soundbar to your TV with the digital audio cable, make sure to select "D IN" using the source button on the soundbar. Bluetooth (BT) is a separate source from another device. (phone, etc.) The TV will need to be set to use the digital audio output and probably PCM format. (?) The subwoofer is preconfigured at the factory to mate up with your soundbar. (See below instructions - your soundbar includes the amplifier:)
Digital audio output setting:
After connecting an amplifier with digital audio input and
external speakers as shown, you should set an audio
output format compatible with the programme you are
watching or the device connected.
Go to "HOME" > "TV Menu" > "Setup" > "Option" >
"Terminal setting" > "Digital audio output" > select
"PCM" or "Bitstream".
NOTE
• When set to "Bitstream", Dolby Digital is output when the Dolby
Digital or Dolby Digital Plus audio formats are received. When
set to "PCM", PCM is output no matter what audio formats are
received.
• When set to "Bitstream", HE-AAC audio formats can be output
as Dolby Digital.
Jan 24, 2015 | Sharp Aquos Televison & Video
I have a problem when i start Godfather 2 then a error comes with could not initialize display hardware restart godfather 2 how to fix and thank you.
I needed to delete settings.txt, located here;
location (win7 x64): "C:\Users\+my_username+\AppData\Local\EA Games\Godphater 2\settings.txt
Oct 11, 2014 | Electronic Arts Godfather II : PC
How i get registration code of godfather 2
send me god father 2 game registration code please please!
May 06, 2013 | EA - Electronic Arts The Godfather II
Sharp ht sl50 sound bar and woofer no volume control
you need to connect the sound via the scart lead plug ,on the polug if you connect the sound to pins 2 and 6 for the channels and 4 is the earth or dround but check it out with a scart diagram as i cannot remember correctly and i just looked for my chart and cannot find it as its been a long time since i was involved in setting up satalite/video/TV euroconector cables .
Dec 26, 2011 | Sharp Audio Players & Recorders
Program code of sharp 21b-k92
sharp godfather tv(model no-21B-k92) WANTED TO BE SERVICED.IT IS NOT WORKING PROPERLY.
Nov 22, 2011 | Sharp Televison & Video
The game is install on my pc but when i run it it crash
Make sure your video card and computer have all the shader requirements look at the back of the cover for the minimum requirements.
Apr 28, 2011 | The Godfather Godfather for Windows
Can i plug pc speakers into tv via red and yelow or ear phone socket ?
If the PC Speakers have a woofer in between then you could connect that woofer to the Tv and then connect the PC Speakers to the woofer..
The PC Speakers should not be the inbuilt PC Speakers.
--Steven Vas(The one)
Jun 09, 2010 | Acer Audio Players & Recorders
Am setting up a bose GSX 3-2-1 home theater
Need to know the TV connections. On newer TV's there RCA jack connection or ext speaker connections. Usually the external TV speaker connections hook to the woofer and the rest of the speakers are connected to the woofer. The woofer acts as the sound system for the rest of the speakers. With this method you need to mute the internal TV speakers by a swiich on the TV or internal TV setup menus and select ext speakers.
Jan 26, 2008 | Bose Cinemate Digital Home Theater System...
Televison & Video Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
