Question about E-Machines T6528 PC Desktop
Is there a space for a second hard drive in emachines T6528
"T6528 can i install an additional internal hard drive or do I have to remove and replace"
  • 127 Answers
You should have no problem in putting another hdd in to the case you should have space
Posted on May 17, 2009
Bsnl evdo
Your system memory may not be adequate and you may have to upgrade, you may also want to check how much space you have on your primary hard drive. This can be cured by purchasing a second hard drive, (internal/external), then configure your pc so that any additional programs/documents are stored on the secondary hard drive with the exception of the system files required to be located on the primary drive or re-install your additonal programs/documents to the secondary hard drive. This will significantly improve your PC's performance. Finally some system drivers may be out-dated and may need to be upgraded.
Dec 14, 2013 | Microsoft Computers & Internet
I want upgrade my emachines t6528 hard drive and ram.i need help
Memory Upgrade for eMachines eMachines T6528 Computer, the eMachines eMachines T6528 Computer takes the PC3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. Memory Type, and comes installed with 512 MB (removable) of Memory. You can upgrade your eMachines eMachines T6528 Computer to up to a maximum of 4.0 GB Memory, the system has 4 sockets to install Memory, already with 512 MB (removable) standard Memory installed. For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
As for the Hard Disc.... the following address will give step by step instructions on installing a new HD. http://www.manualowl.com/m/eMachines/T6528/Manual/
Thank You for using FixYa
Tom Miller
KD4DTK
Aug 19, 2012 | E-Machines T6528 PC Desktop
T6528
See http://www.manualowl.com/m/eMachines/T6528/Manual/119527 which is the manual for your eMachines T6528 system and has information on replacing hardware components including disk drives.
Dec 31, 2011 | eMachines T Computers & Internet
I own a emachine w3622 and changed the hard drive. The computer reconizes the new hard drive but when I go to use the operating system disk that came with my computer says disk boot failure. Not only that...
The disk that came with your system is a recovery disk only. You will need a full installation disk from your local retailer or you can match the OS from your old HDD and use the serial key on the side/back of your machine. If you just wanted more space, install both drives and set the original one as the boot drive. the new drive, if properly installed (refer to your hdd instructions and jumper settings) you will see the second drive under "My Computer" as additional storage
GOOD LUCK AND PLEASE RATE THIS POST AS FIXYA!!
May 09, 2011 | E-Machines eMachines Desktop PC
Why is my emachine t6528 slowed to a crawl?
Several Possible Reasons.
1.) Hard Drive related
Use the clean up function to get rid of all the cookies and other internet "trash" that has accumulated over time.
Then defragment the hard drive by going to My Computer > C Drive> (right mouse click) >Properties and Tools, select defragment
Then as before and use tools to check for errors (do not bother with a surface scan.. just yet)
2.) Dead and redundant programmes
If you have uninstalled or tried to uninstall any programmes, they may have left debris behind. Download REVO UNINSTALLER and use this to do a proper clean up (its free)
3.) Disc Space
Check the disc space remaining, if below 2 GB, you will be encountering issues with Windows Swap file (the bit of the hard drive windows likes to use to chuck data about in when it is executing commands). the bigger the swap file , the faster windows can do this.
4.) Hard drive damage
Download a programme called HDD Tune (free again), run it and check for any bad sectors and any RSC errors (shown in red or yellow highlights), if you encounter these, get your data of asap and buy a new HDD
5.) Virus:
If after all that, yiu still have problems, download a copy of DRWEB (yes.. that too is free), run it and even if reporting a clean HDD, run the C:/... path to make double sure
Jan 27, 2011 | E-Machines T6528 PC Desktop
My emachine is out of memory spaces what do i do
First of all,
delete any files that you do not need, uninstall any program that you don't need or use anymore.
Find files, images, audio files, video files that you don't need to store on your machine any more.
One last suggestion, perhaps you would want to move all of the file, if you don't want to delete anything, to an external hard drive or purchase an additional hard drive as an extension to the internal hard drive.
Thanks
P.S. Please rate if this solution was helpful.
Nov 01, 2010 | E-Machines eMachines Desktop PC
Need to transfer files from fried comp to new comp
take out the hard drive of ur previous laptop.
purchase an external usb case for laptop hard drive and attach it to ur new laptop.
dont forget to vote.
Sep 16, 2009 | Computers & Internet
Does the toshiba satellite a135 s2276 accomodate a second hard drive?
You won't find internal room to place a second hard drive, if that's what you're asking. Most laptops simply do not have the internal space, especially thin-line units.
What you could do for extra storage space is purchase an external drive.
Sep 01, 2009 | Toshiba Satellite A135-S2276 Notebook
E-Machines T6528 PC Desktop Logo
116 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
