Question about HP Office Equipment & Supplies
Changing an ink cartridge.
How do i change the b/w ink cartridge on my hp 750 xi printer?
I found another website that answered my question the first time I asked, in straight forward language and simple, easy to follow step by step instructions. I didnt have to state my question in two or three parts and didn't have to wait for an answer.
Posted on May 21, 2009
How to change ink cartridge hp psc 750
1- Open the printer
2- Remove the ink cartridges from the print head.
3- Use cotton swabs dipped in hot water to thoroughly clean the print head.
4- Repeat this until there is no ink residue coming off on the cotton swab.
5- Once finished, allow to dry and replace the cartridges
Mar 19, 2013 | HP PSC 750 All-In-One InkJet Printer
Started with out of colour ink - changed coluor ink cartridge. then came up with out of black ink - so changed the black ink cartridge now sais scanner failure when run through procedure to align...
"Scanner failure" basically means buy a new machine. Once the scanner fails on an all-in-one it will refuse to do anything. Replacing or fixing the scanner will cost much more than buying a new machine.
Sep 28, 2010 | HP PSC 750 All-In-One InkJet Printer
How do i change the ink cartridge for an hp psc 750 model ? Thanks
It should be as simple as lifting the top assembly, between the scanner and the printer, and wait for the cartridge to relocate to the center of the machine. Pull back on the top of the cartridge to remove it. Make sure that you remove the protective tape from the new unit and install it in the reverse procedure.
You will need to do a head alignment. Open the control panel, click on "installed printers and other hardware", click on "view installed printers and fax printers", click on the printer in question, under "printer" choose properties, click on cartridge maintenance and follow the instructions to print a test page and reset the cartridge if necessary.
This should finish your cartridge change. Let me know if you need more assistance.
Thanks for using FixYa and for the generous rating.
hardrocko
Jul 10, 2010 | HP PSC 750 All-In-One InkJet Printer
How to install ink cartidge? hp psc 750
1. Allow your injet printer to run entirely out of ink. Unless the quality of your images is suffering, there is no problem with letting your ink run low.
2. Open the printer door. It should fold from the top down toward the tray. When it is open, it should expose the inner workings of the printer.
3. Press the change cartridge button. It is at the top of the printer next to the power button.
4. Pull on the green top of the inkjet ink cartridge and remove it up and out of its holder. Do this gently so the printer is not damaged in the process.
5. Recycle the empty inkjet cartridge or have it refilled at an ink refilling center.
6. Carefully remove the tape from the refilled or new inkjet ink cartridge and insert the cartridge in the same orientation as the one you removed.
7. Push on the green top until the cartridge snaps into place, press the cartridge change button and close the printer door.
Feb 08, 2010 | HP PSC 750 All-In-One InkJet Printer
Cannot locate ink catridge for HP PSC 750 printer
With power on, simply lift up from the hatch located on the front of the unit. The ink jet will slide to the middle position.
Mar 27, 2009 | HP PSC 750 All-In-One InkJet Printer
Black ink Cartridge
Ink Cartridge Supplies for the HP PSC 750
Description
C6615A Black Ink Cartridge (HP #15)
C6578AN Color Ink Cartridge (HP #78)
That's right according to the above info
Try
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 09, 2009 | HP PSC 750 All-In-One InkJet Printer
Hp psc 750 xi how to replace black ink cartridge
1) Pull out your old black ink cartridge, py pressing the button on top of the old cartridge and pulling it down.It will be released, then just get it out.
2) Look at the back of your new ink cartridge, there should be a small panel with some small squares and kinda orange panel, this is the side that should not face you, it should face the ink cartridge holder on the printer.
Just put it in like that. Tell me if you have any problems.
Nov 17, 2007 | Sharp AL-1655CS Laser Printer
HP 2210 xi printing problem - alignment
Try your question here http://www.techsupportforum.com/hardware-support/printer-support/49664-hp-psc-2210xi-problem.html
May 14, 2007 | HP PSC 2210 All-In-One InkJet Printer
47 people viewed this question
Seeker5211
Seeker5211
