Question about Toyota Sewing Machines
Meistergram pro 1502 is not stitching - Toyota Sewing Machines
What position do I use for a straight stitch on a fashion pro sewing machine
Make sure the stitch Width is set to zero and that there are NO decorator design stitches selected. Adjust the stitch length to your needs. You will find it in the manual:
https://www.manualslib.com/manual/1050800/Simplicity-Fashion-Pro-Sw2145.html?page=19#manual
Nov 26, 2016 | Sewing Machines
How to repair error codes on meistergram pro 1500 embroidery machine
Are you asking what an Error Code means and then how to fix the cause?
Error Information...
In case of incorrect operation or machine malfunction, the screen will display the
description of error or icons to inform you.
CL key [CL] Clearing...
This key is used for clearing errors, information or data such as stitch count and frame
coordinates.
Error codes are in the Single Manual (final) pages 68 thru 73
Download this manual's .pdf file...:
http://www.pantograms.com/images/meistergram/Meistergram_Single_Manual_Final.pdf
Feb 08, 2015 | Sewing Machines
Euro-Pro 534 DX sewing machine cannot find the straigth stitch
try these sites for a manual
ebay
sewingpartsonline.com
sew4less.com
sewvacdoctor.com
a1sewingmachines.com
Apr 29, 2012 | Euro-Pro Sewing Machines
Lost manual to euro pro multi stitch 9000 machine. where can I get one
Lost manual for
How can I get one
Jun 24, 2010 | Euro-Pro Sewing Machines
I have a Shark by Euro-Pro and cannot find the straight stitch button.
Turn the knob on the font to 0 and see if that is the setting.
Mar 06, 2010 | Euro-Pro Shark 60 - 384
Friends broke needle on my euro pro multi stitch sewing machine.
According to Euro-Pro.com
Where can I buy new needles?
Answer: The needles are universal and can be purchased at any sewingmachine notion department. The size and type of needles should beappropriate to the fabric used. See the needles and fabrics chart inyour instruction book.
http://www.euro-pro.com/europro/faqdetail.aspx?modelno=9000
has all the information including a downloadable manual (pdf file)
Jan 24, 2009 | Euro-Pro 9120 Computerized Sewing Machine
CONSEW 206RB5 TOP THREAD NOT FORMING STITCHES AND BREAKING
you have your thread tension too tight that's why it is pulling the bottom stitch all the way through it looks good from the bottom but not good on top. Its pulled the stitch all the way through the material.
I had my own upholstery shop 18 yrs and tension gets you every time.Just loosen the top tension.
Jan 18, 2009 | Euro-Pro 8260 Mechanical Sewing Machine
Shark 384 - how can i get a straight stitch?
with the Shark Euro-Pro X machine, you need to bring the stitch width to zero it's the nob on top of the machine the manual states not to use it wider then 3 with the double needle cause it can break the needle. but either stitch selection "A" or "S" will give straight stitching with width at zero.
Nov 19, 2007 | Euro-Pro Shark 60 - 384
Sewing Machines Logo
42 people viewed this question
Top Toyota Sewing Machines Experts
Tally Girl
Tally Girl
xxxxxx xxx
Are you a Toyota Sewing Machine Expert? Answer questions, earn points and help others
