Question about True 49 cu. ft. / 1388 liter Commercial Freezer GDM-49F-RC
Freezer Not Fan not running!
I have a True Westerman Freezer and it runs the Compressor works everything seems to be good except the Fan is not running so it's not gettin cold i was wondering are they supposed to come on right away? because i had it unplugged for like 6 months and now im turning it back on!...and how long is supposed to run for to get to room Temp?...and estimate How Much will it Cost to Replace the Fans or Motor!
  • True Master
  • 1,151 Answers
Most all commercial freezers have some sort of fan delay/ defrost termination device. Commonly called a "Klixon" (pronounced clicks-on). It is a device that is attached to the evap. It's function is to terminate the defrost cycle when the evap reaches a certain temp, say about 50 degrees or so, to ensure there is no build up of frost/ ice on the evap. It then allows the compressor to run, and cool the evap down to a reasonable temp., say about 20 degrees, and then let the evap fan come on. It prevents overloading the compressor during a high temp condition, and it also prevents circulating warm air left from the defrost cycle. I believe this device is most likely your problem. With no air circulating, the box will no cool down.. I have seen them burn and/or slhort internally. They can come apart. too. I would look here for that problem. the True manufacturing website does not give alot of info on this piece of equipment, such as a wiring diagram but manuals are available.
Check this out and let me know how it comes out.
Posted on May 21, 2009
  • danielcastro Mar 25, 2011
    man are you a tech..? this is great info.. thank you ... i found the defrost control sutck on defrost. then i ordered one and it was sutck on defrost as well. so im going to put them in the freezer righ now and check if they will click...i didnt have a chance to check the pressures, but i bet you is low..
  • 122 Answers
Iv'e seen this problem before. When a unit is left off for extended periods the freon pressure on the low side is much higher than when it is running. Any small leaks on the low side of the system will leak faster when unit is left off. Lots of times the evap coil on the low side of the system does develop pin hole leaks over time. As an educated guesstimate I'd say you are low on gas. If the coil in the box never gets cold the fans will never come on.
Posted on Oct 29, 2009
True Freezer T23 compressor will not stop running
Have him check the t'stat. And freon lines. I believe the t'stat is the problem. Are the door gaskets ok and does it seal properly when closed. The fan should always run, so this could be in the rewiring. I am assuming you will be working out of a freezer where the working temp is a little higher.
Feb 16, 2013 | True T23F Freezer
Delay on evap. fan sistm.404a
Give the evaporator a chance to get cold, then check you've got power to the fan, via the evaporator thermistor and door switch
May 02, 2012 | True Freezers
True gdm12 evap fan runs all the time evev with the compressor off wiring seems not to have been touched
evap fans will run continuiously on this unit,it is normal. fans stay on to circuilate air evenly inside unit.
Sep 19, 2011 | True 72 cu. ft. / 2039 liter Commercial...
I have a Turbo Air TGF-49F freezer and it is not cooling. The compressor unit seems to work but when I turn the unit on all I hear is the compressor running continuously but nothing gets cold.
Difficult for you to check this I'm afraid, if the fan on the cooling unit is working unless you have an experienced 'ear' you will not hear the compressor running or worse still occasionally clicking.
Possible faults are
1. Compressor not running (the fan will run even if the compressor does not) electrical fault
2. Compressor seized (consult your service guy) also true for the rest of these
3. Compressor not pumping
4. Refrigerant leak
Not much hope for a cheap repair
Apr 14, 2011 | Turboair 49 cu. ft. Upright Freezer...
I have a true 2 door freezer with bun rack rails...it is runninig between 7 degrees up to 59 degrees...we vacumed the vents...do we need more coolant or what do you think...it is about 4 years old and...
Vacuuming the coil is not usually sufficient to clean them properly. Hold a flashlight behind the radiator on top of the freezer to see if you can see freely through the coils. If not, the best way to clean the coil is to spray coil cleaner on there and flush with plenty of water. It is a mess but it will get the grease off the coild. If you do not have gauges to check the pressures of the refrigerant (lets call it freon), you can get a good guess by doing the following: Get a ladder, climb up so you can see in the top of the cabinet where the compressor is located. It looks kind of like a bowling ball. There will be one small copper line and one large copper line running from the compressor. The small line is the high pressure line. It should be hot enough to burn your finger. It then goes through a small pan where it evaporates excess water, then to a "radiator" which has a fan running behind it. If the machine is running this fan should be on. The small line then runs into the freezer box. At this point the line should be warm, not hot to the touch. If this is not happening you are probably low on freon. The other copper line on the compressor is returning from the freezer box to the compressor. It should be very cold to the touch. It should have moisture collection on it. If this is not happening you are probably low on freon. Other factors can effect your freezer. Make sure the fan near the compressor is running. Make sure the fan or fans inside the freezer are running. They will stop running when you open the door, so hold the door button in when you check the inside fans. Check also to see if there is a build up of ice on the inside coil. Your freezer should run a defrost cycle 4 times a day to remove the ice. If it has ice it will not run properly. If you can remove your product for 24 hours and shut the freezer down, prop the door open and the ice will melt. On restart if the freezer goes down to 0 quickly (30 minutes) it was probably frozen over. This may indicate a bad defrost timer or heater. Try these things.
Sep 08, 2010 | True Freezer TG2F-2S
True upright freezer. coil fan not running.
Let it run. Coil temperature has to be low enough for the fan delay switch to close.
Jul 14, 2010 | True 49 cu. ft. / 1388 liter Commercial...
Fans inside freezer will not turn - no cooling - compressor fan underneath is turning
The fans are controlled with a clixon that has a cut in at 5 degrees, and cut out at 20 degrees. If the unit is running and the fans are not comng on then I would have to say you are out of freon. But your condensor fan could be running and the compressor NOT be running which could be a problem with your compressor. Find out if your compressor is running by taking an amp draw. If compressor IS running then you are low on freon. If the compressor is running and your evaporator coil is cold and your fans AREN'T coming on then your clixon is bad.
Sep 26, 2009 | True 72 cu. ft. / 2039 liter Commercial...
Our true freezer is not working at all.. No cold air going through the refrigerator.. Need repair assistance
we specialize in true freezer repair in illinois. Is compressor running or fan under unit? if not the thermostat may be bad.
Aug 06, 2009 | True 49 cu. ft. / 1388 liter Commercial...
New Commercial True Freezer suddenly quit freezing
Check for freon leak>> is compressor running?
or Iced over?
Jan 29, 2009 | True 72 cu. ft. / 2039 liter Commercial...
Freezer Not Freezing
check compressor is turned on. if compressor is going, you either have a system or compressor fault and this is not diy if compressor not going, possibly a thermostat fault. in this case put on fast freeze to confirm
Jun 15, 2007 | True 23 cu. ft. / 651 liter Commercial...
True 49 cu. ft. / 1388 liter Commercial Freezer GDM-49F-RC Logo
734 people viewed this question
Top True Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a True Freezer Expert? Answer questions, earn points and help others
