Analog stromsparmodus when i start the cpu and monitor the connection but says stromsparmodus. what should i do to fix this problem
4 Suggested Answers
  • 413 Answers
SOURCE: Monitor only shows Analog powersaving mode
Swap monitor for one that works on your machine?
Should be someone you know who would be willing.
Is it new?
If new ask for a swap.
F2 to open bios?
Posted on Jul 07, 2009
SOURCE: no signal analog
Can you still see the boot up screen when you start your machine up?
If you do, then restart the system.
As it's booting up, you tap F8 until you get a menu. Select "Last Known Good Configuration". That will help if you installed a bad driver for your graphics.
If that doesn't help, or if you don't get a picture at all, plug the monitor into another computer and see if it works.
If the monitor works and you still can't get a picture after following the aforementioned steps on your computer, you may need to replace the video card on your system.
Posted on Jul 12, 2009
oldrogers
  • 53 Answers
SOURCE: LCD monitor stopped working on my CPU but works on my Brother's
Definitely some electrolytic capacitors are blown inside the monitor in power supply module. Open it and observe any of them rounded on top, replace with proper ones.
You see, controller operations with VGA and DVI inputs takes different current from the supply, that's why it may take different time until PWM chip in the power supply will decide it is time to shut down before getting smoked.
Replace capacitors.
Posted on Sep 11, 2009
My P.C is running on windows 7 ultimate stopped working and the monitor is showing stromsparmodus message in its center.plzz help to fix this
Sounds like your "stromsparmodus" message is power saving mode for your screen. If you have a video card installed meaning the monitor is connected to a card that is inserted into the motherboards slot and the cable is over in a horizontal expansion area on the back of the case it may have died. You can try to remove it and connect your monitor the onboard video port after removing the faulty one and this should get it to boot. IF YOU DO NOT HAVE an expansion video card installed. Then you will need to probably replace your motherboard. you can try to remove the ram and just try one stick at a time. this can cause the computer not to boot if a chip has gone bad and you have onboard video. also just as a precaution you can reset you bios by unplugging the computers power supply and then pulling the small watch size battery out inside the computer for 15 seconds. and the replace it into the computer and repluging the machine. also check your monitor's vga or dvi cable is properly seated with no bent pins on either end.
William Pitt
www.willpowerpcs.com
Oct 15, 2016 | Computers & Internet
My computer screen is showing stromsparmodus message in its center. so what should I have to do now.?
stromsparmodus is German for Power saving mode, it may be from the computer screen menu itself, but you dont say what type screen or PC operating system you are using.
Mar 12, 2014 | Computers & Internet
Screen says check signal cable - have check my cables....
Not really...
First check if the cable connected from the monitor is secured and properly connected to the video card of the CPU.
"Check signal cable" will only be display if there is no signal coming from the CPU.. that signal Passes through the video card..
Check the status of your video card.....and see also if the CPU is working and not dead set.
Hope this help...
Much appreciated if you rate this help.. thanks
May 21, 2010 | Samsung Syncmaster 730B 17" Flat Panel LCD...
Monitor has solid green LED, but no display
you have to test the processor functions. therefore use post diagnostic card via PCI or PCIX or USB for the check hexa codes, if you show codes the processor ,ay be ok, also have to check the code function by card manual. and replace the unit that failure.
Mar 12, 2017 | AOC LM-800 18" LCD Panel Monitor
Lcd screen goes black after a few seconds
check your vga cable that is connected on your cpu,for some lose connection,it must be fitted if you still don't get any display check your cpu.have some other monitor for isolation,if you dont have bring it on s repair center,your cpu has a problem.
Sep 10, 2009 | Computers & Internet
Replace capacitors.
Sep 06, 2009 | Proview PL913S 19" Flat Panel LCD Monitor
No signal analog
Jul 12, 2009 | ViewSonic VA721 17" LCD Monitor
Is it new?
F2 to open bios?
Jul 07, 2009 | LG Flatron L1750S 17" LCD Monitor
"Analog going into power saving mode" when I try to play a game.
Most of these kinds of problems are created by using the different version than the current version of your video card driver.
Check your video card company's website and download the specific video card driver for your devide's ID and It should resolve the proble,
May 30, 2009 | LG W2252TQ Monitor
Analog Monitor problem
The problem in your monitor is SRGB
Use 3 simple steps to rectify this problem
1. Connect your monitor to another CPU
2. Change The Resolution to 800x600 32/24bit
(After 2 Miniuts SRGB will Reset)
3. After 5 Miniuts change the monitor to your CPU
Thank U
Apr 06, 2008 | Computers & Internet
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
