Question about AEG Cooktops
Aeg micromat combi child lock - AEG Cooktops
UNLOCK THE LOCK OF CHILDREN IN CERAMIC
Hi and welcome to FixYa,
I can not insert the symbols here to properly answer your question so, I found the manual and you can read the steps on page 9 here:
http://awadnahas.net/pdf/UserManual/bf7e9e9b-cc9e-46fc-94a7-5965a2d61b18.pdf
This is copy and paste from the manual and the symbols will not come out:
Switching off the child safety device
• Start the hob with ( ' ). Do not set the heat settings . Touch for (Up arrow) 4 seconds. The
symbol ( 0 ) comes on.
• Stop the hob with ( I )
The symbols I typed above are not 100% as they appear in the manual.
Thanks for choosing FixYa,
Kelly
Aug 23, 2011 | AEG HK955070CB 41 in. Electric Cooktop
Childs safety lock on
May I get the make and model # so I can help you get the child lock off.
Jul 04, 2010 | AEG 23 in. 6410KF-N Electric Cooktop
Turn hob on and only get letter L on each hob and will not turn on
child lock is activated , switch on hob press - and + button simultaneously hob will return to normal. if zeros dont appear try pressing and hold - key slightly before pressing +key hold both for a few secs.
Jun 23, 2010 | AEG 23 in. 6410KF-N Electric Cooktop
Gaggenau 230-110 steamer - cant take the child lock off!
Hold the child lock button down for 5 to 10 seconds. This should unlock it.
Apr 09, 2009 | Cooktops
Hi, I need to replace the fan element in an AEG 663e micomat combi I seems to need a special driver bit - where can I get it = it needs a sort of T20 with a 1mm hole in the centre
Home Depot and Lowe's sells the security Torx bits you are talking about. You will probably have to by a T10, T15, T20 and T25 set but should be less than $10
Dec 18, 2008 | AEG 24 in. 66300KF-AN Electric Cooktop
Aeg hob
It is child lock.
Turn cooker on, press two + at front of oven, this will then take it off for that cooking session.
To turn child lock off switch on hob, and touch - for 5 seconds.
Sep 29, 2008 | AEG 23 in. 6410KF-N Electric Cooktop
Child safety lock on neff cookertop
Just hold down the on button for about 10seconds
Sep 23, 2008 | Neff 23 in. T4343 Electric Cooktop
Hob not working
It is child lock.
Sep 16, 2008 | AEG 23 in. 6410KF-N Electric Cooktop
Child lock on for neff t1443
gud day,not all models of ceramic hob have a child lock,check it 1st ur unit if have it,if we have,touch the circle w/sign of key to lock the ceramic for ur child,to unlock touch again.u see the ligth red is on it means the lock is in ON.easy to unlock even ur child by touching the key sign,for ur safety to not use ur unit,unplug the unit if it not use.
Aug 21, 2008 | Neff 23 in. T1443 Electric Cooktop
CHILD LOCK
should be able to hold the lock on off pad for several seconds it might take longer than you think and I am not familiar with this product it could require a combo or sequence of inputs
Apr 19, 2008 | Neff 32 in. T1683SS Electric Cooktop
Cooktops Logo
35 people viewed this question
Top AEG Cooktops Experts
Charles T Nevin
Charles T Nevin
 Andrew Henderson
Andrew Henderson
Are you an AEG Cooktop Expert? Answer questions, earn points and help others
