Question about Ovens
How to set up oven in the Aftron AFGR66400
How to light the top burner in the Aftron AFGR66400 gas cooking range oven. When light up the bottom row is working.
fridgetech
  • 473 Answers
SOURCE: Roper gas range and oven with electric igniter
First look to see if the ignitor is coming on. Most common problem is the ignitor is weak or just bad. When the power is applied to the ignitor it glows and builds up resistance to open the gas valve then it lights. If the ignitor is weak or bad it will not build up enough resistance for gas to come into the burner. One sign of this would be a "woosh" sound when it trys to light. If the ignitor is coming on but not lighting it is most likely the ignitor is bad. Should have a full glow. Also, if the ignitor looks whiteish in color this is a sign of it going bad. You can compare to the broil ignitor to be sure. If the ignitor doesn't come on at all will need to see if you have power to the ignitor. Let me know what you find and let's solve it before you rate the solution.
Posted on Nov 07, 2007
SOURCE: Tappan gas stove,oven not lighting
i am unable to use my oven on my tappan gas range. every other part of the range works wonderfully. the oven just will not light
Posted on Sep 11, 2008
pride applia
  • 232 Answers
SOURCE: bottom oven won't turn on;
85% of these are usually the ignitor getting week and not allowing the gas valve to open prideapplianceser@sti.net
Posted on Jan 01, 2009
  • 22 Answers
SOURCE: KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Posted on Apr 25, 2009
heatman101
  • 43501 Answers
SOURCE: Kenmore Gas Oven doesn't heat
Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has faied...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Posted on Apr 07, 2010
How to change lower element in DeLonghi Airstream Convectio Oven
  • How to change lower element in DeLonghi Airstream Convectio Oven??
  • Preheat ovens only when necessary. With conventional ovens, keep the preheating time to a minimum. Unless you're baking breads or pastries, you may not need to preheat the oven at all.
  • Food cooks more quickly and efficiently in ovens when air can circulate freely. Don't lay foils on racks. If possible, stagger pans on upper and lower racks to improve air flow.
  • Use glass or ceramic pans in ovens. You can turn down the temperature about 25°F and cook foods just as quickly.
  • Do not open the oven door often to preview the food. Each time you open the door the oven temperature drops by 25°F. Watch the clock or use a timer instead.
  • Full-size ovens are not very efficient for cooking small- to medium-sized meals, it generally pays to use toaster ovens or microwave ovens.
  • Check to be sure the oven door gasket is tight. Adjust or replace gaskets as required.
  • If you have a self-cleaning oven, consider using the self-cleaning feature immediately after regular baking when the oven is still hot. Less energy will be required to reach the cleaning temperature. Try not to use the self-cleaning feature too often.
  • Keep range-top burners and reflectors clean; they will reflect the heat better and save energy.
  • Match the size of the pan to the heating element; more heat will get to the pan and less will be lost to the surrounding air. A 6-inch pan on a 8-inch burner will waste over 40% of the energy.
  • On electric stove-tops, use only flat-bottomed pans that make full contact with the element. A warped or rounded pan will waste most of the heat.
  • When cooking with a gas range-top burner, use moderate flame settings to conserve gas. Also make sure the pilot light is burning efficiently, with a blue flame. A yellowish flame indicates an adjustment is needed because the gas is burning inefficiently.
  • Whenever possible, use a pressure cooker. By cooking food at a higher temperature and pressure, cooking time is reduced dramatically and energy use is cut by 50-75%.
  • Oct 28, 2017 | DeLonghi Ovens
    I have a whirlpool range rf263lxtq the oven stays consent on what is wrong with it
    Oven clicks as if it is relighting almost constantly.
    · Old electric range ovens use a coil heating element called a resistive coil.
    This is nothing more than an electrical wire encased in a sheath. They have flat black coils over rounded burner drip bowls that catch your drips and spills.
    · The newer glass-ceramic cook top style element produces heat that radiates through the glass top to the cookware above.
    · Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop.
    · Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system. GAS OVENS 1)The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
    2) The Pilot flame is too low, and the tip of the igniter is not in the flame good enough. (the flame acts as a circuit when it touches the tip & completes the circuit).
    3) The spark module is no good and needs to be replaced.(But 1 & 2 are your best bet).
    spark module does not sense the flame when it's on. The spark igniter is also the flame sensor which provides feedback to the spark module.
    Make sure the igniter is properly aligned with the burner lighting holes and it is clean. All lighting holes must be clean too. You can enlarge them using a drill bit one size bigger.
    If it would not fix the problem, replace the bake burner and the igniter.
    There is a small chance for the spark module itself to be bad as well.
    ELECTRIC OVENS:
    CHECK THE OVEN RELAY CONTROL BOARD Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
    Feb 15, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
    GAS OVEN WILL NOT GET HOT
    see this instructions and fix it. God bless you
    1. eHow
    2. Home & Garden
    3. Home Appliances
    4. Other Home Appliances
    5. How to Troubleshoot a Gas Range Oven That Won't Heat
    By Kefa Olang, eHow Contributor
    Although gas range oven may prove useful for cooking and baking, they may fail to ignite if they aren't properly maintained and set up. Lighting a gas range often involves simply turning a knob; however, blockages from food particles and debris caught in the burners, improper burner cap installation and gas supply are common problems that interfere with your gas range oven's performance. A few troubleshooting guidelines may solve these problems safely.
    Other People Are Reading
    Things You'll Need
    • Toothpick
    • Paperclip
    Instructions
      • 1
        Check you have gas in your tank if your gas range oven won't heat. Contact your gas supplier if you've run out of gas.
      • 2
        Clean the burners if you have gas but your burners still won't ignite. To clean the burners, lift the burner caps 9b4f010f-be4f-4db6-8a88-4c3fd17e3339.gif
      • 3
        Inspect the small vertical holes on the side of your burners for dirt, food and debris. The gas won't ignite if they are clogged. Scrape dirt, debris and food from the vertical holes using a pointy object such as a toothpick or paperclip.
      • 4
        Reinstall the burner caps properly. If they are tilted or wobbly, the gas may not ignite. Install the caps on the right burners. Some burners are smaller than others, so match the caps to the appropriate burners.
      • 5
        Move the burner knob to the "Lite" position and wait for the gas to ignite. If it ignites, rotate the knob to your desired setting. If it doesn't ignite, contact a qualified appliance technician.
    Jul 18, 2013 | Ovens
    Oven burner doesn't light. Igniter doesn't light. Boiler burner does light and Igniter does light
    Hi. This sounds like a weak igniter, the symptoms usually are: burner won't light, or takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
    Mar 01, 2010 | Maytag Ovens
    I have a RCA gas self cleaning oven,It heats on broil but not on bake.we have noticed over the weeks the oven was getting as hot as the thermostat was set at.Now it won't heat at all
    Feb 13, 2010 | GE Ovens
    Gas stove top works, broiler works, oven does not
    is it electronic iginition? are you asking about top burner pilots? if so there are under the top in the middle beteen each side of the burners 1 pilot does burners on right and 1 on left. oven pilots are underneath you have to remove bottom door look in there at back and look up and you'll see it. if its a electronis ignition range you have no pilots!! glow coils and sparkers....
    Feb 06, 2010 | Kenmore 30464 / 30465 / 30469 Gas Single...
    I have an Amana AGR5715QDS and when I turn it on and set it for any temperature, lets say 350 degrees, it does not turn on or heat up. The stove top burners still work fine and the door appears to be OK,...
    Feb 05, 2010 | Amana Ovens
    Oven is slow ot light and has a gas smell when
    Hi, this sounds like a weak igniter, it would have to be a gas oven and the symptoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, if it does light the burner, there may be delayed ignition (pop), does not maintain set temperature or burner does not come on fully, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
    Jan 21, 2010 | Kenmore Ovens
    Not enough gas to range?
    you either have a gas pressure problem from your meter outside or a bad pressure regulator on the range. if you use a magnehelic guage (get from a plumming supply house) you should be getting about 11inches of water coloum, or you can call your gas company to check it out... Let me know how it goes.
    Jan 09, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
    Frigidaire Gallery Professional Series - No clock/oven functions
    i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
    Nov 01, 2008 | Frigidaire FGB24S5A Gas Single Oven
    Ovens Logo
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
