Question about iRiver iFP-799 MP3 Player
Music won't play..only radio
I haven't used it in a while..put in new battery...now only the radio plays. I can't get my songs to work. What am I doing wrong? or is something wrong with my mp3? I have IFP 799 I river.
I found the manual online...and fixed the problem..it was a user malfunction
Posted on May 18, 2009
SOURCE:
I have a droid Samsung Galaxy 4S cell phone. My problem is in my attempt to play music from my cell through my boat radio I plug in with a cord through the top jack on the phone directly to the radio.
A Samsung phone running the Android operating system probably has a Google "Play Music" app installed. Open the list of apps and look for it. If not go to Google "Play Store" and install it. https://play.google.com/store/apps/details?id=com.google.android.music
If your music files are on your phone or memory card, you can set up the app and it will create a database of all your songs (usually in a folder called "Music"). The app plays what you ask it to play - one song, or an entire album, or all songs in the "genre" Country, etc. The radio just plays whatever sound the phone is sending. The iphone is set up to play a series of songs (probably you selected an album) before pausing.
Mar 27, 2017 | Cell Phones
Why do i get format error when i put songs from a cd on the eclipse?
1. Why do i get format error when i put songs from a cd on the eclipse?
= This is probably because the format that your songs are currently in is not supported by your device. Supported devices on the Mach Speed Eclipse 180 MP3 player are: mp3, wav, and wma. If your music is for example filename.cda, it won't be able to play because of the file format being .cda.
2. I also see the song on the eclipse but it says drm protected and will not play the song.
= When ripping your music, check your ripping options in whichever ripping software you are using that protecting music files is off, this may be the reason why your music cannot play - it may be protected to only play on the computer that ripped(recorded or duplicated) the song.
Sep 17, 2012 | Mach Speed Eclipse 180 MP3 Player
Why won't my new mp3 work properly?
MP3 players can only play music files in mp3 file format. You can download mp3 music files from the Internet to your computer and then copy them to your MP3 player using the USB cable. For your CD collection, you need to convert your CDs to mp3 music files onto your computer or download them from the Internet and then copy them to your MP3 player after you have connected the USB cable to the MP3 player and the computer.
You can do this using Windows Media player and Rip the CDs - Media Player will create a MP3 music file for each music track. Click on this link for instruction on converting music files to mp3 file format :- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Aug 20, 2012 | Audio Players & Recorders
Music dont work on samsung c3050
Please check the format of the files , connect to the PC or remove the micro sd card and use a adapter to be used on the card reader of the PC. If the format is not correct you can change and reinstall with the required type. Also scan for virus or error files which will not be read.
Dec 13, 2011 | Samsung C3050 Cell Phone
How do i put music from my p c to my psp
To play mp3 on your PSP, you'll need
  • A big enough memory stick duo. The 32 Mb that comes with your psp will only fit a few songs. To really make it practical, i recommend that you try and find 1G memory stick. If you look hard enough, you'll be able to find one for about 0
  • You'll also need a Mini-USB (USB A to USB Mini-B) cable or a memory stick card reader to access your memory stick from your pc.
1. Connect to your memory stick
If you are using memory card reader I assume you already know how to do this. If you are using USB cable, simply connect the cable to your PSP and Windows will detect it as a new drive.
2. Copy your music into the folder named "MUSIC" inside the "PSP" folder.
In the memory stick, there should already be a folder called "PSP", if there aren't any, you haven't been playing any games! Inside the PSP folder, find a folder named "MUSIC". If it is not there, don't worry, simply create a new one.
Now, simply copy your mp3 songs into this "Music" folder and you're done. You can also create folders inside the "MUSIC" folder and put your songs there.
Mp3 Playback Tips
  • To save battery, you can turn of the screen by holding the brightness toggle button for more than 1 second.
  • Press the triangle button to view other options such as repeat mode and the built-in help.
Jun 19, 2011 | Sony PlayStation Portable (PSP) Console
How do I enter songs in my sony NW-E002 512 MB MP3 Player? I already have the software named sonicstage. But I am not being able to use how to enter the songs. As in I dont know how to enter songs
personally, i usually just drag and drop from my music folders on PC directly to music folder on mp3 player. but you can try this website to download manuals
http://www.usersmanualguide.com/sony/mp3_walkman/nw-e002f
thanks
dont forget to rate FXYA
Mar 25, 2011 | Sony NW-E002 MP3 Player
How do you play music saved on an SD Card?
1) frm da music on iTunes, right-click,then click on CONVERT 2 aac.another track(identical) should come out.
2)after completing step 1, go 2 my computer nd open the SD card up,create new folder or use da one u used 4 ur other music.
3)after step 1&2 copy nd paste ur song(s) to the folder u had open.hope dis helped
P.S. make sure u converted ur songs 2 AAC(aac) or else it wont work.
Nov 08, 2009 | Nintendo DSi Black Console
Sandisk 240m mp3 not playing
the radio and mp3 uses one audio amplifier, check if you have loaded your music with mp3 songs, if not load with mp3 songs. if songs used to play and just stopped playing, then follow these steps,
i does your display show song playing, if it does then your set is fault, and if it doent and display unsuppoted, load with mp3 songs.
ii if it was playing and just stopped, than take it to a tech, who can open it and check the change-over switch, or selector of that set.
iii the problem is to very big.
Mar 30, 2009 | SanDisk Sansa m240 MP3 Player
Error message M506
I also had this problem and thought my music players were broken. The media players displayed the songs as 00:00:00 even when the file info read that it took up space and had a song length. The music player displayed that m506 error message.
I looked through forms for an answer, and I noticed I didn't try messing with one thing: THE BATTERY.
Try taking the battery out of your phone and putting it back in. It worked for me! My music players work again!
Nov 04, 2007 | Samsung MM-A920 Cellular Phone
iRiver iFP-799 MP3 Player Logo
91 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Peter Dragonetti
Shawn DuRee
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
