Question about Mitsubishi VS-60607 TV
My picture is wavy, I have a mitubishi big screen model # vs-60607
  • 126 Answers
Sounds almost like bad caps okay this is where i would start is thier an option on the set to alighn convergence try that also okay may be bad module also okay its worth fixxing okay call tv shop
Posted on May 18, 2009
I thought i might need a lamp for my mitsubishi tv--model VS 60607 when my tv is fuzzy when turned on.should i simply replace the lamp or is there something else i should try? thank you!
This TV is a rear projection television and does not have a lamp. It has three CRT color guns (Red, Blue, and Green). You have a convergence issue (the red, blue and green color guns aren't aligned properly) and it doesn't sound like a very big one. You should be able to adjust this through the CONVERGENCE Menu in ADVANCED SETTINGS.
More details can be found in your manual, here. The model number isn't exactly the same but I'm sure the process is identical or really close. The other option would be a bad IC (integrated circuit) for the convergence control. This is unlikely unless your picture looks something like this: captainhawk1_15.jpg
May 29, 2011 | Mitsubishi VS-60607 TV
MITSUBISHI TV VS-60607
HI there,
Check for any bad solder on the mainboard of the TV, and also check for any burn fuse on the powersupply area... BAd solder was very common problem on Mitsubishi TV..
micro
Jun 07, 2008 | Mitsubishi VS-60607 TV
Mitsubishi vs-60607 60" screen is
when picture is getting smaller in size or goes away or moves towards one side then hit your TV lightly on left side or right side or on top & then observe ..........you will get normal picture or it comes & again it goes....if it is happening like that then following is the situation..........after 4 or 5 yrs in some TVs on main board at some soldering joints crack develops....then due to loose contact picture becomes small in size or disappears ...........when we hit that lightly then those loose contacts joins temporarly & again picture appears for some time............so solution is ......TV main board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting TV lightly if there is no response then main board has to be checked completely........in your case iam sure it is loose connection problem.........joints should be re - soldered ...100% it works again................this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good TV service engineer
Apr 22, 2011 | Mitsubishi VS-60607 TV
Horizontal/vertical hold is off, picture is moving fom left to right Mitsubishi big screen vs-60607
You better take this fellow to a doctor. You have a stamp size IC with about 250 pins that is bad. Only a tech can replace this or reinstall a remanufactured board into this TV. You may ask the tech to use a freeze spray to find this IC first and then he wil decide how to operate!l
Jan 24, 2010 | Mitsubishi VS-60607 TV
Mitsubishi VS 60607 60" TV
From what i have been told the VS - 60607 was built in 2000 and i am not sure if it is HD or not.....
Aug 31, 2008 | Mitsubishi VS-60607 TV
MITSUBISHI BIG SCREEN TV MODEL VS-60607 CUTS OFF FOR NO REASON
My mitsubishi 65in projector model # ws65807Just started shutting off it only stays on for few seconds and cuts off. I cant get it to stay on
Jul 31, 2008 | Mitsubishi WS-65807 65" Rear Projection...
No picture
Try a "hard restart"', which simply means unplugging the power cord of your TV, and replugging it after 4 hours have passed. This technique helps to reprogram the electronics of your TV.
Hope this suggestion works for you.
Jun 05, 2008 | Mitsubishi VS-60607 TV
Wavy picture on television screen
First do the self test on these threads or goto ctechnicians.com
Dec 29, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS-60607 TV Logo
506 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
