Question about Acer Aspire 5050-3242 Notebook
Having completed a factory reset on my Acer aspire i have a solid blue box stuck on Installing e recovery It's running but nothing more!!!!!
  • nut-1 May 18, 2009
    HI DaNoWhereMan
    it,s an acer aspire 3680
    Did recovery cause various applications were not working correctly
    Previous recovery gave same prob but friend got windows to stop this on start up but he forgot what he did!!
    i,ve tried disabling through defender but no success!!
    Thank You for taking an interest in my problem it is appreciated
    Jen
  • DaNoWhereMan May 11, 2010
    Operating system?
    How long has recovery been running?
    What caused you to recover in the first place?
    RAM and CPU are?
  • 3 Answers
OK you said Windows, but not if XP or Vista (presuming you don't have a way older version). Since you are saying "recovery" I'm going to presume Vista, since MS stopped shipping install disk after XP.
It's been 4 days, so I presume you are not still stuck in recovery mode, and can boot into Windows?
If so, try the free virus scan, reg fixer, etc from Microsoft at:
for XP: http://onecare.live.com/site/en-us/default.htm
for Vista: http://onecare.live.com/site/en-us/center/whatsnew.htm
(I was a beta tester for this, before it went public).
If you can't get into Windows (even safe mode) you will probably need to find someone with the install DVD (if it's Vista). Since it sounds as if there is either a problem with your recovery drive or a corruption of the recovery software/files itself.
Posted on May 21, 2009
My acer aspire one has stucked on factory recovery mode, it has tucked when installing configuration for android on the 30/39
If you are installing an Android operating system on an Aspire One you will need to make sure you have a compatible ROM image. I would suggest you try and install a Linux OS such as Ubuntu or Mint. The Aspire One was available with Ubuntu from the factory.
May 05, 2013 | Gigabyte GA-8SIML Motherboard
Reset acer
The Acer Aspire One is a netbook, not a laptop.
A netbook is a smaller, scaled-down version of a laptop. It does not have the memory capacity or graphics of a regular laptop.
It also lacks a CD drive, which means you cannot restore the Acer Aspire One with restore discs. Instead, the netbook has a built-in factory restore feature.
You can reset the Acer Aspire One to factory settings just using your keyboard.
Only restore your netbook to factory settings if you cannot fix the problem any other way.
Save any files or folders on your Acer Aspire One with flash drives.
Drag and drop files onto the icon of your flash drive.
Go to Start > Restart to reboot your netbook.
Hold down Alt and F10 when you see the Acer logo on the screen.
The recovery menu will load.
Hit Enter and then Next to see your recovery options.
Choose Factory Restore to set your netbook back to factory settings.
Follow the instructions on the screen.
Choose your time zone and language when the customization menu appears.
Reboot the netbook when you are prompted.
Restore your saved files from the flash drive.
or
When a vital file becomes corrupted, it might be necessary to restore a computer to its original factory settings.
This process also cleans up the hard drive and removes old programs that can make a computer slow and unresponsive.
But, because restoration wipes away all files you have installed or created, it should be a last-ditch effort in trying to repair a computer.
If you have reached this point with your Acer laptop or desktop, the manufacturer provides a utility to restore the factory settings.
Open the Windows Start menu by clicking on the icon in the lower left corner of your desktop.
Click All Programs, then the Acer folder.
Select Acer eRecovery Management to open the utility.
If a Windows prompt asks for permission to run the program, click Yes.
Click the Restore button in the pane on the left side of the program window.
Click Completely Restore System to Factory Defaults.
Select the Yes option in the dialog box that asks you to confirm the action, and click Start.
Click OK in the second confirmation dialog box to restart the computer.
Click Next in the warning window that appears after the computer reboots.
This confirms that you realize restoring the computer deletes any data stored on your hard drive.
Click Next again in the Restore Destination window, and click OK in the popup that gives you one last warning about deleting your data.
The restoration process will begin.
Click OK when the utility lets you know that the restoration is complete.
The computer will restart, and Windows will finish the recovery process.
http://acer.custhelp.com/app/answers/detail/a_id/12869/kw/factory settings/related/1
May 01, 2013 | Acer Aspire V3-571G-9435 15.6-Inch Laptop
ACER REINSTALL STUCK ON INSTALLING CLEANUP 28/29
Sounds like the recovery disk when BURNT contains errors, you need the factory discs for your system
Jan 26, 2013 | Acer Upper Case Palmrest for Aspire 5336,...
Reset acer 4810t
You can start the Recovery from outside windows by holding down the ALT key and tapping F10 repeatedly
on startup. When the recovery loads you will be prompted for a password.
This should have been set by the customer if they have been into the Acer Recovery Management software previously.
If they have forgotten the password or you wish to clear the password you need to boot off the recovery disk that should have been created.
More Information
From the Acer toolbar at the top of the desktop click on the disk icon
Setup a password if requested.
After clicking on setup you need to click Create Password to continue.
Create a password and add a password hint (strongly recommended).
You now have the option of restoring from a previous Windows Vista backup or you can start the Acer recovery process.
The recovery is started by clicking Restore at the bottom of the window.
Further types of recovery are now presented.
Choose Restore system to factory default if you wish to run the hard drive based recovery and return your Acer computer back to it's original factory default state.
Note: The factory default recovery will wipe ALL data from the computer so ensure important data has been saved to disk before proceeding.
Enter the password that was previously set.
Confirm you wish to run the recovery process.
After confirming you wish to run the recovery process the computer will restart and restore all the original files
Complete the Out of Box Experience when prompted
After a couple of restarts the computer will run through restoring the preinstalled software that came with your computer and then be ready to use
hope this helps
Jul 27, 2012 | Acer Aspire 3810T 4810T 5810T
I wnt to know how to reset the computer
Assuming the netbook is working normally, and it has the original hard drive that was in it from new, there should be a recovery partition present on the hard drive.
When you switch the machine on, press and hold the Alt button and F10 while the Acer logo is showing. This should give you access to the Acer Recovery centre. Alternatively, boot to Windows, click the start button, All Programs, Acer and Acer eRecovery Management.
Please note that factory recovery usually completely wipes any user data, so back up any important files before performing the recovery. Recovery will restore the machine to the factory installation, so you will also lose any third party software that has been installed since the machine came out of its box.
Jul 24, 2011 | Acer Aspire One D255 Netbook
Hi there , how do i completly reset my Acer Aspire E380 desktop computer to factory settings again . i have backed up everything i need and i just want to start again completely and wipe it all. any...
Hi.
With that desktop computer being new it should have a hidden recovery partition on the hard drive that allows you to perform a factory restore which will take it to how it was when you took it out the box.
To access the recovery partition on your Acer computer for recovery, follow the steps listed below.
1. Power on the computer
2. At the white ACER BIOS screen, hold the Alt key and press the F10 key simultaneously to start Acer eRecovery.
3. Once eRecovery has loaded, click Restore to Factory Default Settings
4. Click OK to continue
5. From here, the eRecovery process will update all the data on the C: drive and restore a fully functional factory image which should take approximately 10 minutes.
6. Once eRecovery has run, press OK to reboot the computer.
Hope this helps!!!
Regards.
May 31, 2011 | Acer Aspire E380-UD420A (ASE380-UD420A)...
I have an Acer Aspire 5520-5334 how do i reset to factory settings? It is running window vista.
Acer PC or laptop
Step 1:
Click "Start" menu.
Step 2:
Click "Programs."
Step 3:
Click "Acer Recovery Management."
Step 4:
Click the "Restore" button on the bottom of the dialog box that opens.
Step 5:
Click "Restore System to Factory Default."
Step 6:
Click "Yes" in the warning dialog box which asks if you wish to continue the recovery process.
Step 7:
Click "Start" to restore the computer to the default factory settings.
Tips & Warnings
If you are unable to access the Start menu, use the recovery CDs that came with the computer or visit Acer's website (see Resources below).
Always make a back-up CD before restoring a computer to factory defaults.
Resources
Feb 06, 2011 | Computers & Internet
When i power on my Acer aspire one all i get is blue screen....how do i restore factory settings?
press f9 as soon as soon as you turn on the laptop and you should be routed to the recovery console. tick the box and continue. disclaimer: going for the factory settings will delete all data. Restoring it to the factory defaults will only work if there's a recovery partition on the hard drive itself
however if the cause of the blue screen is a hardware failure , restoring it to the factory settings will be useless
Oct 23, 2010 | Acer Aspire One PC Notebook
Acer laptop stuck on Aspire screen
i/run operatin disk take prompt comman and type chkdsk/rr 2-3 times it can be repair your system 2/ repair by operating disk if not work by two methode reinstal operating system.
Oct 14, 2009 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 5050-3242 Notebook Logo
173 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
