How do i connect Denon AH-NCW500 headphones to a Denon AVR-3313 Amplifier?
pomonabill22
  • 7 Answers
SOURCE: AVR-1603 - no Sound exept over Headphones is a weak signal
First check the outputs at the output fets/transistors for any DC voltage. Reference your voltmeter to the speaker - terminal. If there is ANY DC offset, the amp is shutting down the outputs to protect your speakers from DC. Is the power supply + and - 47 volts? If only one supply is there That is your problem because the supplies should be symmetrical. Also look for any wiring problems from the amp to your speakers... any shorts? Try disconnecting all your speakers to totally eliminate any speaker problem and see if the relays still click. You should hear only ONE click when you first turn the amp on (delay of about 2-5 seconds). If they keep clicking the amp outputs are next. Also, is there any indication on the front panel of what is failing?
Posted on Aug 13, 2007
tech48
  • 624 Answers
SOURCE: Denon AVR-3802
I have repaired many of these Denon receivers over the last few years.
Since the headphones work, that means if you dis-connect the speakers it will turn on and not go into protect (when power cuts off a few seconds after turning the unit on).
The most likely problem is a bad speaker. to find out which speaker is causing the problem, do this.
Start out with just one speaker connected and then turn on the unit. If it turns on and plays music, you know that speaker is good.
Now turn the unit off again and add another speaker and keep the first speaker connected. Once again, if the unit plays, that speaker is also good.
Keep doing this same procedure one speaker at a time. As soon as you connect a speaker and then try to turn on the unit and it goes into protect, the speaker you just connected is bad.
To confirm that this speaker is the bad speaker, dis-connect all speakers and only plug the suspected bad speaker into a speaker jack that worked with one of the other speakers.
If the unit still goes into protect you know then that you have found the bad speaker.
If the unit still goes into protect, that speaker is bad and you will need to take it in for repair or replace it.
make sure you use 8 ohm speakers. if i remember correctly these Denons can use 6 ohm speakers, but those are harder to find and most home speakers are 8 ohms.
If the unit does not go into protect and that suspected bad speaker plays in one of the other speaker jacks, what you really have is a bad channel in the amplifier, the channel that the suspected bad speaker was previously connected to.
If you find out you have a bad channel, you will need to take it in to an repair center. Preferably an authorized Denon service center. There are not very many of those around. I work at the only authorized Denon service center in the entire state of Michigan.
If I can be of more assistance, don't hesitate to ask. And a good rating is always appreciated. :)
Posted on Jun 22, 2008
SOURCE: control code for the Denon AVR 1403 so I can program my motorola
I did resolve the matter, thanks
Posted on Dec 10, 2008
SOURCE: connecting wireless headphones
stop connecting
Posted on Jul 06, 2009
  • 11800 Answers
SOURCE: how can i connect headphone
If by that you mean that you want both the speakers and the headphones to be active at the same time then it's easy to do : you just buy this adaptor
http://www.amazon.com/Cables-Go-40424-Stereo-Y-Cable/dp/B001B8QUS6/ref=dp_ob_title_ce
you connect it in the discrete Zone 2 outputs (the ones set vertically with a black one underneath them), then you plug in it a pair of headphones with a volume control knob like
http://www.amazon.com/Koss-KTXPRO1-Titanium-Portable-Headphones/dp/B00007056H/ref=sr_1_1?s=electronics&ie=UTF8&qid=1307222481&sr=1-1
and finally you configure the Zone 2 accordingly in the Denon.
Posted on Jun 04, 2011
How to connect a walkman to a Denon AVR-3805
headphone jack cable to 2x RCA/phono (red & white) cable. Connect that to a spare input on the amp.
Sep 02, 2014 | Denon AVR-3805 Receiver
How can I connect my I pod Touch to my Denon AVR 1803 reveiver?
Connect the 3.5mm cable to the iPod headphone output and the two RCA plugs into any unused analogue audio input on the Denon AVR 1803. Then choose the appropriate input on the Denon, press play and enjoy the music. Be careful about volume. Start with the volume on the iPad low and adjust to suit.
Cheers, Don.
Aug 07, 2014 | Denon AVR-1803 Receiver
I cannot connect my iPod nano with Bluetooth to my Denon AH-W150 bluetooth headphones. Help!
that is because the ipod nano can not connect to bluetooth it does not have a bluetooth reciver
Sep 07, 2013 | Denon AH-W150 Exercise Freaktm Bluetooth...
Only red light is blinking on my denon avr 1508
It sounds like you overloaded the Denon avr with too much resistence from the speakers. Please check the total resistence of the speakers before you connect them all. Also check that the speakers or their wires are not shorted!
Jan 20, 2013 | Denon Audio Players & Recorders
Denon Receiver keeps switching between H/P input and speakers
The problem may be dust in the headphone jack
http://blog.adamnash.com/2010/10/01/solution-denon-av-receiver-avr-1410790-with-no-sound/
Jun 17, 2012 | Denon AVR-1709 Receiver
Hi, how can i hook up a wireless 5.1 headphone to a denon avr-3808 using an optical connection. I can't find any optical output port on the denon amplifier.
My manual shows two optical outputs labeled "2 (DVR)" and "3 (VCR)" at the upper right of the rear panel.
It's unclear what will appear there when playing any particular analog source.
Feb 26, 2011 | Denon AVR 3808Ci Receiver
How Do I Connect My Dell Laptop to a Demon AV Receiver
use a 1/8in stereo to two male RCA plug to connect from your computer headphone out to an input on the Denon such as AUX or CD
Jan 25, 2009 | Denon AVR-587
Connecting wireless headphones
You should be able to get a cable with your headphone jack on one end and the standard left and right RCA jacks on the other end from just about any electronic store. Carl.
Sep 09, 2007 | Denon AVR-2807 Receiver
22 people viewed this question
 Grubhead
Grubhead
