Question about Fagor LFA-65 IT Dishwasher
I have a problem that I was hoping you can solve for me. My dishwasher starts and cleans for about 10 minutes before it stops cleaning and starts beeping constantly instead. When opened the beeping stops but all lights on the right side of the panel blink
Dishwasher starts, drains, runs 2 minutes, then stops & turns on Clean light
Sounds as if the programmer is not responding maybe time to call out service engineer. Sorry or wash up by hand like I do.
Nov 02, 2017 | Bosch Dishwashers
Intake drain light on
Hello & Welcome to FixYa
The problem is with clogged drain filter pump assembly, you can take it apart from the bottom to clean the drain filter pump assembly. After you have cleaned it completely then turn the selector switch to STOP/END or press the START/STOP for 20 seconds. After you have done all this unplug the appliance for 5-10 minutes and plug it back to solve this problem. Please get back to me if you have any other questions.
Kevin
Dec 19, 2011 | Miele 24 in. Novotronic G851SC Plus...
Control panel or electrical panel not working right. It stops washing at 10 minutes
The DD603 dishwasher from Fisher and Paykel is a very sofisticated electronically controlled dishwasher. It does not have a control panel or electrical panel unlike some of the other brands of dishwasher which are electromechanical controlled.
So if it is stopping with 10 minutes left on the LCD display, then it might have simply gone into the Dry mode. A small fan in the door unit starts up and sends warm air into the unit. At this time the dishwasher gives a couple of beeps. You will have to wait until the time display goes to 00 provided the dishwahser is set to be in the Clean Dish indicator option is on. This means the washing is complete. Refer your instruction manual.
It is also a good practice to keep the area around thw wash program button (on the drawer door top edge) clean. Sometime grime can cause false trips.
Hope things are not as bad as it may appear.
Nov 15, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Clean light blinks, dishwasher won't start,
turn the power off at the breaker for 10 minutes and check it then.
Jun 11, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Kenmore Elite Dishwasher clean light ind flashing and won't start
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
Feb 17, 2009 | Kenmore 24 in. 15142 Built-in Dishwasher
Clean light is blinking and I can't start a new load
erin,
Try throwing the breaker off for FIVE minutes and then restart it. This may solve the problem.
Let me know. Please remember to leave a rating
Oct 06, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Zanussi ZDT6252 stops 1min into cycle
You need to reset the computer on the bottom. Had the same problem with mine. The Blinking led means the heating element is bad and will not operate.
Dec 30, 2007 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Another inlet / drain light cycle interruption problem!
When the water stops too soon, it could be the "over flow" is stuck in the downward position, therefore the dishwasher thinks it's going to over flow. Check that out. Otherwise I'm afraid this sounds like the circuit board is shot.
Miss Midget
Nov 02, 2007 | Miele 24 in. G646SC Plus Free-Standing...
Fagor LFA-65 IT Dishwasher Logo
75 people viewed this question
Top Fagor Dishwashers Experts
dannydoesita
ray gallant
Are you a Fagor Dishwasher Expert? Answer questions, earn points and help others
